Question about Sony KDF-E50A10 50 in. LCD HDTV
Standby lamp keeps on flashing.
I have KDL-40v2500 TV. While watching the tv, suddenly the standby lamp started flashing. Now I can not watch the TV.
  • 10,594 Answers
Seems its time to replace lamp in your Sony KDF-E50A10
When lamp in TV got weak in result, standby light start blinking and if lamp got broken / dead, you will see lamp light ON.
Lamp replacement procedure is easy and written in user manual, please buy Sony original lamp for TV safety.
Thanks.
Posted on Jul 30, 2009
When turning on tv. screen will display Bravia image & then go blank. red light flashes SIX times
Power off the television. Wait a few minutes, then power it back on. If this does not correct the issue leave the power on, point your remote control towards the Sony television and hold the down arrow button. While holding the down arrow button press the "Power" button. Release the down arrow button and the Sony TVicon1.png will reset itself to factory settings. Once the television performs a scan on itself your problem should be gone.
Good Luck Ed Pinero
Read more: How to Troubleshoot the Standby Indicator Flashing on a Sony TV ' eHow.com http://www.ehow.com/how_5925008_troubleshoot-indicator-flashing-sony-tv.html#ixzz2KBk1cWbu
Feb 02, 2013 | Sony BRAVIA KDL-40V2500 40 in. LCD HDTV
While watching my sony KDL-46NX810 TV its suddenly shut off and starts blinking 3 times red standby light. Please have me inform, what this error means and how to repair or what to replace on my...
Hi Gerard,
3 flashes of the led light on most KDL series is a power supply malfunction. To confirm the error code, lets access the self diagnostic screen by following the steps below.
Unplug the unit from the outlet for 30 minutes and then plug it back in and check if the symptoms remain the same. Wait until the led light stops from flashing and then press in rapid sequence the "Display", "Channel 5", "Volume (-)", "Power" button key on the remote control. Self diagnostic screen will be display. Let me know the result.
Jdvillanueva
Nov 09, 2011 | Sony KDL-46NX810 46 in. 3D LCD TV
Tv does not turn on. Standby button has 3 quick flashes and then a pause then 3 quick flashes again repeatedly.
3 blinks pertains to a problem with panel voltage. May need to have power supply replaced or Inverter module if available.
Aug 11, 2011 | Sony BRAVIA KDL-40V2500 40 in. LCD HDTV
I was watching TV Sony KDL40s2000 and sudenly the TV shuts down and a red ligth (standby) keep flashing!! I cant do anything! It wont turn on or off!! I need help
It is giving you a diagnostic result by the # of flashes. count the number of flashes before it pauses and repeats. It could be the lamp as well, however, this unit has some common board failures. post a comment with your results and I can help you further diagnose the problem. If you are "handy" the parts can be found inexpensively online. and it's generally a plug n play swapout. Hope this is a good start...
Jun 02, 2011 | Sony BRAVIA KDL-40S2000 40 in. LCD HDTV
Black screen , red standby light flashing 4x repeatedly, unplug it and the green light comes on momentarily then resorts to 4 red flashing lighrts again. Sony KDL-40V2500 approx. 4yrs old. HDMI cables are...
4 blinks indicated of backlight malfunction. The unit shutsdown to avoid overload to the inverter board.
Check the backlights, busted backlight has a physical indication of fault like blackened end, crack end. You must replaced the busted one and your unit will back to normal operation again.
Hope I helped you.
Have a nice day!
Thanks for using Fixya.
May 16, 2011 | Sony BRAVIA KDL-40V2500 40 in. LCD HDTV
When I was watching TV today my Sony Bravia KDL-40V4100 just swutched off by itself. After 15 minutes or so it came back on by itself, I shut it off soon after. Later on today after watching TV for 15...
When tv it shutting itself off by it own does the tv power LED light indication flashes?Tv turn on now,the tv power light indication,just flashes?Yes,than ur tv power supply board is the causes and the problems.That the board,where the power a/c cord plug into it.Tries websites like Shopjimmy.com,Ebay.com to buy a whole refurbish power supply board for the replacement.
Dec 12, 2010 | Sony BRAVIA KDL-40V2500 40 in. LCD HDTV
Sony Bravia KDL 46", no picture, standby light blinks 4 times
Since the TV is still receiving power, the problem is going to be with the TV's mainboard.  After you unplugged the TV and plugged it back in, you said the power light went out again, so I assume the standby light wasn't flashing again?  The flashing standby light is indicating an error code so my suggestion is to contact Sony for service options regardless if there is a warranty or not because service is the only solution to this situation.  Don't forget to provide them the error code or 4 flashes repeating.
Mar 25, 2009 | Sony BRAVIA KDL-46S2000 46 in. LCD HDTV
Have a new Sony Bravia KDL-40W500 keeps turning off into standby mode with 8 flashes.
There is some confusion on the model (KDL-40W500 vs. KDL-40V2500), so I will direct this toward the 40V2500.
On the KDL-40V2500, an 8X blink means the scan processer has gone bad, and the BU board needs to be replaced. If the problem is intermittent, the the AU board might be the problem, but if it all the time, bank on the BU.
A competent repair shop should be able to help you, or you can try calling Sony directly for assitance.
Hope this helps you...
Jan 05, 2009 | Sony BRAVIA KDL-40V2500 40 in. LCD HDTV
Normal picture mode make the sharper picture quality but smaller screen apparance
If the broadcast is in 4:3 (square) then either you can have the black bars on the side, or the TV can stretch the image to fill the screen.
Nothing wrong with your set. The broadcast must be in 16:9 to fil the screen.
Aug 07, 2008 | Sony BRAVIA KDL-40V2500 40 in. LCD HDTV
Sony KDF-E50A10 50 in. LCD HDTV Logo
1,001 people viewed this question
Top Sony Televison & Video Experts
Jerry Greenberg
Jerry Greenberg
Are you a Sony Televison and Video Expert? Answer questions, earn points and help others
