Question about Boston Acoustics MicroMedia Computer Speakers
My husband disconnected our wires from the computer and put everything back (I thought ) now, we have no audio?
  • 3,267 Answers
Most probably the speaker jack is in the aux. port. Also check under systems----device manager to see if it recognizes the sound and has the adequate drivers for it...........sodeep
Posted on Jul 30, 2009
Air bag lght came on after my husband pushed the passenger side seat back, it stays on after a few seconds of flashing
If you are certain this light only illuminated after your husband moved the seat, then he may have disturbed a wiring loom, or a crash sensor beneath the seat.
- Disconnect the NEG (-) battery lead and wait for 5mins (this will disable the Airbag circuit & reset the computer).
- Look under the seat for any wiring looms - ensure the connectors are tight and secure
- Also look under the carpet, for a crash sensor (small square box) and if found, ensure the wire connections are tight and secure.
- Once you are happy everything is ok, reconnect the battery lead.
If the Airbag light comes back on after a few drive cycles, then you will need to have codes read from your vehicle's computer (your local dealership can do this for you) which takes about 15mins.
The fault codes will identify which component/s within the Airbag circuit is causing the issue.
Good luck.....
"If this solution has resolved your problem, please be kind enough to leave a testimonial"
Jun 08, 2011 | Chevrolet Equinox Cars & Trucks
Hp c4180 paper went halfway in cant pull out how open the back or get paper out
-disconnect the power cord from the back of the printer while it is turned on. -remove the back door and take the paper out from there -do not take the paper out from the front as it may cause damage to the rollers
May 27, 2011 | HP Photosmart C4180 All-In-One InkJet...
At first my front right hand turn signal wasnt working. my husband thought that the bulb burned so we bought one..but when he went to change it he noticed it was the wrong one..and also when he lifted the...
Not expensive, Go back under the Hood and compare the wiring positions on the Left hand bulb to the RH. If this is all correct, then check the Ground connection of that lamp. When the Headlights are ON, the RH turn signal, is tacking a Ground from that Headlamp.
Good luck. DT
Mar 01, 2011 | 2001 Mazda MPV
Tell me how to reset the cd player on model # cdx-gt420ip. I can't download the manual on my computer.
pop out the front of the stereo and there's a small reset button around the middle of the part that's still attached. get something somewhat sharp like a pencil to press it with. that should reset everything but if it doesn't work you can take the whole thing out and disconnect the wiring harness and wait about a minute. then plug it back in and put everything back. that will reset everything too.
Sep 12, 2010 | Sony CDX-GT420IP CD Player
199 Mercury Cougar
my husband just uses his finger nails to lift up the switch. Ours has failed multiple times and we purchase 2 at 65-70 dollars a piece from the dealership. Don't waste your money, its not the switches. It is the wiring to the switches. After trial and error, my husband pulled the wiring up thru the switch hole and seen that the wiring was loose on the back of the wiring harnes. so he tightened everything up, and wah lah. Save ourselfs $$$$. Make sure to disconnect the battery before working with any electrical components.
Jun 26, 2009 | Cars & Trucks
Speakers not working, but cables all plugged in...
You might have to reinstall the software that came with the speakers since you had to wipe your computer clean when the virus was on there. The speakers will not work until the software is installed back on your computer.
Oct 21, 2008 | Logitech S200 Computer Speakers
E-Machine Mother Board Connections
Find the company, and name of the board, and look that up. Computer manufacturers could use any number of different boards. You need the specific manual to that board. The manual should explain where the connections go. Sounds like you have the LED HD and POWER ON LED disconnected.
Sep 28, 2008 | ASUS A7N8X-E Deluxe : ATX Socket A FSB400...
Kenmore model 525321 overheat problem
hi thanks for the question after your husband replaced relay & overload if the compressor started & kept on running but no cooling you have a bad compressor
Sep 13, 2008 | Kenmore 55612 / 55614 / 5561 / 655619 Side...
Computer crash no sound
check the printed circuit board, check for cut lines
Dec 14, 2007 | HP Compaq FS 7550 17" CRT Monitor
Speaker issues
Disconnect whatever wire is connected to the blue wire behind your head unit. Re-connect it to the blue/white wire, instead.
Jun 21, 2007 | Sony CDX-M770 CD Player
Boston Acoustics MicroMedia Computer Speakers Logo
129 people viewed this question
Top Boston Acoustics Audio Players & Recorders Experts
 Grubhead
Grubhead
Steve
Are you a Boston Acoustics Audio Player and Recorder Expert? Answer questions, earn points and help others
