Question about Nikon COOLPIX S200 Digital Camera
Camera was dropped
Lens error appeared & tried to on/off many times. recharging battery now, but when i tried to force the lens the cover popped off. i have the pieces and think i could reassemble but would like a diagram to be sure, if available
This kind of small digital camera, their lens structures are quite compact and complicated. The lens are covered one layer by one layer, even if you can reassemble the lens glass into a whole one lens, you still need some very professional instruments(To my knowledge, OLYMPUS company makes these series of instruments, cause I work ed for OLYMPUS Microscopes over 10 years in China ) to accurate and test the focus founction is working correctly or not. So, it is not that simple as to just reassembing the lens glass.
Posted on Jul 30, 2009
Camera lens does not retract and shows camera error #e45
It appears that the error code is due to your lens being stuck. In many small digital cameras this is caused by a drop or jar to the camera and the lens being knocked off of its tracks. Make sure your camera battery is fully charged. Power the camera off. With the camera is laying flat on its back on a table or other level surface, see if the space or gap around the lens is an even amount. If not, it is probably out of its guide track. Holding one hand cupped, take the camera, face down and lightly strike it into the cupped palm of the other hand. That should dislodge any sand or grit. Then, holding the camera in one hand, grasp the lens gently and apply a light pressure toward the side with the larger gap around the lens. Do not apply a lot of force. Do this gently. If you hear a light "click" the lens should be back in place. Try powering the camera on to test the results. If it still doesn't retract, power it back off and lightly rotate the lens back and forth with you hand. Do not apply a lot of force! Again, if you hear a click, the lens should be back on its tracks. Power it up to test it. If that doesn't do the trick you probably need to take it to a repair shop or replace the camera.
Dec 27, 2014 | Kodak EasyShare LS743 Digital Camera
Dropped my camera and now lens stuck out and beeps and switches off
Hi
Do you get a E18 in the bottom left on the camera screen before the Canon PowerShot A95 switches off?
If you do see this error code then t
he problem could be because dirt or sand has got into the lens mechanism.
Firstly you should contact your local Canon repair centre and Canon may fix it for free. If this fails you can try the suggestions below, but you do so AT YOUR OWN RISK as this could make the problem worse.
Make sure the batteries are new or if you are using rechargeable batteries they are fully charged.
a) Remove the batteries from the camera, and unplug any USB cable. Wait for 5 minutes, then put them back in and switch the camera on.
b) Try using compressed air with a fine tip. Use between the lens turret and the camera body and turn on the air while moving the tip around the lens. It should remove any dust or sand. Turn the camera on and see if operates correctly.
c) Another, slightly unusual method is to gently tap the padded USB cover part on a hard surface. Amazingly this does sometimes work.
d) Lastly, you can try and force the lens back into the camera. With the camera switched off place the camera on a surface with the lens facing up - look at the spacing between the lens and the lens housing. If it is not even all the way around the lens VERY VERY GENTLY press down the lens on the side where the gap is the biggest. Hopefully you should hear a reassuring "click" as it pops back into place. Try powering the camera back on.
If these suggestions do not work then you are looking at a professional repair.
David
Feb 13, 2011 | Canon PowerShot A95 Digital Camera
I have a camera it's a canon S5 IS i let a friend borrow it he dropped it and now the lens won't go back in it says lens error restart camera i need help
Lens error occurred due to external shock, Now lens is prevented from properly extending or retracting.
1) Avoid applying pressure to the lens and surrounding area:
  • Do not touch Lens while shooting.
  • Make sure the camera is off before the camera is placed back in the case.
or..
2) Check batteries and make sure that they have sufficient charge, the batteries may need to be recharged or replaced. follow the instruction to resolve the problem.
  • Remove the battery and wait 30 Seconds & reinsert the battery, if your camera has a backup or date and time battery, remove this battery as well. Removal of the backup battery will cause a full reset of the camera and will clear any settings.
If this will not solve the problem your device need service (repair)
Rating the solution in highly appreciated....Good Luck
Mar 05, 2010 | Canon PowerShot S5 IS Digital Camera
Turn on camera,lens pops out,goes in/out focus reads lens error
If the camera has recently been dropped you may have lens damage that is preventing it from powering up. If it hasn't been dropped your problem may be due to weak/worn out batteries or corrosion on the battery contacts inside the camera which can prevent the full power of the batteries from flowing into the camera. Try this free fix before you do anything else: remove the batteries and wipe the camera contacts firmly with a dry cloth (heavy corrosion may require cleaning with a wire brush, steel wool, or sandpaper). Remove any residue that may have fallen into the battery compartment during cleaning, then wipe both ends of the batteries and place them back in the camera and give them a full charge (assuming that you are using rechargeable batteries). This cleaning clears the problem about 90% of the time. If it doesn't work for you, your batteries may need to be replaced or the camera may have a problem that requires professional repair.
Dec 15, 2009 | Nikon COOLPIX L18 Digital Camera
My camera won't come back on
the lens array has been damaged dude..you had either dropped it down or put it in you bag in switched on condition which should have forced the lens to get inside(resulting in damage).
please take your cam to the nearest service center to get it done, since it needs a pro and specialized equipments to calibrate to normal once it is opened..
if its covered under warranty you wont be levied on service charges, else it costs around 60$
Nov 05, 2009 | Kodak EasyShare M853 Digital Camera
Camera won't come on and lens doesn't retract
If you bought ni-cad batteries then you may have recharged them incorrectly and they do not have a good charge. Try fresh non-rechargable batteries.
If you bought ni-cads, buy nickel-hydride next time. They do not have a "memory" issue like Nicads.
I think the key here, though, is that it was dropped....
Jan 06, 2008 | Nikon Coolpix 2100 Digital Camera
Samsung camera power-on problem and beeping
same problem! camera HAD been dropped....carefully pull up with a gentle twist on the 'tilted ' side.
thanks for the tip! camera works fine!!
Oct 05, 2007 | Samsung Digimax S630 Digital Camera
So frustrating. Turn off and Turn on again.
There are two possible defective parts on your camera, is the lens cover will open upon power on? if yes, then lens cover motor is OK. if not its defective. Assumming, lens cover is OK, does lens assy pop-out upon power on? If not then, lens assy is defective, replace it. Thanks
Sep 06, 2007 | Sony Cyber-Shot DSC-S40 Digital Camera
Lens will not retract
In my case, there was dust in the switches that sense the cover movement.
  1. Close the sliding door and wait until the lens is drown inside (timeout).
  2. Open the screws that secure the front cover.
  3. Remove the sliding door covering the lens. There is no trick (hidden screws etc) so just use the force. The door is mounted by two-sided tape and adhesive.
  4. Remove the front cover. This is also mounted by two-sided tape / adhesive in the center, so you have to be a bit brave.
  5. The sliding door rails and the movement sensors are now visible. Clean all dirt.
  6. Try the door functionality.
  7. Mount the front cover after the lens works as it should. Close the screws.
  8. Mount the sliding door.
May 27, 2006 | Konica Minolta DiMAGE G400 Digital Camera
Nikon COOLPIX S200 Digital Camera Logo
178 people viewed this question
Top Nikon Cameras Experts
Steve
Jeff Marcus
Are you a Nikon Camera Expert? Answer questions, earn points and help others
