Question about Sony VAIO PCV-W10 PC Desktop
I have no sounds in my computer?
There are no sounds and audio controller in my computer and when I put the headphones they dont work because theirs no device for sound on my desktop how do I get the sound back
    Sergeant:
  • 263 Answers
Reinstall the sond driver
Posted on Jul 30, 2009
SHG7980 Windows 8 drivers not available
If there is a driver needed ?
Click start control panel administration tools computer management device manager scroll to sound video and game controllers you might see a yellow question / exclamation? ! mark or a red X Right click to reinstall drivers
If your computer came with a motherboard disk the drivers could be on it
or you might download slimdrivers.
Rather doing a driver hunt
http://download.cnet.com/slimdrivers-free/3000-18513_4-75279940.html
Windows XP/Vista/7/8
Note: it will find all of your outdated drivers
This is a free driver solutions
which will automatically search for and find the correct driver
You will have to update every driver individually once you update you might be asked whether you want to restart or make a system restore point.
Click no to both of these then continue updating each driver free then restart once all of the drivers have been updated.
It might take some time being free
The headphone jack on the computer connects to the sound card, a hardware device that controls audio input and output on the PC.
The card contains a digital-to-analog converter that converts analog audio into digital signals and visa-versa.
The performance of the headphone jack, therefore, depends on how well the sound card functions; if the card doesn't work, then the headphones connected to the PC won't output sound.
Reconfiguring the audio settings will often fix problems with audio output on the headphone jack, but if the former fails to resolve the issue, replacing the sound card in its entirety is sometimes the only means of repair.
Click "Start." Enter "sound" into the search box. Select "Sound" from beneath Control Panel.
Double-click "Headphones."
If no "Headphones" option is available, double-click "Speakers."
Click "Properties" on the General tab.
Check the Device Status field for errors. Look up the message on Microsoft Support for more assistance, if applicable.
Close the window if the Device Status field reads "This Device Is Working Properly." Go to the "Levels" tab.
Click the speaker button to unmute the volume if the icon contains a red circle-backslash symbol. Drag the top slider to the right to increase the headphone volume.
Go to the "Enhancements" tab.
Check "Disable all Sound Effects." Go to Applications, and then clear "Allow Applications to Take Exclusive Control of This Device."
Click "OK" to close Headphones Properties or Speakers Properties.
Test the audio.
If the headphones fail to output sound, unplug the headphones from the computer.
Reconnect the headphones to the PC.
Headphone jacks are color-coded lime green on most PCs.
Look for the headphones symbol if the jacks are not color-coded.
Plug the headphones into the line-out port on the back of the computer if the headphone jack on the front of the PC fails to work, or visa-versa.
Test the headphones.
If headphones still won't emit sound, the sound card most likely requires replacement.
Replacing the Sound Card
Shut down the computer. Remove the power cord from the back of the PC.
Disconnect the keyboard, mouse, monitor and all other peripheral devices.
Loosen the screws found on the back of the case, then slide the cover panel off of the case. Touch the chassis to protect the hardware from electrostatic discharge, or ESD.
Set the computer on its side.
Locate the sound card found on the opposite of the audio jacks and loosen the screw that secures the card to the computer.
If no expansion card is located opposite the jacks, the computer uses an integrated sound card which can't be removed.
Remove the new audio card from its protective packaging.
Line up the card with an available expansion slot on the motherboard, then push the card down into the slot to install the new audio jacks.
Screw the card to the computer case.
Reassemble the computer.
Turn on the PC. Boot in to Windows and insert the CD that came with the new expansion card. Follow the onscreen instructions to install the sound card software to the computer.
Plug the headphones into the new line-out jack.
Jul 10, 2013 | Intel Computers & Internet
Headphone jack does not work
The headphone jack on the computer connects to the sound card, a hardware device that controls audio input and output on the PC. The card contains a digital-to-analog converter that converts analog audio into digital signals and visa-versa. The performance of the headphone jack, therefore, depends on how well the sound card functions; if the card doesn't work, then the headphones connected to the PC won't output sound. Reconfiguring the audio settings will often fix problems with audio output on the headphone jack, but if the former fails to resolve the issue, replacing the sound card in its entirety is sometimes the only means of repair.
Click "Start." Enter "sound" into the search box. Select "Sound" from beneath Control Panel. Double-click "Headphones." If no "Headphones" option is available, double-click "Speakers." Click "Properties" on the General tab. Check the Device Status field for errors. Look up the message on Microsoft Support for more assistance, if applicable. Close the window if the Device Status field reads "This Device Is Working Properly." Go to the "Levels" tab. Click the speaker button to unmute the volume if the icon contains a red circle-backslash symbol. Drag the top slider to the right to increase the headphone volume. Go to the "Enhancements" tab. Check "Disable all Sound Effects." Go to Applications, and then clear "Allow Applications to Take Exclusive Control of This Device." Click "OK" to close Headphones Properties or Speakers Properties. Test the audio. If the headphones fail to output sound, unplug the headphones from the computer. Reconnect the headphones to the PC. Headphone jacks are color-coded lime green on most PCs. Look for the headphones symbol if the jacks are not color-coded. Plug the headphones into the line-out port on the back of the computer if the headphone jack on the front of the PC fails to work, or visa-versa. Test the headphones. If headphones still won't emit sound, the sound card most likely requires replacement. b> Replacing the Sound Card b> Shut down the computer. Remove the power cord from the back of the PC. Disconnect the keyboard, mouse, monitor and all other peripheral devices. Loosen the screws found on the back of the case, then slide the cover panel off of the case. Touch the chassis to protect the hardware from electrostatic discharge, or ESD. Set the computer on its side. Locate the sound card found on the opposite of the audio jacks and loosen the screw that secures the card to the computer. If no expansion card is located opposite the jacks, the computer uses an integrated sound card which can't be removed. Remove the new audio card from its protective packaging. Line up the card with an available expansion slot on the motherboard, then push the card down into the slot to install the new audio jacks. Screw the card to the computer case. Reassemble the computer. Turn on the PC. Boot in to Windows and insert the CD that came with the new expansion card. Follow the onscreen instructions to install the sound card software to the computer. Plug the headphones into the new line-out jack. Hope this helps.
