Question about Technics SL-1210 Turntable
Basically, have just bought 1210's mark 5's one of them, the tone arm makes the Brand New cartridge skip when it gets to certain points, its because the tone arm sort of swivels, like something is not tightened properly./. Please help :-x
    Problem Solver:
  • 5 Answers
I have this case now, i bought some mk2's. If u have a record that is single sided, put the side that dosent play on the slip matt, put the needle on it...add more weight if needed. it should stay where u put it, if it dosent...then it should be a case of moving the anti-skate, untill you are satisfied that it is not moving anymore. If u dont have a record like that, like i dont....i took the stylus off...and the slipmatt off...and let the cart run on the platter at 33, i hope it helps your problem, if i dosent then i would take it to a technician.
Posted on Aug 13, 2009
My brand new audio-technica AT-LP60 turntable has skipped on every single record I've played in it (even brand new ones). Always happens at the same spot - towards the end of the record, halfway...
hi,
Do one thing adjust counterweight on the back of the arm to 1.5gm or 2gm by rotating the counterweight. It will give some more pressuer on the styles and will avoid the jerking
ok
Aug 04, 2011 | Audio Technica AT-PL120 Turntable
1210 tone arm won't stay down. When I unscrew the
Check the point where the arm piviots, maybe a screw has come loose. Depending on the type of cartridge it should track at 3 to 4 grams.
Jun 08, 2011 | Technics Audio Players & Recorders
Tone arm skipping records.
The anti skate adjustment. And if you scratch @ all....move the weight all the way in and take off the little extra one that screws in on the back. Also a great tracking needle is a M44G.
Mar 03, 2010 | Technics SL-1200 Turntable
Sears Tape deck/Turn table skipping!
Hi the pennies will mess up the stylus. There should be an anti skate setting at the back of the turn table, a round adjustable bit with numbers, increase the anti skate and then use the balance weigth (weight right at the back of the arm that turns to get the weight right. Set the anti skate with the tone arm light, then increase the weight a bit. Hope that helps
Jun 14, 2009 | Technics SL-1210 Turntable
Tone arm trouble i think???
this is a damaged tone arm bearing i had this problem with mine and had no choice other than spending £50 on a new tone arm
Mar 08, 2009 | Technics SL-1210 Turntable
Arm does not track properly but skips across records
Just guessing, but it sounds like you haven't counterbalanced your tone arm.  When a tone arm skips, it's usually because there's too much counter weight on the rear of the tone arm.  You want between 3-5 grams, but first you have to calibrate your tone arm (balance it so you know where zero is).  If you don't know how to do this, refer to the Ion directions called "Tonearm Setup" in the instructions.
Jan 03, 2009 | ION Audio iTTUSB Turntable
1210 Constantly Skipps
More than likely your tonearm is damaged. There is a small screw towards the rear of the tonearm. If you loosen this it may solve your problem. However, please be careful, because once you adjust this screw, it is very hard to get it right. That screw is known as a 'conical' screw, and has a cone shaped tip. This tip sits on top of 4 very small ball bearings, which are held in place by a very thin piece of sheet metal. If any of these are damaged, you will have to replace the tonearm. If they are not damaged, and your conical screw just became misaligned, then it is possible to salvage your tonearm. However, be very careful when turning this screw. Turn it counterclockwise very slowly, about a hair of a turn... yes, I said a HAIR of a turn. Then put the needle back on the record and observe what happens. If the problem persists, turn it a little bit more. Keep doing it until the problem is solved. You will eventually have to have the tonearm replaced, as this screw will start to loosen over time, once it's been adjusted.
- OPTiC
DJ Pro Audio
www.djproaudio.com
www.1200s.com
www.repairnyc.com
Jul 27, 2008 | Technics SL-1210 Turntable
Re:
Hi Vat,
Although I live in Canada now, I was born in the former
Czecholsovakia. While I spent a year in the Czech Republic in
2006, I was amazed how advanced their technology was, in
comparison to Canada or the US. If you want modern technology,
Prague is the place to go. Anyway ...
1) As I said before, do NOT adjust the tone-arm weight up
and down. This setting must be set to match the stylus and
the cartridge !!! The wrong setting is very bad.
To get the weight adjusted correctly, do the following.
a) Check the cartridge and stylus (needle) specifications, on
the WEB if necessary.
A typical tracking weight is between 0.9 grams to 1.5 grams,
but this very much depends on the needle geometry. To much
weight will damage the needle and the record, but
so will too little, because the needle will not stay on the
surface, skipping or mistracking on loud passages.
Note that the tracking acceleration is proportional to the
the square root of the loudness, multiplied by the frequency
squared. So if the tracking force is too low, the needle will
bounce over high frequencies and damage the record as
well as the needle's tip.
