Question about NetGear DG834G Wireless Router
How doI make wireless modem secure - NetGear DG834G Wireless Router
  • 1,272 Answers
Hi, Follow the steps below to enable security on the wireless modem:
1. Open the browser (Internet Explorer, Mozilla Firefox or Safari) on a computer connected to the router.
2. Access the router usually by typing 'http://192.168.1.1' or 'http://www.routerlogin.com' in the address bar.
3. Login to the router with the Username as "admin" and Password as "password" (please note that the Username and Password are case sensitive).
4. Click on Wireless Settings'(under Setup) from the left menu.
5. Select security options as 'WEP (Wired Equivalent Privacy)'. Set the 'Authentication Type' as automatic. Set the 'Encryption Strength' as 64-bit.
6. In Key 1 type a 10 digit number. Apply the settings.
I hope this information allows you to resolve this issue.
If I have helped you, please help me, and rate this suggestion with the highest FixYa rating. If you cannot rate this post with the highest rating, then please comment to this post and I will try to help you further.
Regards
Anand
Posted on Jul 30, 2009
FORGET THE PASSWORD
it should be written underneath the modem
Apr 07, 2014 | D-Link Wireless N Access Point Dap-1360 -...
I wanna protect my connection from outside users i dont know how to protect it !! please help me out!
You listed your problem ubder: modems. A modem you do not need to protect further. You can only use the connection by hooking up a cable to it. If you have a wireless router connected to your modem that should be secured. You do this by entering a security code in the setup of the router. just enter the router's IP address in your web browser, log in to it,go to the security tab under wireless setup and enter a security code. (write it down because you will need it to connect wireless). You can not connect to it without this code. This way your wireless connection is secured and can not be used by outsiders.
Feb 10, 2011 | Computers & Internet
I cannot find the security key on the bottom of my motorola surfboard modem
Contact your local Internet Service Provider for assistance with your cable-modem.
Or, if you have connected a wireless-router to the cable-modem, and now you are trying to connect a wireless-device to the wireless-router, that's where a "security-key" is needed.
Dec 20, 2010 | Arris SURFboard SBG900 (49402201900) Modem
MAKING A WIFI MODEM SECURE
Change the "settings password" from default password to a complex one. Next make sure u set the wireless security to WPA or WPA 2 and password protect it too. (to go to settings of your modem type 192.168.1.1 in internet explorer)
Mar 18, 2009 | Computers & Internet
Need to find security codes for 2wire dskl
When you say security code do you mean you wireless password?
Jan 04, 2009 | AT&T High Speed DSL Modem
Connect Wii via wireless router
The modems wireless feature is always on. For some reason entering the security code wasn't working so I turned off the security feature and it worked fine. After the wii downloaded updates I turned on the security to the most secure settings and everything continued to work. I guess maybe the wii update fixed the issue or I just needed to change to the most secure setting.
Jan 02, 2009 | 2wire (1000-000057-000) Modem
Interface
did you ever changed the default login? If not just google for router passwords and your model should appear. If you changed it and forget, you should reset the device.
Oct 23, 2008 | Toshiba Wireless Broadband Gateway...
Westell model 327w
you can run another ethernet cable from your westell modem to your laptop. hence, if you want your laptop to connect wirelessly, it must have a wireless card/adapter inside. if it already has a wireless adapter, it should automatically detect your wireless network and you just need to connect to it (note: you need to enter the correct wireless security/network key if you have enabled it on your modem). by default the serial number is the ssid of the router and the wireless security is disabled. but if you are not sure of your wireless security, log on to the modem's web user interface by typing http://192.168.1.1 on your web browser's address. then go to the wireless section and verify your wireless settings from there.
hope this'll help you.
ciao!
Aug 20, 2008 | Westell Wirespeed VersaLink...
Hi i had to do a recovery,now i can not get access to the internet through my wireless conection.when i try to, it ask me for security key or passphrase can you help me solve this...
Hi, u have to tell the fone model and alsorefer ur fone manual to reslove this issue.. the security key that ur fone is asking mite be the security that ur wireless modem has..so u have to use the same security code or key..u can c that security key of ur wireless modem by typing in the default IP address of the modem u have..it owuld be written in the manual of the WIRELESS MODEM aswell..if ur able to note that security key i.e the WEP key,u can try putting that key in ur fone when it asks for the security key..then lets see what happens.
Jul 14, 2008 | ASUS Cell Phones
Security code
if you are using a siemens 4100 modem alone.. siemens 4100 modem has no wireless capabilty unless there is a wireless router plugged in..
if you already have a wireless router.. the SECURITY CODE shud be provided by your wireless provider
REMEMBER: SIEMENS SPEEDSTREAM is not wireless capable
Jun 26, 2008 | Siemens SpeedStream Modem (4100) (SS4100)
NetGear DG834G Wireless Router Logo
1,079 people viewed this question
Top NetGear Computers & Internet Experts
Prashant M
Prashant M
Are you a NetGear Computer and Internet Expert? Answer questions, earn points and help others
