Question about Robot Coupe Blixer BX6 Food Processor
Replaced magnetic switch wont turn on when i lock the bowl down some times when i slam the bowl hard it will turn on
  • dennis_yasin Jul 30, 2009
    switch is aligned and touching any more ideas thanks in advance
    Brigadier General:
  • 3,614 Answers
This can be a problem on contact with the magnetic switch, it could be not touching did not contact each other so you need to put some force to lock it.
Better check the alignment of the switch if it's properly seated and there was no problem with switch.
Hope this initial info helps.
Kindly let me know for further clarifications.
Posted on Jul 30, 2009
  • micromaster
    micromaster Jul 30, 2009
    This can be a possible cause that can make this kind of problem, a bad contact or a faulty switch.
Kitchenaid food processor wont start
Probably solved by now I suppose but model number would help.
Nov 21, 2016 | KitchenAid Food Processors
Magimix 4200 xl won't turn on
Check that the bit on the lid that activates the switch pushing mechanism in the bowl is working properly.
Aug 27, 2014 | Magimix Food Processors
Hamilton Beach food processor
make sure bowl and lid are on correctly. If not, it wont run. Both have safety switches where they lock onto the unit. If latch tab is broken, you will need new bowl or lid. If still nothing, switch itself is bad
Jun 28, 2013 | Food Processors
Light is on but blade will not turn
You have a bad sensor switch, when you put the bowl. Locate the sensor switch and replace it.
Jul 23, 2009 | KitchenAid KFP740 Food Processor
Problems with Braun K3000
1st lock the bowl properly, watch for the arrow pointing in the right direcction. Then lock the lid, properly and watch that it makes kind of a click sound when it enters into de machine. After that you should be able to turn it on
Jan 17, 2009 | Braun K 3000 Multisystem Food Processor
Motor runs but switch won't activate despite new parts
Make sure the handle of the bowl is facing the front of the food processor. Place the lid tab just to the left of the handle and slide it toward the handle until it won't turn anymore. Remove the pusher sleeve from the lid and reinsert it with the lock facing the front of the food processor. Slide the lock into the locked position. If it still doesn't work, replace the third piece on the work bowl - the one piece that you haven't replaced. It will then work.
-Tha Mp3 Doctor
Jan 10, 2009 | Cuisinart DLC-8S Pro Custom Food Processor
Cuisinart 7 cup food processor wont' start
Remove the work bowl completely. Turn the machine on and use a pen to depress the dark grey or black button on the base of the food processor. If the motor doesn't spin, it needs repair. If there is spinning:
Make sure the handle of the bowl is facing the front of the food processor. Place the lid tab just to the left of the handle and slide it toward the handle until it won't turn anymore. Remove the pusher sleeve from the lid and reinsert it with the lock facing the front of the food processor. Slide the lock into the locked psoition. If it still doesn't work, replace the third piece on the work bowl - the one piece that you haven't replaced. It will then work.
-Tha Mp3 Doctor
Jan 06, 2009 | Cuisinart DLC-5 Food Processor
Euro-Pro EP91 Quad-Blade 6 Won't Start
My wife was given this unit from an elderly gentleman that was done trying to make it work.
I just fixed the same problem as above. Note - I do not have a manual for this unit.
True above about the bowl cover being locked in position but found the key to make it work is also the white lid to the left of the bowl cover. I was locking and unlocking this white lid with no results. Then I removed the bowl cover and found the white lid cover was loose and easily removed this white lid to inspect inside ( why this cover removes I have no clue).
Anyway I was able to snap the white cover firmly on and turn counter clockwise to lock in place ( six o’clock position), then after putting the bowl cover back on and snapping in place it works.
Note - I do not need to turn the white lid cover to install or remove the clear bowl cover, this could be because it looks like one of the clear tabs might be broken on the locking area of the clear bowl cover. If you have two tabs the same shape on the bowl cover you may need twist the white lid clockwise to install and remove the bowl cover and counter clockwise to lock in place so the unit works, but now that my white lid is snapped firmly in place it hardly moves with the force of both hands trying to turn it.
Hope this helps someone.
Good Luck !
Dan L. P.
Jan 05, 2008 | Euro-Pro EP91 Quad-Blade Food Processor
My food processer does not work
I had the exact same problem. The red light came on when I hit the "On" button, but nothing happened. Then I noticed that when the lid is locked into place, a small pin in the handle goes into a small hole in the base. I took a wooden chopstick and poked it in this hole in the base, and the unit started running. I put the bowl and lid back on the unit and locked them into place, and this time the unit ran just fine. Yeah! I will remember this the next time my unit won't run even though I know that I've properly locked down the bowl and lid. Good luck!
Oct 11, 2007 | KitchenAid KFP750 Food Processor
Robot Coupe Blixer BX6 Food Processor Logo
Top Robot Coupe Food Processors Experts
eyecam
Are you a Robot Coupe Food Processor Expert? Answer questions, earn points and help others
