Question about Refrigerators
The water intermittently does not come out from the water dispenser. The ice maker seems to be working fine. What could it be?
  • Mike Smith
    Mike Smith May 11, 2010
    Brand and model number needed .
  • 547 Answers
It could be that the water line is freezing up. Have you ever had bits of ice come out of it? If you have a good thermometer, you might check the temp of the water.
Chill the thermometer so it's close to freezing. Draw a few ounces of water (too much and you'll be bringing in warmer water from the line) and check to see if it's below 36 degrees.
If you're icing your water line, just turn the thermostat up (warmer) by a bit.
Posted on Jul 30, 2009
  • Rob C Aug 03, 2009
    Just had another thought on this one -- does your fridge have a water filter? When was the last time you changed it?
    For the Pur water filter in ours, they recommend changing it every 6-9 months. Your filter may be (almost certainly is) different.
How do i fix ice maker
Could be 2 different problems. Inlet water valve is a dual valve (2 halves). 1 half feeds water to the door dispenser, the other half fills the icemaker. The icemaker half could be bad or blocked up with sediment causing a no fill situation. 2nd problem could be the icemaker itself which sends power to the inlet valve when it needs filled. Usually the inlet valve fails first but you need to test and see.
Apr 14, 2015 | Refrigerators
Ice maker kitchenaid super ba is not working . Chilled water dispenses but no water seems to enter ice maker.
Before going to buy any parts directly.
Go through this troubleshooting help links.
This is list of refrigerator problems, which is normally faced in refrigerator.
You can go through the details, by clicking the link below:---
Refrigerator is not cooling properly?
http://technoanswers.blogspot.com/2011/06/refrigerator-is-not-cooling-properly.html
Both refrigerator and freezer not cooling properly in refrigerator?
http://technoanswers.blogspot.com/2011/06/both-refrigerator-and-freezer-not.html
The ice maker not working: ---
http://technoanswers.blogspot.com/2011/06/ice-maker-stopped-working.html
Compressor not running on refrigerator?
http://technoanswers.blogspot.com/2011/10/compressor-not-running-on-refrigerator.html
Water dispenser not working on refrigerator?
http://technoanswers.blogspot.com/2011/10/water-dispenser-not-working-on_19.html
Ice maker stopped making ice?
http://alltypesofpartsreplacing.blogspot.com/2011/10/ice-maker-stopped-making-ice.html
Water Overflows in Ice maker and freezes inside?
http://alltypesofpartsreplacing.blogspot.com/2011/10/water-overflows-in-ice-maker-and.html
How to replace Ice maker assembly?
http://alltypesofpartsreplacing.blogspot.com/2011/10/how-to-replace-ice-maker-assembly.html
These will help.
Thanks,.
Dec 22, 2012 | KitchenAid Superba KSRG25FK Side by Side...
Water dispenser doesn't work
It could be the water valve. There is usually one for the ice maker and one for the water.
Aug 31, 2009 | Refrigerators
FROZEN WATER FILTER - UNRELIABLE TEMPERATURES
About the dual water control valve the side that feeds the ice maker could be defective. Fill the ice maker with tap water and let freeze. If it dumps and does not refill the water control valve will need replaced. Here is a link to the water control valve.
WR57X10032 Water Control Valve
As far as the temperature control here is a link to the Temperature Control Here=>
WR55X10095 Temperature Board Encoder Below are some photos. If I can help answer any questions let me know, Sea Breeze appliancepartsse@yahoo.com 6b49f39.jpg053ba1a.jpg
Jul 28, 2009 | GE Profile Arctica Stainless Steel Top...
Intermittantly no water from inside water dispenser
I just started having the problem of no water dispensing from the in-door dispenser. I checked the operating manual and it suggested that the refridge temp may be set too low thus freezing up the water line. I have set the temp higher and we will see if that helps. I do not think that will do it because as you too note, the ice maker works fine. If the filter were an issue the ice maker would not refill either.
illinoisjas
Apr 19, 2009 | KitchenAid KBFA25ER Bottom Freezer French...
Ice maker issues
Replace the Motor Module on the ice maker. I had the exact same issue.
Jul 30, 2008 | KitchenAid KSCS25FKSS Side by Side...
Frigidaire Ice Maker not working
sounds like you got a water valve problem. it will be found at the lower back side of fridge where the water hook up is at.
Mar 14, 2008 | Frigidaire FRS6R5EMB Side by Side...
GE GSH22SGRE - water dispenser not working but ice cube maker working fine
I have the same problem, although mine is intermittent. Apparently it's a problem with the line freezing. For an excellent discussion of the issue, see http://www.askmehelpdesk.com/advice/t-14182.html
Dec 20, 2007 | Refrigerators
Refrigerators Logo
83 people viewed this question
Top Refrigerators Experts
Charles T Nevin
Charles T Nevin
John Tripp
John Tripp
