I have no idea. Recommend contacting a local car audio professional or Clarion customer support directly here:
https://clarion.com/xe/en/user-support/inquiry/contactus
https://clarion.com/xe/en/user-support/i...
The problem is... Eric Cook,
Lead length is of PARAMOUNT importance
when popping off DIRECT CURRENT Amperage
advice...
If a TECHNICAL ADVISOR here just TOSSES a wire
gauge UP-IN-THE-AIR for you without any NOTION
of what vehicle... What source... What physical
protection you are providing for any UN-FUSED
power sources (feeds)... & SPECIFIC LENGTHS
They are INSANELY NEGLIGENT...
(or I would be CRAY-zee (bat guano)).
All unspoken... yet hideous opportunities
for incredibly EXPENSIVE work errors.
Just a QUICK look at the DOCUMENTS you
most likely have (right there at your finger tips)...
SEZ "less than 15 Amps"... (check the specs)
Clarion DXZ655MP Owner Manual Specifications
I actually don't understand...
You are HAND-BUILDING a car from SCRATCH...
Or the "vehicle" came with a RADIO... BUT you
are OPTING to STRING a (likely) unfused
power wire ...
Build your own ... but be advised: Not smart
to consider lengths in anything but linear feet
of wire USED..
(CROWS distances are dangerous (see chart)).
12 Volt Wiring Wire Gauge to Amps
(((think fire, exploding air bags & petroleum))).
I'm just saying...
Carnac the Magnificent
SOURCE: Need wiring diagram of connectors for Clarion
you can usually go to the site and put in the model # and request owners manual. it is in there but you need to have adobe reader.
SOURCE: i have a clarion dxz655mp and i need the wiring
Wiring diagram for the internals...you're out of luck. Wiring for hooking it up in a car...Go to a car stereo shop and buy a wiring harness for your make/model of car ($25-35). or crutchfield.com
Good Luck
SOURCE: CLARION CAR STEREO WIRING DIAGRAM
Here's the wiring diagram for the DB245 - not from Clarion's site, but this is it...
http://723634aa8cde73188d4661bb3fe81ce4.diplodocs.com/external_download5.php
If that link does not work, here's the page that should get you to it, but you need to provide a rating on the page before it activates the download link.
http://safemanuals.com/314159.php?k=faea99c148e033a6ced0caaa53759ea0&ID=109111&q=CLARION%20DB245%20INSTALL
The picture wiring diagram is found on the right-hand side of Page 2
I have not been able to find this installation manual anywhere else(including Clarions site), so this is about your only option.
SOURCE: need wiring diagram for dxz635mp clarion car
yellow battery
black earth
red accessory
purple right rear + speaker
purple/black right rear -
green left rear +
green/black left rear -
white fr left +
white/black fr left -
grey fr right +
grey/black fr right -
blue auto antenna
blue/white rem amp
brown phone mute
orange/white illumination
pls rate cause people havent been rating hope this helps
