Question about HP LaserJet 9050 Printer
Seems to jam in fuser, fuser has been replaced
Laserjet 9050 - Seems to jam in fuser, fuser has been replaced rollers are new
  • Paul Douglas
    Paul Douglas May 11, 2010
    Hi kdibler: What error on the display panel are you getting?
  • garcia
    garcia Apr 17, 2014
    How to fix Jam in fuser when print photo full page?
  • 99 Answers
If it always jams at the same place (fuser area) try another fuser or check the BLACK PLASTIC ASSY. THAT is mounted in the left door and takes the paper right after it comes out of the fuser ;part is called (PAPER DIVERTER) And sometimes one of the FLAPS That routes the paper is broken,hence causing paper jam.
Posted on Aug 01, 2009
Throughout print job HP laserjet 9050 print will be squigly/flakey and not fuse to paper properly
when you replaced the maintenance kit - did you replace the Fuser assembly as well - as this faultr is down to the pressure off the fuser roller to fix the image also there are two blue tabs that set the fuser unit to letter mode(less Pressure) these can be accessed without removing the fuser and are accessible from the left door. ensure the levers are set to paper and not letter. if the fuser is still not fixing the image correctly then a new fuser unit assembly is required as fuser units are non servicable.
Jan 08, 2014 | HP LaserJet 9050 Printer
Installed new maintenance kit for 9050 printer. Trying to reset page count and now the printer is jamming error code 13.02.00.
No relate with paper jam & page count resetting. Might be maintenance not installed properly..Remove paper jams, restart printer,if error 13.20 appears check some paper/paper particles jammed.. 1. Print from manual tray.
A. If paper is jamming, check registration assembly, clean it,best method for cleaning is vacuum cleaner in this area. chk..
B. Take out registration assembly, check clutch gears, driving gears, solenoids..
2. Check pick up rollers are properly installed in tray 2 & 3..
3. Check PIU unit for paper jams
4. Check Fuser sensor flags.
To reset the counter: Hold enter button & switch on the machine, wait till display shows cold restart, scroll to reset maintenance kit with help of arrow buttons & enter. Printer restarts & counter will become Zero..
Jan 07, 2013 | HP LaserJet 9050 Printer
Take apart hp3005dn
Analyse what type of jam it is...based on that we can shoot the trouble.1. Paper is jamming before entry in fuser and its folds like curl in the cartridge area.. A. Fuser Teflon sleeve not rotating or slow rotation results media(paper)unable to reached the destination in specified interval. Replace fuser assm or Teflon sleeve.2. Paper jamming after fuser assembly crossed little bit ( approx 1-2 inch).A. Clean fuser out paper sensor, check sensor flag & flag spring located in fuser assm.3. Paper jammed after fuser crossed more than 6 inches..A. Check paper pick up roller warn out(tray1 or 2), check registration sensor located under registration assm.How to remove fuser assm: remove back door, see the snap shot...
Registration sensor location:
Pick roller roller tray 2 :
1_9_2012_3_54_49_pm.jpgPl try it carefully..Best of luck...
Jan 09, 2012 | HP LaserJet P3005n Printer
13.01.00 Jam in Tray 2 error when no jam exists
Check Tay2 paper sensor flag, located at tray2 pick up roller, its its stucked shoot the fault
Mar 24, 2011 | HP LaserJet P3005 Printer
My print write error 59.30 how I will fixe that?
1st try reseating the fuser. 2nd replace the fuser motor. 3rd replace the fuser
59.3 = abnormal fuser motor start
Sep 28, 2010 | HP LaserJet 9050 Printer
Not fusing
Make sure the two blue levers are in the down position on the fuser. If the problem persist try another fuser .
Apr 03, 2009 | HP LaserJet 9050 Printer
Bad fuser Laserjet 3380
hii..
is u 3380 fuser fixing film ok...if ok try to change presure roller..it below fixing film....you can take out the fixing firm or presure roller.just check the size only.if same u can combine it.
2.try to clean paper pick roller at 3380 printer..
Nov 11, 2008 | HP LaserJet 3380 All-In-One Printer
Manual Feed Gets Jammed
It might be the feed roller. Sometime its the roller or the clutch if it isn't feeding.
Jun 12, 2008 | HP LaserJet 5200tn Printer
HP LASERJET 4250n PRINTER-PROBLEM WITH PAPER JAMS AND "FUSER ERROR"
Put a maintence kit in your machine, easy install, everything just clicks in, Every 200 000 prints it should be done, it includes the fuser, all feed rollers, sep pad and transfer roller.
These are great printing machine, they only ever need the MK and on this model a fuser drive gear wears and get noisy, but once that has been done once, it is ok from then on.
KIts seem expensive but they are meant to last 200 000 prints and usally do. These are one of the best most reliable printers in the market.
fee693c.jpg LINK to part info
Jan 09, 2008 | HP 4250 Monochrome LaserJet Printer
HP LaserJet 9050 Printer Logo
1,197 people viewed this question
Seeker5211
Seeker5211
