Question about Toshiba Computers & Internet
I bought a Toshiba satellite L300 laptop 5 weeks back. It worked well for 3 weeks. Suddenly it developed a problem. It just started hanging. It would not give any response to cntrl+Alt+del. My only solution was to switch it off. It again functions normally after 5-6 tries. During these tries it goes into windows repair mode & I have to follow the sequence. After a few tries it works normally, then it hangs again & I have to switch it off. What should I do to get over this problem? My Laptop is only 5 weeks old.
    Sergeant:
  • 280 Answers
If you had had virus problems or if this started to happen after a software installation, you better try restoring your PC to an older state. Go to Start->Accessories->System Restore. Select a date before the problem started. Restore your PC. If the problem still remains, comment back. Also if you have ZoneAlarm, try uninstalling it. That might be the problem in some cases
Posted on Jul 30, 2009
Toshiba Satellite l300 1ap windows 7
Restore Toshiba to Out of the Box Condition
If your model Toshiba laptop has a Restore partition on the hard drive then follow these steps to restore your Toshiba to the Out of the Box condition.
1. Press and hold the 0 (zero) key and at the same time, tap the power button once to switch on
your notebook.
2. When the machine Starts beeping; release the 0 key.
3. When prompted by the warning screen; select Yes to continue with the system recovery.
4. Select Recovery of Factory Default Software; click Next.
5. Select Recover to out-of-box state. 6. Click Next again.
7. Click Next to Start recovery.
8. Restart the Toshiba laptop when there restoration process finishes running. Follow the prompts that appear on the screen to set up the laptop's date, time and language settings.
Oct 15, 2012 | Toshiba Satellite Pro L300 (L300-EZ1502)...
I got a new Toshiba satellite L300 notebook and turned it on today. But there's a starting up beep but the screen remained black. even when i connected the laptop to another screen, the screen still...
Take it to the purchasing party and get a refund or a repair if you just bought it. If it has a warranty by all means get it back to get it repaired. If you bought it from a private party always turn it on before you take it to see if it works first. Also you may want to try restarting and waiting a bit to pick up the screen sometimes they are really slow starters depending on what is has loading at the startup. I feel for you friend. John
Jan 30, 2011 | Toshiba Satellite Pro L300 Notebook
My toshiba satellite l300 suddenly not charging. might be the loose power jack, battery or the charger... how can i check which of these is the root cause?
Does the laptop work on the ac adabpter? If it does, you probably require a new battery. Ebay will be the cheapest source of original and copy batteries.
If it doesn't, you probably require a replacement ac adapter, Ebay again.
Hope that helps.
Jan 20, 2011 | Toshiba Satellite Pro L300 Notebook
Toshiba Satellite Pro L300 PC Notebook in battery the set is OK but when I connected ac power the set is hang on or restarted frequently
you should have your unit check professionally, as it can be cause by multiple problem.
1. laptop fan
2. memory problem
3. voltage problem.
either way, its best that you try to have it check thru the toshiba service center.
Nov 13, 2010 | Toshiba Satellite Pro L300 Notebook
Toshiba satellite L300 freeze when adaptor plug in.
This is a middle pin issue, you will find the laptop doesn't charge either but will power the unit, if the power is connected, the laptop will hang and use reserve resources, if you unplug it, the machines performance will dramatically increase.
replace your power adaptor and all will be fine, i have had the same issue.
Sep 02, 2010 | Toshiba Satellite Pro L300 Notebook
Computers & Internet Logo
77 people viewed this question
Top Toshiba Computers & Internet Experts
k24674
Are you a Toshiba Computer and Internet Expert? Answer questions, earn points and help others
