Question about Electrical Supplies
My honda worked until i had my two fridges pluged in then i turned a light on it blew the light now it worked power anything it runs good but like i said it wont give power to anything would there be a fuse i need to change
  • 41 Answers
Yes there should be. there should be a circuit breaker, try to reset that. then find the circuit protectors and check those. without model# I dont know locations but probably around the control panel.
Posted on Jul 30, 2009
Amana Regrigerator Stopped Working After Power Supply Loss
unplug it and leave it off for an hour. then plug back in this may reset it. power coming back on can be higher than normal its always best to turn things off so when the power comes back on and you switch it back on its at the correct voltage.
Feb 28, 2018 | Amana Refrigerators
TV will not power up. Timer light continues to flash, will not reset.
You could have shook a fuse loose moving it ,,,or blew a fuse,,take the back off and check the fuses,,good luck ,,
Oct 06, 2008 | Mitsubishi WS-55859 55" Rear Projection...
I just got an amcor CPLMB12000E fom a friend, it worked great for about 15 min. then the fridge turned on an blew a cecit breaker in the box. I reset itand all it does is blow harm air. I pluged it into a...
Check compressor and fan only things it can be disconnect one at a time until fault goes away and there is your prob hope this helps
Aircon chilling for a living....................
Sep 01, 2011 | Heating & Cooling
Suddenly fridge not working
Two things to check.
Is the door light coming on? If yes you have power
Is the compressor running? Turn the thermostat knob until you hear a click. Did anything happen?
If no you will need a new thermostat
Mar 31, 2011 | Haier Refrigerators
Honda eu3000is. runs but not putting out the full watts. Is this a cheap or expensive fix?
I have the 5kw Honda and have no problem, but I have never tried to run 5,000 watts either. It is reaching max rpms? Air filter clean? Good fuel? Oil? Have you run it much, or does it sit? How do you measure the wattage? Add up a bunch of things like, skil saw, pump, fridge, etc? Let's see, skill saw at 13 amps x 120 volts =1560 watts. Fridge probably idles at 7amps, starter windings use 10 or so amps, tv, 500 watts, computer, I would not run anything electronic with a genny, unless I had a spike protector on it. Check it out, hope this helps.
Mar 05, 2011 | Honda 3000 Watt Portable Generator
My 97 Honda Civic runs good and up until now, no problems, but when I turn on the key to start it, nothing happens. Have new battery, fully charged, lights on dash do not go off when I turn key to start. ...
Bypass the clutch switch. If the car starts then replace the switch.
If this will not work, then you need to troubleshoot the starter, from the fuse up to solenoid. Might be anything from a bad fuse, bad relay, bad solenoid, corroded starter copper contacts, or a bad starter. Hope this will help.
Oct 05, 2010 | 1997 Honda Civic
Hello, i was changing the tail light to a aftermarket light with turn signals and when i pluged it in my bike turned off but when i restarted it the dash display does'nt light up but all the signals in the...
Check your LH side cover under the Rectifier or if not there look by your instrument panel there should be a plastic cover you can open up. Good enough for free advise? Another quick way is to query a Honda dealer mechanic an to show you where it is. Good?
May 03, 2010 | 2007 Honda CBR 1000 RR Fireblade
93 accord shuts everything off when I turn key from on to start
there is a crank fuse in the fuse pannel under the hood check that its comman
Mar 22, 2009 | 1993 Honda Accord
My Amana refrigerator freezer is totally off.
Ouch!
You may have lost your fridge. Try This.
  1. Unplug.
  2. Take a table lamp & plug into socket where you had fridge plugged in. Turn light on. If it lights. Fridge is trouble.
  3. If no light check another socket make sure light works if it works your socket, wiring or breaker is your problem.
  1. If fridge check wire to & from fridge make sure it is unplugged feel & look for crimp or gap in wire.
  2. Check connection to fridge some have a reset button or overload fuse. Reset or replace if you find one.
  1. If socket try another socket see if fridge runs.
  2. If it runs you will have to troubleshoot house wiring.
Contact me if you need more help. Good Luck!
Please rate if this fixed or was helpful. Thank you.
Mar 09, 2009 | Amana ABB1927DE Bottom Freezer...
Electrical Supplies Logo
35 people viewed this question
Top Electrical Supplies Experts
Craig Butler
Craig Butler
Steve
Gene Haynes
Are you an Electrical Supply Expert? Answer questions, earn points and help others
