Question about Hoover Vacuums
Need address of Kohls corporate headquaters
Major complaint about a product bought there in August and now December does not operate, I have org. receipt won't take it back,said I have to return to maker. I called them they won't take it back. Hoover Vaccum.
  • 8,112 Answers
Feel free to look it up like we would. non repair questions take a back seat here at fixya.
Posted on Jan 05, 2018
3 Suggested Answers
  • 430 Answers
SOURCE: recently bought electolux hoover , used it at
Since you were " hoovering" I assume you're in England ...or nearby.
If so you will have to look up AB Electrolux vacuum division.
The number in North America would be AERUS Electrolux for models pre 2000.
AB Electrolux has bought them out and would cover totally different units sold here since about 2002....
Posted on Oct 12, 2009
snowghost1
  • 784 Answers
SOURCE: My Windtunn begless hoover vaccum
check to make sure that the brush wheel turns freely ( without belt on ) -- if it does not turn freely then there could be hair or carpet strands twisted up on the ends of the wheel,, inspect and clean. also make sure that the wheel cartridge is sitting nicely in its mounting area,, ( again - make sure the wheel turns freely ). now if it is moving freely - then make sure the height adjustment on the vacume is set to the proper height for your carpet thickness,, it kinda sounds like the brush wheel is not turning because it has to much pressure on the floor.
so -- make sure wheel spins freely,replace the belt and adjust the height and then check the unit for proper operation.
c...
Posted on Feb 03, 2011
I bought the vacuum in August it was working perfectly until a couple of weeks ago when it started cutting out. It now won't run at all. It is clean in all the places that are accessible so I don't th
Make sure the charger is working first. You can test it with a voltmeter. If it's ok then the power switch is the second most likely place. Then on to the motor and wiring. could be a loose wire connector.
Dec 13, 2014 | Dyson DC40 Multi-floor Vacuum DC40
Today I bought an Electrolux Jet Max ZJM6840 I need to register it on line but it will not connect to Registration site. I am writing from Napier N.Z. Is there a NZ address for Warranty Registration?
Welcome to Electrolux Online Product Registration
Thank you for choosing this Electrolux product. Please take a few minutes now to register your purchase.
All information will be collected and processed in accordance with the Privacy Act (Cth) 1988 and the New Zealand Privacy Act 1993.
PS. Please remember me when you win the $10,000 draw.
Cheers!
Jun 20, 2011 | Electrolux Vacuums
I have a Necchi model 3205 in December 2010 and For no reason the upper tension knob pop off and all the inner springs and the washers like things went accross the floor I would like to know the name off a...
Email or contact these folks and see if they can help you:
Mario Necchi Import & Export Inc.
Fax: (450) 653-6160
Saint-Bruno, Quebec, Canada
E-Mail: necchi@total.net
or
http://www.necchi-importexport.com/contact1.htm
Email for main corporate site: info@necchi.it
Thanks for choosing FixYa,
Kelly
May 17, 2011 | Vacuums
Recently bought electolux hoover , used it at weekend to hoover stairs and have noticed that it has burnt two small holes in my carpet , is there a phone num or address that i can send a complaint to
Oct 12, 2009 | Vacuums
Service problem
remove the inlet pipe of u v chamber and pass the water for 10 mins. again reconnect and switch the machine on.......should work now :)
Jul 01, 2008 | Eureka 431A Optima Bagless Upright Vacuum
Hoover Savvy on-off switch does not work (very intermittant)
Hi All-
I found the solution to this issue. You need to take the switch apart. Having a set of small jewelers screwdrivers from radio shack helps a lot.
First, take the switch enclosure off to expose the mechanics of the switch. There are 3 clips on either side that need to be worked free.
There are 4 springs inside the switch that push down 2 metal contacts (one other spring is used to hold the switch in position). If you expand all 4 springs (stretch them out about double there normal size) the increased pressure helps the switch make more solid contact and prevents arching which is what ruins the switch in the first place. After you stretch the 4 springs be sure to clean up the contacts on the switch chassis with a wire brush.
On the slider part of the switch there are 2 contacts which also need to be cleaned up. If you have a dremil tool use it to file a point on opposite the ends of the messed up contact. Be sure there are no burs after making the points . If there are burs the contacts will hang up and springs can't do there job. This is because there are slots the contacts need to float in on the plastic slide.
With the 4 springs stretched out it will be very difficult to put the switch back together. However, with some patients, mini needle nose pliers and jewelers screwdriver set you can be successful.
You may want take the switch circuit board off the vac before putting the switch back together (to do this remove the handle). The switch is much easier to put back together removed from the vac and on a clean well lit table. Assemble the switch in a place where you can find small parts on the floor if the contacts or springs shoot out during reassembly
This hoover savvy runs like a champ now, no more arching in the switch to destroy the contacts.
I would only attempt this if you are mechanically inclined… worst case scenario however is you break the switch and need to order the replacement though… oh yea make sure the thing is unplugged when you do the above procedure.
Dustin
Nov 24, 2007 | Hoover U8145-900 Savvy Bagless Upright...
Vacuums Logo
22 people viewed this question
Top Hoover Vacuums Experts
Gerry Harvey
Gerry Harvey
Are you a Hoover Vacuum Expert? Answer questions, earn points and help others
