Question about Black & Decker 19" Electric Lawnhog Mulching Mower with Rear Bag
I started mower in tall grass. It started up and immediately stopped. Could not get it started. Replaced battery. Charged 12 hours. Still will not operate. Green light is on. Noticed the blade seems to turn too easily if I spin it manually.
  • 1,000 Answers
After charging the mower, you must place the safety key in the mower before it will start. On models that have a bail handle, be sure to pull the bail handle back to the mower handle before engaging the start lever. If your mower still does not start, remove the safety key and ensure the bail and start lever are in the "off" position. Then firmly re-insert the safety key, pull the bail handle to the mower handle and engage the start lever.
Note - It is important that the bail and start lever are returned to the "off" position before inserting the safety key.
Give it try, if it still will not operate you may have to take it in for service.
Good luck, let me know.
Regards,
Posted on Jul 30, 2009
Tucomse moer 5.5 Won't speed up when cutting tall grass.
These push-mowers have a limited power, when you hit tall grass there is much more resistance on the blades. Even higher power riding mowers can stall on tall grass.
Aug 04, 2015 | Garden
Yardman 38" 7160 the deck belt is loose
Have you been mowing high grass, and how long has the belt been on? if you have mowed tall grass or belt is older than 2 years old it needs replaced, most don't realize how much a belt stretches from mowing tall grass. I hope this has been helpful.
Sep 27, 2013 | Husqvarna Lawn Tractor 48" Deck, 23 Hp,...
Model lv195ea
There is not a governor on newer mowers. Ease mower thru grass slowly, if starts to slow down stop, let mower speed up. In tall grass only use 1/2 of the deck width with side discharge open. Ensure spark plug is clean and gapped properly, replace once a year. Ensure air filter is clean, replace once a year. Ensure oil is full. 30w oil. Always use Stabile in gas. Use carb cleaner and clean outside of carb to ensure choke lever is free to rotate.
May 09, 2013 | Toro Garden
LT1000 cranks but won't start
check to see if you lost spark if not spray starting fluid and see if it fires that will tell you if it's a fuel prblem
May 21, 2012 | Craftsman 17.5 hp 42 in. Deck Lawn Tractor...
I tried to mow the grass even though it rained this am. our grass was really high and i saw a little smoke come out of the lawnmower. is that because the grass was still a little wet or the grass was...
Nope. If the grass is too high, knock it down to size with a weedeater first. These electric mowers cannot handle the tall, high stuff. If you do, you will surely burn it up.
Aug 14, 2011 | Black & Decker 18", 6.5a Electric Mower
Husqvarna YTH20K46
Is this the first time cutting grass with a lawn tractor?
How tall of grass?
Use the grass cutting heigth adjustments on the tractor to a higher setting when cutting tall grass. Cut again to a lower height setting on the second pass. Grass higher than your tractor is not good for your tractor. Follow the manual instructions for best results.
Jun 27, 2009 | Husqvarna 23 Hp 48" Deck Yard Tractor
Bog when trying to mow
you are cutting to much grass & it isn't kicking it out fast enough out of deck which will bog it down it might help if you clean out the bottom of the deck & also dont cut really low if grass is really tall also cutting wet grass will aslo cause the bogging if i can further help e-mail me wade at wadembly@aol.com
Jun 26, 2009 | Garden
My Toro mower is 7 yrs old. 3 speeds, blade
I've noticed that when the blade get dull it work harder a cutting tall grass. I just put a new blade on mine and now it runs and sounds like a brand new mower. also if the inside of the deck is coated with old grass that makes a differance too
Jun 23, 2009 | Toro Lawn Mower With Toro Power Tools
Motor has low torque
common complains for electric & cordless mower is that they are not ment for cutting on wet or dump grasses or long tall grasses they will bog down. for this type of unit blade should be extremely sharp. also clean the under the deck so you can better air flow for the blade. if your switch & rectifier are new & in right connection then have you armature check for short circuit..
Jul 27, 2008 | Black & Decker 19" Electric Lawnhog...
Black & Decker 19" Electric Lawnhog Mulching Mower with Rear Bag Logo
328 people viewed this question
Top Black & Decker Garden Experts
Jim Parker
Jim Parker
Simon Elder
Level 1 Expert
Are you a Black & Decker Garden Expert? Answer questions, earn points and help others
