Question about Watches
My Pulsar 4005's second hand twitches and stays in place, which throws off timing. Can I fix it, and how?
  • 65 Answers
If your watch is still running acording to hrs and mins then the second hand must be slipping so would need to be attended to by removing the module, In some watches the second hand appears to twitch because the battery has become too flat so maybe the battery needs to be replaced.
Posted on Jul 30, 2009
Pulsar World Chronograph, World Timer
Click on the crown (the stem in the middle on the right side). There are three settings, and one of them will change the minute hands' behavior to normal. You might also check out this guide:
http://c01.coacdn.com/calibers/H800_condensed.pdf
May 07, 2014 | Pulsar Mens World Time Alarm Chronograph...
Pulsar Chronograph 100 m - The second hand on the left small dial (not the sweep second hand of the stop watch) has begun moving erratically. It appears to move for two counts and pause for three and then...
If your watch is solar powered the second hand performs this characteristic when it's in need of a charge. Try placing your time piece under a bright light for short time or in direct sunlight and see if this helps you with your problem.
Jul 21, 2011 | Pulsar Chronograph Watch
Pulsar chrono hand alignment
mcdedevito75 here, Return to the watch rep[air that installed the battery for adjustmaet.
Jul 03, 2010 | Seiko Pulsar watch
How do you get the big second hand to go back to the 12?
I went through the steps on re-setting the time and date and somehow it fixed the problem.
Dec 31, 2009 | Pulsar Tech Gear PF3183 Wrist Watch
How do I set the Pulsar Alarm-Chronograph N944-6A00
Short answer: You download the Operational Guide from Pulsar:
http://www.pulsarwatches.com/home2.asp#FAQ (look for N944 which is PGC series).
Longer answer: It is baffling to do this without the manual. You put the watch in -0- mode (crown fully in), pull the crown out to first stop, then us the A and B buttons to zero the 1/10th and second hands, then pull the crown out to second stop, then use the A and B buttons to zero the minute and hour hands. Then, you put the watch in "Time" mode (crown fully in), pull the crown out to the second position, and use the A and B buttons to set the time. You have no functioning second hand except for the stopwatch - in Time mode it acts as the calendar hand.
Dec 16, 2009 | Seiko Pulsar watch
The hour & minute hands on my pulsar nx14-x001 do not move. the second hand quivers, but also does not move. the digital time and other functions are okay. HELP!
Without knowing the model of the watch i would say you need a new battery. It is typical for this style of watch to have two batteries or one lithium battery. In either case the analog movement will drain faster than the digital portion of the watch and will stop working first.
Sep 21, 2009 | Pulsar Watches
Second Sweep Hand Stopped
sounds like the gear that turns the second hand has a tooth missing.
Apr 28, 2009 | Watches
Pulsar Gents Chronograph PF3501X1?
OK YOU GO TO SET TIME BY PULLING OUT PIN TO SECOND CLICK OUT. THEN USE THE BOTTOM BUTTON TO SET THE ALARM DIAL TO THE SAME TIME AS THE MAIN WATCH HANDS. CLICK BACK IN ONE CLICK WINDER THEN USE THE BOTTOM BUTTON TO SET THE ALARM. CLICK WINDER BACK IN FULLY AND PRESTO YYOU HAVE IT.
Feb 09, 2008 | Watches
Sweep 2nd hand operation & watch time setting on my Pulsar watch.
The larger second hand on the Pulsar PF8036 is part of the stopwatch feature. The upper button starts/stops the stopwatch feature, and the lower button operates the lap/reset function. Why they made the larger hand work only with the stopwatch instead of the smaller hand to the left is beyond me, but that's how it is designed.
Oct 09, 2007 | Watches
Watches Logo
324 people viewed this question
Top Watches Experts
Jimmy Accardi
Are you a Watch Expert? Answer questions, earn points and help others
