Question about Dell Inspiron 530 Desktop Computer
Solid Amber light when starting the Inspiron 530 . Every time i start the Dell inspiron 530, the solid amber light comes on and it dont start. As per Dell user manual i have tried everything but of no use. As per manual it is related to power supply issue. any Help??
I have a Dell inspiron 531s had amber light and internal fans running, I replaced processor and fixed the problem. The computer is running fine.
Mike
Posted on Jan 04, 2013
    Problem Solver:
  • 8 Answers
Amber led simplifies a start-up-error. This could be a number of things.
For example:
Check if HDD is connected properly
Check if RAM is connected properly / also if this is damaged your pc wont start.
Check your m/board for any loose capacitors an if they are not popped at the top.
Your LCD screen is properly plugged in to the m/board and if the cables aren't damaged they are very thin and fragile.
also could be the power supply...
Goodluck
Ryno Gerber
Posted on Jul 30, 2009
My dell 545S will not boot up it blinks amber for about two minutes then turns solid amber and the funs(all three) run but will not start!!!
If you are not getting any beeps its either the powersupply is back or the motherboard is bad. You can try replace one at a time
Aug 11, 2014 | Dell Inspiron 535s 537s 545s 546s 560s...
When i turn on my Dell Inspiron 2400 Desktop Computer why won`t it start.
Is the computer plugged in to a known good power source with a known good power cord? Also, make sure the power is fully seated on both ends. When you press the power button are you getting any indicator lights? The power button itself has an LED that will be either solid green, blinking green, solid amber, blinking amber, or off. Do you hear any beeps?
May 19, 2014 | Dell Inspiron 530s Desktop Computer...
Dell troubleshooting
Most likely there is something wrong with either the motherboard, cpu, or RAM. Check out the troubleshooting steps at:
http://bit.ly/ZRBZvZ
Jan 28, 2014 | Dell Inspiron Computers & Internet
Dell insprion 530s won't start up just amber light on the motherboard comes on
hello, you will have to remove power cables, and leave for a while then reconnect it and try again. check out my blog for more tips ;
http://diyshelf.blogspot.com/
Oct 18, 2012 | Dell Inspiron 530 Desktop Computer
I have a Dell Inspiron 530. It will not start. Fans do not operate. Green pilot light on PSU is on. Amber light on mother board is on. Power button is glows solid amber.
First ,change the Fan,it can be heating problem...and also check the other hardware portion....
If you need any kind of technical assistance, you can contact support cell at http://www.vtechsquad.com
Sep 12, 2012 | Dell Inspiron 530 Desktop Computer...
My desktop (inspiron 530)started beeping (6 short beeps)when it restart or shuts down; it will do the same when it reboots itself. Now, it will do the same beeps but it won't pass that stage. I also...
HI,
The 6 beeps on the computer suggest a video card BIOS failure.
If you have an add-on video card on the computer . Trying removing the same and then restart your computer. If the the video card is on board on the motherboard. Then the motherboard would need to either service , that would be expensive,or get the motherboard replaced.
Thanks
Proton
Sep 27, 2010 | Dell Inspiron 530 Desktop Computer
Solid amber light ON Dell Inspiron 530 desktop.The Fans start and stop immediately.The mother board has the power ON Amber light.
The Yellow Light of Death, anyway turn on Your PC, as it starts You will here some beeps especially on a Dells. Count the beeps , there will be a slight pause so it will beep once then pause then beep again. Count the beeps and that will be Your code. Go to Dell Support site and look up code. Most of the time a Yellow amber light means that there is trouble with Your Motherboard but thats not to say its the Motherboard itself, it could have possibly burned out Your RAM, Processor, Heat fan, even the power supply itself. So look up the code and at least You'll have a better chance of finding the solution, Good Luck
Mar 04, 2010 | Dell Inspiron 530 Desktop Computer
When I take the computer out of the standby mode
Try this:
  1. Update the BIOS and Video driver to the most current on http://support.dell.com
  2. Disable the screen saver
  3. Enable HIBERNATE instead of standby in Power settings, set the LCD to go off in 10 minutes, HDD to 15 and Hibernate in 20.
Select Shutdown, Hibernate
then try and restart
If no GO, disconnect all peripheral items except KB
Try hibernate again and restart.
If all works OK, add items back one at a time till you find item causing issue. If no go, replace power supply if issue still occurs, replace MB
Oct 13, 2009 | Dell Inspiron 530 Desktop Computer
Computer locking at startup
If the LED is glowing Amber then there is definitely something wrong with the hardware. Open up the system and check to make sure that all cables are plugged into the motherboard securely. If they are, you have faulty hardware somewhere. I would take it into a repair shop and see if they can locate the fault.
Please rate,
Thanks!
Apr 02, 2009 | Dell Inspiron 530 Desktop Computer
Dell Inspiron 530 Desktop Computer   Logo
2,466 people viewed this question
Alun Cox
