Question about Grandstream GXP-2000 IP Phone
Trying to set the gxp2000 with 3cx pb x - Grandstream GXP-2000 IP Phone
  • 339 Answers
Here is a step by step that is very good:
http://grandstream.com/support/gxp_series/general/documents/gxp_interop_3cx.pdf
If you have any more specific questions, please let me know in a follow up. I just set up a 3CX system with these phones last month and it's pretty fresh in my mind.
Posted on Aug 28, 2009
69,tiger 200. Went to kick start and it's seased up, been setting for 18 month s. Should I poor oil in plug hole and let it set? I know with these type of engines may not be a good idea.
Hey Rick,
i would use a squirt of two things... A good shot of PB Blaster to break it free and the WD40 to aid in wicking around the rings (which is what is really stuck) into the spark plug hole.. and put the plug back in.. wait 24 hrs.. try to kick it,, if not kicking..repeat the spraying...wait 48hrs.. IF the piston is stuck, it will break free.
Once you get it running...change the oil immediately!!!
Blaster PB Penetrating Catalyst Penetrant Walmart com
WD 40 Smart Straw Spray Lubricant 10 oz Aerosol Can 6 CT Walmart com
Jul 06, 2017 | Motorcycles
Key wont turn
Try spraying some PB Blastor directly on the key before inserting...also spray with the fine tube a little PB Blastor into the ignition switch...this is safe for electrical parts...wiggle and retry...Your local locksmith can replace the key switch for you...the air bag usually prohibits self repair...:( You can buy the PB Blastor at Walmart and auto stores...
Jun 04, 2014 | 2000 Oldsmobile Bravada
Hi I've got an all in one PB one two M, with
YOU MIGHT CHECK WITH TECH SUPPORT FOR THAT DEVICE AND GOOGLE THIS DEVICE FOR ISSUES OTHER MIGHT BE HAVING YOUR SAME PROBLEM(S)...?WITH AND YOUR MANUAL MIGHT NEED TO BE CHECKED FOR SOLUTION(S)...?
Jun 14, 2013 | Televison & Video
How to set my grasslin pool time trying to understand to let it run in day and shut off at nite about 6pm so i need to set it that way with the pin
Open following link for setting Intermatic/Grasslin FM1 timer setting instructions:
To set the 24-hour analog timer, you need to move 4 consecutive tripper pins for each hour of run time.
So for 6 am to 6 pm, 48 trippers pins will be moved outward and 48 inward.
http://waterheatertimer.org/pdf/How-to-set-Intermatic-FM1-timers.pdf
Open following link for Intermatic FM1 series and PB series modular timers with wiring, manuals, model numbers and instructions for setting.
http://waterheatertimer.org/Intermatic-trippers-and-parts.html#PB
Add a comment for more help
Upvote the help.
And take advantage of fixya expert assistance live.
For a price, expert works with you while you work on timer or any do-it-yourself project.
Fixya is always less expensive than a service call.
Jun 08, 2011 | Intermatic FM1STUZH-120U - 24 Hour...
I have no signal with the video component (Y, Pb and Pr)
You may have to set-up the DVD player for component (Y,Pb,Pr) output instead of S-video. You may have to set DVD player to progressive-scan or 720p or 1080 video out, also.
May 02, 2010 | Cyberhome CH-DVD 300 DVD Player
Map loading impurient client files kikked out
Oh god, poor you dude. That's an arbitrary PB kick. That means PB believes your client file is hacked or some other nonsense. This is a PB problem, there is no fix, just try to reinstall your game and delete all your player profiles. This is one more reason to hate PB...
Mar 10, 2010 | Video Game Consoles & Games
Y/Pb/Pr outputs are green; needs
There is no calibration for the component video that I know of, check your cables you may have a bad Pr cable or the Pr/Pb ones may be mixed up.
Y (the green one) is for luminance, plug in ONLY this connector and you should see a black and white picture.
Now connect the Pr. You will now see red tones.
Now connect the Pb. And you will see blue tones.
Reverse the Pr and Pb and see what happens.
Oh and make sure you don't accidently have one plugged into a composite video or digital audio port.
Still not looking right?
Go into the input menu of the TV and change the component (or colourstream) input from RGB to Y/Pr/Pb. (most TVs do not have this feature.
Hope this helps!
Jan 24, 2010 | Samsung SIR-TS360 DirecTV DTV Receiver
Chranks hard,won't start
you need to adjust the valves with the cylinder 1/4 inch below top dead center to get the decompression lobe to function right during cranking.
Aug 07, 2009 | Garden
HDMI Cable problem
Well, first you might want to try another hdmi connection behind your TV.If it appears to have the same message,you need to check your TV setup and be sure the HDMI video is active.
Secondly,go with the recommendation of the set top box.You will use component video cable to connect from your set top box component video output(Y PR PB) to your TV (Y PR PB) and see if that actually work.If so,just use the cable box for the time being and call your cable company for another cable box to replace this one!
solutiondoct
Jun 13, 2008 | Samsung HP-T4254 42 in. Plasma Television
Mitsubishi WT-46809 Problem getting HD from DirecTV
I have the same exact problem. Same model, etc. Is there a resolution?
Sep 16, 2006 | Mitsubishi WT-46809 46" Rear Projection...
Grandstream GXP-2000 IP Phone Logo
214 people viewed this question
Top Grandstream Computers & Internet Experts
David Payne
David Payne
Dave
Are you a Grandstream Computer and Internet Expert? Answer questions, earn points and help others
