Question about GE WSXH208A Front Load Washer
Ge fornt load washer mod #wcvh6260fww the inner drum chatters violently in hi rpm spin-- not to be confused by the entire unit shaking-- the inner drum only
  • Mary Anne C May 11, 2010
    I may have a similar problem during the spin cycle. It makes a loud noise like something is loose or rattling around. When I take the front lower cover off to check the lint drain trap, there is black dust on the cover and the inside of the washer. Almost like some rubber or plastic pieces is disintergrating. Does anyone have any suggestions on what to look for or replace?
  • Anonymous Mar 12, 2014
    Spin basket has come loose
I'm having a similar problem. Mine sounds like there is something behind the drum, like maybe a coin or loose nut? It screeches horribly.
Posted on Aug 09, 2009
I am having a similar problem. When I remove the front lower cover, there is black dust on the inside of the cover and inside the machine, like something is wearing out or disintergrating. Is anyone else having this problem? What could be wearing out? In the spin cycle, it sounds like something is loose rattling around or hitting something as it spins.
Posted on Aug 02, 2009
WCVH6260FWW drum sticking
you have an item in between the inner and outer drums if you take the heater unit out you should now be able to see it remove it
Jan 10, 2014 | GE WCVH6260FWW
GE adora front load makes loud rattling sound in spin cycle. nothing in drum. sounds like a ball bearing
its the inner baskets bearings behind this basket as water gets past the rear seal into these bearings and ruins them,you need to dismantle the entire unit to remove the inner basket from the outer tub to replace these bearings
Oct 27, 2012 | GE WSXH208A Front Load Washer
GE WCVH6260Fww knocks during spin
Had the same GE model number and similar problem. The basket (stainless steel) doesn't look centered in the unit anymore, you can tell when looking around the perimeter of the basket and compare to the rubber gasket. On front load washers the basket (the stainless piece that spins), if the door is open and if you push up on the basket there should be very very little to NO play or give . Meaning the basket should not be able to move up, down, side to side (not talking about spinning, just north, south, east, west). If there is play or movement there is a very good chance (thinking 95% sure) that it is the bearing. Not good news for any front washer but GE in all it's wisdom set it's crack engineers out to design this unit so that the bearing is not an individual part, this design has the basket (THE ACTUAL STAINLESS BASKET), THE SUPPORT ROD AND BEARINGS AS A SINGLE PIECE. The "Basket Assembly" alone is between $550 and $650, before tax, before labor if you don't do it yourself. If you decided to tackle this yourself you have to totally disassemble the entire unit to replace it. No exaggeration, you literally have to take the entire outer tub assembly apart to replace. If you are able to accomplish this without damaging any other part then you have to Humpty Dumpty back together again, without damaging anything else. Hope this helps.
Nov 23, 2011 | GE WCVH6260F Front Load Washer
Violent spin cycle on the Frigidare front-loading washer
I assume you bought it new, so on that basis, did you remove the transit packing materials inside the machine ?
Front loading washing machine normal design is for the drum assembly to be supported by two or more springs at the top, and two dampers at the bottom. This allows the drum to move in a controlled fashion and also minimises vibration, particularly during spinning.
When the machines are shipped from the factory, transit packaging is put inside the machine to ensure that any shocks to the machine during transit dont damage the springs or dampers. This must be removed before use otherwise you get pretty much the symptoms you describe.
The manual that cam with it will show you how to remove the transit packaging. In such a short time I suspect you wont have suffered any damage, but take the transit packaging out as soon as possible.
Nov 04, 2009 | Frigidaire ATF6000ES Front Load Washer
Loud thumping noise when the drum starts to spin. The unit is level. It looks like the drum is not spinning balanced
see if you shake or tilt or move the inner tub
if you can you may have a groken spinner support
dont know hold old the machine is, but if its out of warrenty, it could be come very expensive repair
Oct 06, 2009 | GE WSXH208A Front Load Washer
ON SPIN CYCLE MY FRONT LOAD WASHER SHAKES VIOLENTLY
I have a four year old Andi front loading machine, and just in the last week it has started to move violently during the spin cycle and move across the room.
The last time, the movement was so severe that the machine was cutting itself off and then trying to spin again.
I couldn't control the machine and I just had to turn it off at the wall.
Feb 24, 2009 | Frigidaire Washing Machines
Samsung P801 Front Loader shakes violently during spin cycle.
When the washer goes into spin cycle it is suppost to start at a slow speed and continue to increase speed (to a maximum of 800 RPM) as the water leaves the clothes. Your washer is going directly to 800 RPM which causes the washer to shake and stop giving you the E4 code. The control board that controls this speed increase must be replaced.
Feb 23, 2009 | Hotpoint Ultima WD72 Front Load...
Drum off balance
how do I tell if the drum is off balance or the bearings are out in the inner tub of this front load washer?
Jun 30, 2006 | Whirlpool GHW9150 Front Load Washer
GE WSXH208A Front Load Washer Logo
497 people viewed this question
Top GE Washing Machines Experts
Dan Webster
Dan Webster
Tim Whalen
Are you a GE Washing Machine Expert? Answer questions, earn points and help others
