Question about Hotpoint Ariston WD440G Front Load All-in-One Washer / Dryer
The drum won't spin
Once you push the start button on any setting the drum will start to fill with water and start to turn then stop. There is only half a load in the machine but the drum refuses to turn over completely. This happened once before when the machine was under warranty and hotpoint came to fix it
  • lewis_pennic Jul 30, 2009
    When hotpoint fixed it the first time software that ran the machine need to be reinstalled as it seemed to have crashed, which is what I believe to have happened again.
    Problem Solver:
  • 9 Answers
Check tension on the belt
Posted on Jul 30, 2009
Electrolux EWF 1495 won't spin.
The belt could be stretched or the tension idler could be malfunctioning.
Feb 12, 2015 | Electrolux Washing Machines
Fills with water, drains, will not spin. sometimes will not fill
This is almost certainly the filter to the empty pump blocked. When you power up the machine, the first thing it does is make sure there is no water left over in the tub, if it can't evacuate any water it finds there, it won't go any further. Same on a spin, if after a set time the water hasn't emptied the empty cycle will stop but the spine cycle wont start because there is still water in the drum.
Locate and clean your empty pump filter.
Jun 29, 2011 | GE Washing Machines
What does the LE flashing mean? Water won't drain out of washer.
LE means that the motor sensor has failed and needs a technician to come out and repair the unit. To remove the water, turn on the unit, press the spin speed button once and press start. It will drain the water out and spin the drum.
Jun 15, 2011 | LG WD-1280FHD Front Load Washer
Miele w1113. Washer drum won't spin during wash cycle
I assume you are saying the machine is working except the drums not turning? - you need to see if the belt has come off because thats what i would check first if you hear the motor start/stop after it fills up with water.
May 30, 2011 | Miele Touchtronic W1113 Washing Machine
Wash cycle and spin
you need to check a simple button called " no spin" may you will see it marked "aspiral shap" and has "x" over
good work !
Jul 05, 2009 | Zanussi ZWF1430W Front Load Washer
Front loading ge washing machine only 2 months old. door locks,
take water lines off of water valve at rear of unit and clean dirt out of screens.
Jun 19, 2009 | GE WSXH208A Front Load Washer
Fills up when not on
you have a leaky water valve it leaks because one of the solenoids in the valve is stuck open, the unit senses the water in the drum from the leak and therefore must be drained before it can start a new cycle, replace the water valve.
Apr 07, 2009 | Maytag Neptune MAH5500B Front Load Washer
Wash starts it fills with water then stops and wont wash
problem may just be that drum is not turning so you think program is stopped. try cancelling and select spin program and see if you get spin
Apr 01, 2007 | Hotpoint WMA44 Front Load Washer
Hotpoint Ariston WD440G Front Load All-in-One Washer / Dryer Logo
142 people viewed this question
Top Hotpoint Washing Machines Experts
vince
Eric Taylor
ptpumpman
Are you a Hotpoint Washing Machine Expert? Answer questions, earn points and help others
