Question about Sharp Sidekick LX Smartphone
Low battery signal on ohone ,phone wont turn on
Hi i have a sidekick lx and i have already purchased two batteries and used different chargers and it still says let battery charge for a few minutes and the phone will power on and it still hasnt what to do
    Problem Solver:
  • 12 Answers
Check the shorting and update software by flashing
Posted on Jul 30, 2009
SiDEKiCK LX CHARGER PORT BROKEN??
sound like you need a new battery or charger or maybe both. try useing a diffrent battery and charger befor buying one
Aug 27, 2009 | Cell Phones
Sidekick lx will not charge
Try charging in using a different method, either an external battery charger or connecting to a computer.
Aug 09, 2009 | T-Mobile Sidekick
Charging
Replace battery. Improper charging has created a memory in the battery faking charger to think it is fully charged.
Jun 29, 2009 | Sharp Sidekick LX Smartphone
My side-kick LX will not turn on
Try this, though is used for when the device is randomly rebooting aswell, it might help you to force your Sidekick to come back on:
  1. Check the device's battery level for at least two bars of strength.
  2. If the battery level is low, charge the battery.
  3. If the issue is not resolved, remove the back cover.
  4. Remove the battery.
  5. Wait 10 seconds.
  6. Press and hold the W key.
  7. While pressing down the W key, re-insert the battery.
    • The device restarts and after approximately 15 seconds, the 'Recovery' screen appears.
  8. Select the desired language.
  9. Select Reboot to restart the device.
  10. Your Sidekick should go back to the main screen as normal. Good luck
Dec 02, 2008 | T-Mobile Sidekick® 3 Cellular Phone
Sidekcik Lx will not charge.
Try a new battery for it.
Sep 09, 2008 | T-Mobile Sidekick
alright..my sidekick does he same thing but i fund a temp fix....the guy at the store says its the charging port..idk.....first plug it in....let it charge 4 ten min....then try to put in on...it will say the low battery sign...dont worry...then t8 sumting pointy and push it in the little reset hole behind the screen as you swivel it...as soon as you see the little box with the circles in it you press and hold the space button... hopeully it will start by showing the four butttons....if it does start and cuts off at the tmoblie sign jus let it charge longer and do it agian....hopefully it will work on yours it worked on mine....gud luk
Jul 02, 2008 | T-Mobile Sidekick® 3 Cellular Phone
Phone will not turn on
Sounds like your charger port is busted. Ti is a common problem on sidekick 3 and can effect sidekick IDs as well. A fairly cheap workaround is to get an external battery charger. It will have a slot to charge the sidekick battery external formthe phone. They sell on ebay fior about 25 dollars.
The sidekick ID and sidkeick 3 batteries are the same so it will work. Check then out here
Sidekick ID battery charger
Feb 24, 2008 | T-Mobile Sidekick ID Cellular Phone
Sidekick problem
It looks like it's a battery related problem . You should get a new battery. Good luck!
Dec 12, 2007 | T-Mobile Sidekick® 3 Cellular Phone
My problem is with the sidekick III, it wont charge, What should I Do?
dnt drain the batteries of your phones...if that happens pls buy multicharger or battery shock,remove the battery..... charge it for about 5min or shock the battery if ur using battery shock...be sure u positioned it ryt....den put it back on ur phone then charge it or continue the charging on the multicharger until its full !!!!im pretty sure of it....im encountering the same prob as urs before and thats what i did and it work!!!!
Jun 09, 2007 | T-Mobile Sidekick II
Sharp Sidekick LX Smartphone Logo
341 people viewed this question
Top Sharp Computers & Internet Experts
Tony
Jason Harris
Jason Harris
Ricky Ostrom
Ricky Ostrom
Are you a Sharp Computer and Internet Expert? Answer questions, earn points and help others
