When I make a copy I get a strip down the middle that does not copy.
  • 313 Answers
If yo are using the documen t feeder check the smalll glass that the paper passes over to see if there is any tipex or ink marks on it if the copy is done off the glass plate and no line appears or if you are printing to the machine and it doesnt appear then it is usually down to the smalll **** glass or it could be a bit of dust on the mirrors on the scanner unit..Hope this helps Good Luck A>>
Posted on Jul 30, 2009
Error message 502
Hardware Error 0502 on LCD Display
Check the encoder strip on the printer. (This is a clear strip running the length of the printer, above or behind the cartridge carrier.) Do the following:
1. Switch off the printer using the power button.
2. Disconnect the power cable from the back of the Lexmark X5100 / X6100 Series.
3. Leave the power cable disconnected for 30 seconds.
4. Slide the cartridge carrier to the middle of the printer by taking the top part of the belt and moving it gently to the right.
5. Take out both cartridges.
6. Place an index finger on the encoder strip on either side of the cartridge carrier.
7. On the back of the cartridge carrier, there is a small slot that the encoder strip fits into. Slightly push the encoder strip down and then back up to get it into the slot.
8. Lightly press the strip first to the rear and then forward, if necessary.
9. Clean the encoder strip with a dry tissue. Also clean the contacts of the printer.
10. Reconnect the power cable and switch the printer on again.
11. Perform the hardware test without cartridges first and then with both cartridges.*
12. Make a standalone copy.
13. If the copy is satisfactory, repeat the test once to confirm that the error is gone.
Jan 13, 2011 | Lexmark X5150 All-In-One InkJet Printer
Copy has a white 4" strip down the middle I have a canon k940
PROBLEM WITH THIS COULD BE LASER SLICK GLASS CLEAN, ALSO CLEAN TRANSFER UNIT
Oct 20, 2010 | Canon PC-940 Black and White Copier
What causes a line down the middle of copied pages
There is something on your scan glass. My guess is you are getting the line on your copies when you run the original through the document feeder. If you get lines through the document feeder but not on copies made off the glass then it is a dirty scan glass. There is a thin glass strip where the document feeder feeds the original. Usually something like white out that did not dry smears off an original and ends up on this thin strip of glass. Scratch it off with your finger nail and use some glass cleaner to resolve the problem. The scan glass is about 1/2 an inch to an inch wide and will be on the same side of the machine that the copier feeds the originals in on.
May 24, 2010 | Canon imageCLASS MF6530 Monochrome Laser...
How do I fix hardware error 0 502?
Feb 10, 2010 | Lexmark X6150 All-In-One InkJet Printer
Showing Hardware Error 0502
Hardware Error 0502 on LCD Display ID:ENUS16536
Feb 07, 2010 | Office Equipment & Supplies
Leaving a dark strip down the middle of the copy
what your copir model? if your model IR3045 replase the drame unite.
Jan 05, 2010 | Canon Office Equipment & Supplies
Blank strip down center of page
It's hard to say when I don't know what machine you have, but it could be the toner cartridge. If you have a cartridge pull it ou shake it gently and try another copy.
Good Luck
May 04, 2009 | Canon Office Equipment & Supplies
I have a cs-1530 and when using the auto-feed the copies made come out with a black line down the middle.
Dear Sir; Open the cover on the left hand side have a piece narrow strip glass (or white reference on the cover) use rubbing alcohol to clean it.
Jan 10, 2009 | Copystar CS-1530 Copier
Blank Strip Down the Middle
My guess is the fuser needs to be replaced.
Apr 21, 2007 | Epson TM-T88III Thermal Printer
k24674
