Question about Hoover U6630-900 WindTunnel Bagless Upright Vacuum
How do I change the belt on the motor? - Hoover U6630-900 WindTunnel Bagless Upright Vacuum
    President:
  • 1,273 Answers
Hi. This is easily done. Flip the vacuum over, beater bar up. With the machine unplugged, locate the screws or tabs that hold the base plate on, surrounding the beater bar. Remove the plate. The beater bar is held in place by fitting into sockets that then fit into the vacuum frame, so be careful in removing the beater bar. Pay close attention to the sockets, so you can get the bar assembly back in easily. Replace the belt. When you fit it over the motor shaft, you'll have to slip the belt onto the beater bar, and fit the bar into the frame at the same time. Reinstall the plate, and test your work by revolving the beater brush a bit by hand......If you're satisfied, you should be good to go!
Best regards, --W/D-- please feel free to rate this solution! Thanx!
Posted on Jul 30, 2009
Beater bar does not work
Make and model may help you get an answer.
Nov 02, 2017 | Vacuums
Brush not spinning and motor surging and not picking up
does the motor surge when you push it back & forth or when you raise & lower the brush end of vacuum?
if so it sounds like it needs a new belt installed.
the belt should be routinely changed every 12 months (some need to be changed sooner) do to the belt stretching.
changing the belt to see if that changes how vacuum operates is a cheep & easy fix.
Feb 07, 2015 | Vacuums
I need a diagram to show me where and how to install the front belt< I think the motor belt) on my Hoover Windtunnel, self propelled Model U6634-900 series x12-0 60HZ 120 V
Most vacuums are pretty well the same belt set-up...remove the metal plate covering the rotating floor brush and pull it out...place new belt over motor pulley and and stretch other end over rotating floor brush in the space provided for it....pull and place ends into slots on the sides....if the belt is not straight flip the brush the other way...you will figure it out. Just be sure to buy the right belt!!!
Regards,
Dennis
Aug 15, 2014 | Vacuums
Miele 228 power brush stopped working
Does the motor on the Head Run but the Brush does not turn... change the Belt, the brush head is operated by a rubber belt this is so it has no direct drive so if you suck up something then you ruin a belt and not the motor. Besides you should change the belt as per MFG directions. I change ours at Least 2 times a year and if you do.. say Pull in a Rug corner and it smells like Burnt Rubber? ... you just decreased your life of the Belt.... you'd be surprised on how well a New Belt helps your Vac pick up things. Change the bag often too, do not wait till it can pickup no more. The bag is Not meant to be FULL to be changed, besides it keeps Mites in the trash where they belong and not a breading ground in your closet... If you have a bag-less clean and rinse (All Filters Every Vac has a Filter even the Bag-Less ones) and let dry after a day of vacuuming follow MFG directions, Hope this helps.
Jul 22, 2014 | Miele SEB 228 Powerbrush
Changed Belts, Changed Roller Bar, Still have High pitched, ear splitting squeal, is there a fix for this?
Remove belt and roller. Start motor- noise still there? If so noise is in the motor or caused by the motor.
Mar 09, 2014 | Hoover U6437-900 / U6439-900 Windtunnel...
Change belt
Remove the bottom plate, the V belt goes around the inner pulley and then the brush roll. The flat belt goes around the motor shaft and will stretch to around the bigger pulley by the V belt. f9e9b4d.jpg
May 15, 2008 | Hoover U6437-900 / U6439-900 Windtunnel...
Belt Replacement
Take the bottom plate off, the brush roll and belt are there. the belt goes around the brush roll and hooks to the motor shaft. If you can't get to the motor shaft, then you will nee to remove the top cover also.
May 12, 2008 | Vacuums
Changing the belt?
Take off the bottom plate covering the brush roll. The belt runs from the brush roll to the motor shaft. Get a new belt, it will strectch to go around both.
Apr 29, 2008 | Hoover U5163-900 Upright Vacuum
Eureka 5197 self propelled bagless upright
Did you check the brush roll when you changed the belt? The smell of rubber would inducate a belt slipping. So if the brush roll (part #61308-2)isn't turning, the belt would get hot and would be slipping. If the motor sounds real loud, then you could have a bad motor(part #60775-4).
Feb 14, 2008 | Eureka 5197AT Upright Vacuum
Hoover savvy changeing belt
There some screws on the bottom to take off, then turn vac upright, under the round Hoover logo sticker is another screw. It is just a sticker, so will peel off. You can work the belt onto the motor pulley, or unscrew the motor, put the belt on the pulley, then reinstall the screws to hold down the motor.
Jan 06, 2008 | Hoover U8145-900 Savvy Bagless Upright...
Hoover U6630-900 WindTunnel Bagless Upright Vacuum Logo
176 people viewed this question
Top Hoover Vacuums Experts
Gerry Harvey
Gerry Harvey
Are you a Hoover Vacuum Expert? Answer questions, earn points and help others
