Question about Drills
How to fit drill bit to drill - Drills
  • 74 Answers
It depends what chuck (the part the drill bit goes into) on the old ones you had a chuck key that slots into the hole on the side and connects to the teeth to tighten the chuck around the bit, keyless chucks are tightened by hand instead of the key and the SDS have a collar that pulls down, you have to turn the bit so it then slots in then just release the collar to fix it in place good luck!!!
Posted on Jul 30, 2009
How to get my ignition lock out
Instructions
Test fit a drill bit in the lock cylinder. You want a bit that is just smaller than the cylinder. You will be using hardened drill bits to cut through the cylinder, since ordinary bits may be damaged by drilling metal.
Lock the drill bit into the drill chuck and tighten the chuck.
production in very fast delivery! special threading taps, plug gauge
Drill a starter groove into the lock cylinder. Start the drill on a low speed and create a groove in the end of the lock cylinder. You don't need to create a deep hole, just enough of a groove so that the drill bit will not slip on a higher speed.
Increase the drill speed to the highest setting and drill out the lock cylinder. Let the drill do the work. If you force the drill into the lock cylinder, you could burn out the rotor inside the drill motor
Jul 10, 2012 | 1999 Pontiac Sunfire
How to use?
It is used to check either the size of a drill bit or to see what size fastener you have and decide what size bit to use. Just insert a bit or fastener into a hole. It should fit snugly and if it doesn't fit the next smaller sized hole then you now know what size you have.
Feb 17, 2012 | Starrett Jobbers Drill Gage Gauge No. 187...
Need a chuck key for model 1140b,f powermatic drill press,manual part number 6285469.
There are only a few sizes of chuck key. Easiest thing to do is first find a drill bit that fits in the hole where the key goes to determine the size of the pin on the end of the key. (Use the back end of the drill bit.) Then take any other chuck key you have and see how closely it fits or doesn't fit - just as a reference. Take the reference chuck key and the drill bit with you to Sears or any place that sells a good assortment of tools. You will probably be able to determine the correct size key from what they have available very easily. Good luck, Al K
Mar 14, 2011 | Powermatic 1140 B,f 14 " Drill Press...
I received my LWG151P yesterdat and I am having problems with assembling the safety guard. It does not fit, it appears to be about 1/4" too short and the hole does not line for the screw to fit. Any...
If you can, just mark and drill out the guard with a powered drill and drill bit (not too big) in the correct location for the screw(s) to fit. When in doubt, just drill it out! Plastic or metal guard....doesn't matter....a steel cutting drill bit will go thru both. Sometimes drastic engineering flaws cause for drastic solutions.
Aug 27, 2010 | Worx 10" 18v 2 In 1 Grass Trimmer/In Line...
Have a skil 597 T8 thats lost its grip - is it neccy to change the chuck - and if so can I replace the chuck with one that can open far enough to accept some larger bits?
I couldn't find your particular drill model drill. If this is a corded drill with a 1/4 inch chuck, you would do better to just buy a corded 3/8 drill. But otherwise, yes, change the chuck if you can find one to fit at a reasonable price. Drill chucks are sized to hold a straight bit of the maximum hole diameter that the drill has enough torque to drill into mild steel. If you find a larger one that will fit on your drill, it will work fine, but if you overload it you will burn it out. If you don't drill into steel with any larger bit than the original chuck, then this won't be a problem.
Jun 29, 2010 | Skil 3/8IN DRILL CHUCK/KEY
Will the bits from the te-c3x fit my te-17
Yes. New bits will fit old Hilti drills. Old Hilti bits do not fit the new (last 15 years) Hilti drills.
Apr 07, 2010 | Hammer Set Of 6 Hilti Te-c3x Drill Bits...
How do I fit drill in this machine please? DEWALT D25113K D25113 3 MODE SDS
Youcan only use standard drill bits with the use of a chuck attachment with the SDS type bayonet. These hammer drills use an SDS type drill bit which just pushes into the fitted chuck and are released by pulling back on the lock mechanism on the chuck.
Jan 19, 2010 | Dewalt D25213k D-handle Tri-mode Sds+...
Bit or chuck type for a Skil 717 hammer drill
I have a Skill 717, too. It has a hex shank. Here are a couple places that I've located that carry (some) parts:
www.icscuttingtools.com (pages 155 & 157)
www.bamanufacturing.com/page_15.htm
also try:
www.ereplacementparts.com
www.toolpartsdirect.com
Sep 12, 2009 | Skil Drills
Ryobi impact drill compatibility with normal drill bits
Round bits are not compatible with the Ryobi impact drivers. You need the hex shank "quick connect" bits and accessories. There is an adapter available. it is basically a regular style of keyless drill chuck with the quick connect hex shank that should fit right in to your Impact.
Apr 10, 2009 | Ryobi 18v Variable Speed Impact Driver...
Porter cable 884 cordless drill
Most chucks have a tolerance the cordless drills where designed for drill bits 1/8 and larger the 3/8 chucks are a little better with the smaller bits .Check your owners manual and see if they have a min requirement listed for the bit size
Sep 27, 2008 | Porter Cable Cable 19.2 Volt Grip - To -...
Drills Logo
507 people viewed this question
Top Drills Experts
Are you a Drill Expert? Answer questions, earn points and help others
