SOURCE: fridge doesn't get cold enough
you have either a Defrost heater / a defrost timer/ or a defrost bi-metal that is bad. if you post your model # i can look it up and show you how to set it into defrost to see if the heaters are ok
Since you replaced the timer already that leaves two things you need to check set it into defrost if you know how and remove the panel in the back wall of the freezer you should see the heater(s) are on if not check pwr 120vac at the heaters if 0 volts the bi-metal is bad
SOURCE: KENMORE MODEL 596 BOTTOM FREEZER, FRIDGE NOT COOLING
The freezer will stay cold because a small
amount of cold air will be forced through the frost but that will not
be enough to make it up to the refrigerator portion. You can defrost
the unit by removing the metal panel and allowing the frost to melt.
Careful use of a hairdryer can speed up this process. This will likely
be a temporary fix. The root cause of excessive frost can be caused by
a bad door seal or a defective defrost circuit.
First check that the door seal is good by closing the door on a dollar
bill at several points around the door, both on the freezer and
refidgerator door. If you can pull the bill out with no resistance, the
door is not making a good seal. Inspect the seal and make sure there
isn't anything stopping the door from closing such as food, or a shelf
not pushed in all the way.
If the door seal is good, the defrost system is likely defective. The
defrost system has three main parts, the defrost heater, thermostat,
and timer. None of these parts are particularly expensive, or difficult to replace you feel comfortable with repairing it yourself. If you can troubleshoot this by manually
starting the defrost cycle. Let me know if you would like this
procedure.
SOURCE: fridge is warm even when i adjust temp. control.freezer is good.
if your fridge has 2 set of dials one numbers and the other letters than you need to adjust the dial that has letters on it. If the fan in your freezer is not blowing, then it won't force the cold air from the freezer to the fridge. Make sure fan blows then adjust the letter knob.
SOURCE: Whirpool fridge is warm, freezer is working
Check the back wall of the freezer compartment for ice buildup. Sounds like you have a defrost issue.
Check out these tips...they can help you figure out what is going wrong with your refrigerator and why it is not cooling
Refrigerator not Cooling or Fridge not Cooling
How to Defrost Refrigerator Defrost Timer Problem
Water Running in refrigerator from Freezer
Refrigerator or Freezer not Cooling or Getting Cold
heatman101