2) Once you know the correct force for your needle, adjust
the rear weight for ZERO force, such that the needle just
floats weightlessly in the air. If your turn-table has an anti-
skating adjustment, set that to zero as well.
3) At this point the tone-arm should be totally weightless,
and should neither touch the plater nor swing up/down
by itself. It should float halfway.
4) A this point, adjust the rear weight's dial (not the weight) to
read zero. Note that the dial will slide, while you hold the
weight still. You have now calibrated the tone-arm's zero
point.
5) Now, adjust the weight (with the dial) to read the desired
tracking force, for example 1.25 grams.
6) Now adjust the anti-skating dial to the same number as
the rear weight. This setting compensates for the radial
(towards the center) component of the friction vector,
caused by the needle riding on the record groove, at some
specific (average) tone-arm angle.
7) Your tone arm is now balanced, and you should not
touch it after this, accept for minor adjustments.
For brand new records, you may lighten the tone-arm
by 10%. For old records, you can make it a little heavier.
Similarly, you can adjust the anti-skating to prevent a
record from skipping, but a bad record should be played
only once (and stored on your computer).
8) For some tone-arms and cartridges, the cartridge pitch
(up/down angle) is also adjustable. This requires a special
jig or gauge, supplied by the cartridge manufacturer.
The pitch can be adjusted either by the use of screws or
wedges, and by lowering / raising the rear gimble. On my
Technics SL 1200, the gimble elevation is adjustable with
a large ring, and my SURE V15 cartridge came with a guage
for adjusting it correctly.
9) It may also be possible to adjust the cartridge's yaw and
radius, but all of these adjustments should only be done
using the correct gauges and by strictly following the
cartridge installation manual.
10) NONE of these adjustments should effect the tone-arm
cueing or return process. There should be plenty of
clearence if the cueing mechanism is working properly,
except, perhaps, for the gimble elevation, if the cartridge
is unusually tall.
11) Is the cuing mechanism (i.e. the tone-arm lifter)
mechanical or hydraulic ?
Is it the lift consistent or does the tone-arm drop down
with time?
Does the tone-arm move parallel to the plater, or does the
stylus height change with tone-arm position (yaw)
You are looking for a mechanical defect in the cuing
mechanism.
12) How much over all lift do you get between the down position
and the up position? This should be at least 8 to 15mm
If the cuing mechanism is worn out, it may not move enough.
If it starts too low, it may move enough but not raise the
needle enough to clear the record.
If the cartridge is tracking too low, you may have to
remove some wedges or spacers between the cartridge
and the head, or lift the rear gimble if it is adjustable, or
get a different tone-arm head, that matches the cartridge
profile.
Finally as silly as this sounds, make sure that the
platter is fully dropped and properly engaged. If the
plater is too high, for what ever reason, this would also
cause the needle to drag.
Also make sure that the rubber mat on the plater is the
right one and that it is not too thick.
Martin
Jul 02, 2008 | Audio Players & Recorders
1210 mk5g tone arm pin stuck
Hey raz, i've just taken apart and put back together my turn table trying to cure the same problem. I DIDN'T NEED TO!!!!
number 1) i think the tone arm is a sealed unit so far as i can gather so if the spring is broken you need a new tone arm. however. Get a cotton swab, soak in malt vinegar and use this to gently push the faulty contact in. The idea behind this is to get vinegar around the contact shaft. This should dislodge the dirt and release the contact.
Dec 18, 2007 | Technics SL-1210 Turntable
Technics skipping
hi fletch83.
this could be the tone arm bearings too tight,damaged or in need of a little oil.
i had a similar problem on my 1210, it kept jumping all the time,ruining my mixes! it turned out it was the bearings too tight.
unscrew the counter weight so that the arm hovers over the platter and move it to the centre with anti-skate on zero.
slowly turn the anti-skate round to three and the arm should move over to the arm rest smoothly,if it stops before the arm rest or isnt smooth theres your problem,loosen the bearing adjuster slightly and try the hover routine again until its as smooth as you can get it. it is possible,if the turntable has been transported without dust covers the bearings or the pin could be slightly damaged from knocks on the top of the tone arm assembly.
let me know how you get on or if you need any more help.
darren
Oct 10, 2007 | Technics SL-1210 Turntable
Technics SL-1210 Turntable Logo
90 people viewed this question
Top Technics Audio Players & Recorders Experts
 Grubhead
Grubhead
T-Comtech Repairs
T-Comtech Repairs
Electro Med Services...
Are you a Technics Audio Player and Recorder Expert? Answer questions, earn points and help others
