Question about Sony Grand WEGA KDF-55XS955 55" Rear Projection HDTV
Picture goes on and off intermittently - Sony Grand WEGA KDF-55XS955 55" Rear Projection HDTV
  • 167 Answers
There is a Sony factory update on these types of TV's. It is an overheat sensor that needs to be replaced with a new design to keep this from happening.
Posted on Jul 30, 2009
Samsung hp-s5053 bottom half goes black intermittently. Picture is fine, bottom half goes black, then picture comes back. Is there a replacement part I can try before disposal?
The Tcon board or the LCD panel is faulty. Can confirm by replace the Tcon board .
If you wish to get some details; check the site linked here. Pull up older posts.
http://electro-medical.blogspot.com/
Jul 02, 2016 | Samsung Televison & Video
How to fix my Samsung tv ..picture goes in and out intermittently
The inverter board is responsible for the backlight so you can see the picture. If the picture just goes off intermittently then that means that the backlight is being turned off. And since the inverter board powers the backlighting you might want to look there.
Feb 25, 2016 | Samsung Televison & Video
How to fix an intermittent white screen on a Samsung television?
Ask them to replace the t-con board. It could be a defect one.Good Luck.
Serge.
Oct 01, 2015 | Samsung LNT3242H Television
LG M197WDP, used as a monitor with a Windows 7 computer. Intermittently the monitor goes black for 15 to 20 seconds then the picture returns. I have checked drivers etc all up to date. Anyone able to
Could be a hardware issue, If the screen has a power light, does it change coulor (often green to orange) when the problem happens. If so its the screen inst getting any signal. It could be a connector or cable.
Nov 01, 2014 | Computers & Internet
MAGNAVOX 27" TV, PICTURE START UP PROBLEM
This problem with your television set is more than likely a problem with intermittent component failure. The fact that the television turn on for awhile is a sign the the component or components are intermittent.The reason the television turns off is that it goes into the protection mode caused by the intermittent component or components. They are unstable and are causing unstable voltages supplies to appear in the circuits. The television has a built in feedback circuit that will detect the faulty operation and turn off the television. When it stabilizes again the television turn back on. This is usually a sign of aging or faulty components. The problem will only get worse and the television should be thoroughly tested. You can call Magnavox customer support at this telephone number 1-800-705-200. Give them the model number of your television and tell them about the problem you are having with intermittent turn on of the television. They will be able to tell you where to take the television for testing and service. I hope this information helps you with your problem.
May 19, 2009 | Philips Magnavox 27MS343S 27" TV
Sony KP-53HS10 rear proj TV - picture goes on & off
If the adjustment of the screen settings does not fix your problem, its likely that one or more of the CRTs (picture tubes) is defective.
And, the CRTs for these sets are hard to find and expensive.
michtech
Jan 29, 2009 | Sony KP-51HW40 51" Rear Projection...
Picture goes intermittent after a while; sound plays throughout.
I would take it to a repair shop, they charge around $50 to look it over, and then tell you want is wrong with it and they will give you the cost to fix it. This is what I do when TV's go out. It will save you time and money in the long run.
May 19, 2008 | Sony KV-32FS10 32" TV
42" RCA Projection TV - Sound good, but Picture goes out intermittently.
resolder the vertical output IC . bad solder there can make the CRTs blank for protection and you will lose the picture when the vertical drops out.
Mar 27, 2008 | Televison & Video
Intermittant lamp cycling
could be lamp or lamp driver the only way to tell is to replac on at a time.
Aug 11, 2007 | Sony Grand WEGA KDF-42WE655 42" Rear...
RCA F36450 TV is intermittently snowy
Your tuner assembly has a bad connection inside of itself, or there is a bad connection around the tuner assy. if this is an ATC113 chassis Good Luck
Mar 21, 2007 | RCA F36450 36" TV
Sony Grand WEGA KDF-55XS955 55" Rear Projection HDTV Logo
154 people viewed this question
Top Sony Televison & Video Experts
Are you a Sony Televison and Video Expert? Answer questions, earn points and help others
