Question about Lexmark C532n Color Laser Printer
Display is blank (C532N) I have two different diagnosis from Lexmark - one says replace main board, other says replace display. Anyone else have this problem?
Look at the web interface.
Posted on Jul 19, 2012
I talked to Lexmark tech support they say We should replcae the display. Anyone knows how to clear the red LED error without having the view of the display?
Posted on Nov 05, 2009
I have a c532n printer and am getting an error960 service
This error indicates that the system board's on-board memory has failed.Try to power the printer off and wait 15 seconds. Then power the printer back on.
If this doesn't resolve the issue, I suggest you contact Lexmark Technical Support.
Aug 24, 2011 | Lexmark C532n Color Laser Printer
Lexmark c532n no screen? Is there a fix for the screen or just has to be replaced?
Turn the printer off, wait about 10 seconds, and then turn the printer back on. If Performing Self Test and Ready do not appear, turn the printer off and contact Lexmark Technical Support.
Mar 04, 2011 | Lexmark C532n Color Laser Printer
Service 960 memory error- r for my Lexmark C532n printer
A 960 RAM MEMORY FAILURE message indicates a failure of the RAM MEMORY that is soldered onto the printer's main controller/system board.
If the printer is displaying a 960 memory error.
1. Power off the printer.
2. If you have any extra memory SIMMs or code SIMMs installed in the printer, remove them.
3. Power on the printer.
4. If the 960 error continues, the main controller/system board will probably need to be replaced.
5. If the 960 error does not return, try printing a few documents.
6. If these documents print correctly, the cause of the 960 memory error is probably one of the SIMMs you just removed.
To confirm this, do the following:
1. Turn off the printer and reinstall each SIMM one at a time.
2. After you install each memory card, power the printer back on and try printing. If the error returns as soon as you install a particular SIMM, that SIMM is probably the cause of the error message.
Nov 08, 2010 | Lexmark C530dn Laser Printer
Model Lexmark C532N - Has two paper trays - the top tray holds the regular 8.5 x 11 paper the bottom tray holds the legal 8.5 x 14 - It was set up to automatically choose the correct size paper. Now we...
was this printer removed or installed while it was powered on? if it was the control board in the lower tray will need to be replaced this can and often does short the board. does the tray show up in the paper menus?
Aug 05, 2010 | Lexmark C532n Color Laser Printer
How do i clear a 920.08 engine self test error on my lexmark
Try to replace the fuser. If that doesn't help, system board may need to be replaced. But I strongly suggest you contact Lexmark Technical Support to further investigate the problem. Thanks.
Jul 27, 2010 | Lexmark C532n Color Laser Printer
Lexmark c532n prints smudges on page
The problem could be caused by the photoconductor units. Try to swap the affected photoconductor units (like swap the magenta with black and cyan with yellow). If problem still occurs, then the photoconductors need replacement. I suggest you contact Lexmark Technical Support for assistance. Thanks
Jul 26, 2010 | Lexmark C532n Color Laser Printer
Yamaha htr 5550 stereo receiver blank display. It
I would suggest a quick resoldering of the flatcable connectors, both on the display board as well as on the main board. That should fix the problem.
Oct 20, 2009 | Audio Players & Recorders
Dell 6000 laptop screen blanks out - bought new screen
ManualsBack to Contents Page
Display Assembly and Display LatchDell Inspiron™ 6000 Service Manual
Display Assembly
Display Bezel
Display Panel
Display Latch
Display AssemblyRemoving the Display AssemblyCAUTION: Before you perform the following procedures, see the safety instructions in the Product Information Guide.NOTICE: To avoid electrostatic discharge, ground yourself by using a wrist grounding strap or by periodically touching an unpainted metal surface (such as the back panel) on the computer.NOTICE: To avoid damaging the system board, you must remove the main battery before you begin working inside the computer.
  1. Follow the instructions in "Preparing to Work Inside the Computer."
  2. Remove the hinge cover.
  3. Remove the keyboard.
  4. Open the display all the way (180 degrees) so that it lies flat against your work surface.
  5. Remove the four M2.5 x 5-mm screws (two on each side) that connect the display assembly to the computer.
  6. Loosen the screw that connects the grounding wire to the system board.
  7. Use the pull-tab to disconnect the display cable from the system board.
  8. If a wireless Mini PCI card is installed, disconnect the antenna cables from the card.
  9. Lift the display assembly from the computer.
Apr 06, 2009 | Dell Inspiron 6000 Notebook
Lexmark C532n Color Laser Printer Logo
457 people viewed this question
Top Lexmark Office Equipment & Supplies Experts
Don  Farrell
Don Farrell
Are you a Lexmark Office Equipment and Supply Expert? Answer questions, earn points and help others