Jan 21, 2013 | Acer Aspire Computers & Internet
I dont have sound in my pc.i dont know where to fix my problem
If you sue external speakers or headphones, follow these instructions. If you have a notebook computer & are using the onboard speakers, skip to the *Windows section below.
You can start by checking your speakers, if any. Make sure they are powered on and functional. You may also want to test there speakers on a different computer just to make sure.
If the speakers work on a different computer but YOURS still does not have sound, try a known-working set of headphones. Make sure the jack is seated correctly as it may be loose.
*Windows:
Check the volume controls on in Windows. If windows does not have any volume controls, then chances are, the sound drivers are not installed. Check your computer manual to find out what model it is, then visit the manufacturer's website to download the appropriate drivers and software for the sound card.
Note that if you have used external speakers or headphones anytime before this issue started, you may have to re-plug the device & unplug it again & allow Windows to detect that it's unplugged (for HD-capable audio devices in Windows Vista or 7).
If you do have HD audio in Windows Vista or 7, right-click on the volume control in the notification tray on the bottom-right corner of your screen and select "Playback devices"...
... then make sure you choose the appropriate output device (whatever it is that you actually use: Speakers, headphones, HDTV output, etc).
Aug 12, 2011 | Computers & Internet
My speakers dont work at all. the only way i can hear things is if i put headphones
Probably the volume of speakers is turned down.
1. Go to Start
2. Open Control Panel
3. Unplug the Headphone
4. Open Sound and Audio Device
5. Find "speakers" under Playback device (normally it on AUDIO tab)
6. Click on the button "Volume"
7. Pull all the slide bar to the top.
8. See if you hear sounds from the speakers
Mar 20, 2011 | HP G60-230US Notebook
I cant hear nothings on my computer theirs no sound it says theirs is no speakers or headphones plugged in and wel they are plugged in (compaq presario SR5202HM) windows 7 ultimate 32 bit.
are you using a sound Card the presario SR5202HM has this sound setup
Sound/Audio Integrated Realtek ALC888 Audio
  • Audio CODEC: Realtek ALC888
  • High Definition 6 channel audio
make sure that this sound driver is up to date
here is the plugs
4 - Audio: Line In (light blue) 5 - Audio: Line Out (lime) 6 - Audio: Microphone (pink) make sure you have the headphones plugged into the Lime colored plug
if this doesn't work i have some more idea's let me know.
Jan 23, 2011 | Compaq Audio card Sound Card
My speaker don't make a sound or headphones theirs no sound coming out
control panel sounds and audio,audio you will find the necessary adjustments to make there or control panel,administrive tools,computer management,device manager,sound,could be a yellow question mark? right click to re-install drivers
hope this helps
Sep 22, 2010 | Audio Players & Recorders
No sound when i put in cd or dvd was working ok untill my computer crashed
check the following
Microsoft Volume Control or your mixer program mute options and volume sliders.
Connect headphones to the stereo phone jack on your CD-ROM drive’s front panel; adjust the volume control settings on the drive. If there is sound from your headphones, check the CD audio cable connection from the CD-ROM drive to the audio card.
Ensure the speakers are properly connected to the audio card’s output connector.
hope this can help
goodluck
JABEMS
Nov 13, 2009 | Hannspree 19" Widescreen LCD Flat Panel...
My laptops speakers stopped working
Have you tried a pair of headphones to see if they work?
Is the sound ouput muted? (a lot of laptops have a physical button to
do this...
check to see if the laptop is muted. Also, check the
volume control to see if everything is up where it should be, including
Speaker Out.
If I've got this all straight, the only thing that it can be is an
issue with the plug on the speakers and the jack on the laptop.
Obviously the computer is putting out sound to the headphone jack as
evidenced by your ability to listen through headphones. The speakers
work on another computer. So, it has to be something specific about
the Speakers on this laptop. Plug/Jack problem is the only thing that
comes to mind.
Jun 24, 2009 | HP Compaq Presario 2500LA Notebook
NO SOUND
the make and model of your computer dont matter to what speakers you hook up. i can take those speakers and plug them into my ipod, my computer, even my psp and will work.
i would first check ALL wiring and make sure is all conected corectly.
try plugging them into your ipod/mp3 and see if you hear sound? if not, its the speakers. If yes lets move on.
Plug them into your audio jack on your computer (THE BACK, Green audio Jack) usually your front audio jack if you have one is set to head phones and your rear audio jack is set to speakers.
Plug them in.
Go to Start, Control Panel, Sound.
Now make sure your speakers are conected and it notices it.
Me i have 3 Input devices that show up.
1) Speakers
2) Headphones or Audio 2nd Output
3) Digital Output
If you plug them into the back they will most likely but under #1.
Click Option #1 or the one that is labeled speakers and says "plugged in"
Towards the bottom select, Set As Default.
Apply Changes, Ok, and exit.
Now try listening to something on your computer.
If this still doesnt work, let me know.
Thanks
Feb 15, 2009 | Boston Acoustics BA735 Computer Speakers
Sony VAIO PCV-W10 PC Desktop Logo
79 people viewed this question
Top Sony Computers & Internet Experts
Are you a Sony Computer and Internet Expert? Answer questions, earn points and help others
