Question about Jl Audio 500/1 Car Audio Amplifier
Green power light on JL Audio 500/1 but no output
My son ran this amp with the low voltage yellow indicator on until it just quit working.
I traced all the wires and found a half corroded ground connection wire that was reused from a previous 10 year old install.
Replaced the ground with a new one and got a green light for power with no output.
There is zero signs of anything burnt inside the amp and no burnt smell.
The speaker wires are 18" long 12 ga and hooked up correctly to the sub.
  • gtheel Aug 02, 2009
    Where can I buy transistors for this amp?
  • 3,267 Answers
Its the power transistors that would be affected by low voltage. It delivered till it finally gave up 'cos the output wattage to be generated at low voltage means more current flowing through the equipment. This high current will adversely affect all small solenoid valves & transistors and IC's. Even failure of one section of any IC is rarely detectable with the naked eye. It has to be thoroughly checked with a multi-meter to assess the damage correctly......sodeep
Posted on Jul 30, 2009
  • Sudeep Chatterjee
    Sudeep Chatterjee Aug 03, 2009
    First of all it has to be checked with a multimeter to determine which components are damaged and nowadays the power transistors have been replaced with IC's. So try to repair it only if you are familiar with repairing electronic equipments...............sodeep
Sleuthing a 300/4 low-ohm issue. 300/4 amp history: unknown. just connected today whole system yesterday/today: head unit, 300/4(to 4 polk 6.5" component speakers brand new) 1000/1 (4-W3's),...
Are you sure you getting enough power to push everything. I have seen when the voltage is too low coming in, the amps will shut down so they don't overheat. Once they've cooled off and the volume level is lowered they will kick in again. Low voltage and a heavy draw will create massive amounts of heat.
May 24, 2011 | Jl Audio 500/1 Car Audio Amplifier
My output rca jacks are not working. where can i buy some more to fix my amp?
The thing about Jl audio amp is that you have to choose between using the sub output or the the rca output. In order to use the rca output you will have to switch a switch next to the gain level. And it should be label low/high voltage. If you want to use the sub output then leave it on low if you want to use the rca output then switch it to high. I hope that solve your problem
Oct 11, 2009 | Jl Audio 500/1 Car Audio Amplifier
Jl audio 1000/1 low voltage -keeps shutting off at high volume
You should definitely upgrade the power wire to the sub amp to 4 gauge -absolutely your choking your amp its starving for current-poor thing is starving !!!!!!!
Apr 16, 2009 | Jl Audio 1000/1 Car Audio Amplifier
JL Audio 500/1 Amp, The green power light is on but no sound!
Check to be sure you are on the correct outputs on the head unit, and be sure the outputs do not have a separate volume control.
Mar 06, 2009 | Jl Audio 500/1 Car Audio Amplifier
I HAVE A JL AUDIO MONOBLOCK AMP 250
It indicating that the power output is too loud and possibility of speakers may get damaged if played at this volume for long periods. When the loudest sound is played the led light mightshow its loosing its brightness and dims in time with the sound level.......................sodeep
Jan 17, 2009 | Jl Audio 500/1 Car Audio Amplifier
Jl amp
The amber is the low impedance indicator and can mean that the impedance of the load is too low or there is an internal fault (shorted output transistors).
The blue LED indicates that the voltage is too low. This can be due to a bad connection or low battery voltage.You need to measure the DC voltage across the B+ and ground terminals of the amp to confirm that they're at or above 12v.
Let me know if you have any other questions.
Aug 11, 2008 | Jl Audio 1000/1 Car Audio Amplifier
Jl audio 500-5
Assuming that you've confirmed that the speaker is in good working order and that the wiring isn't shorted in any way...
There are separate power supplies for the high and low amplifiers. It's possible that the one for the sub output has failed. If that's the case, the output transistors probably failed and that's what damaged the supply.
Generally, I'm willing to help people repair their amps but this is a large, complex amplifier and it should be repaired by a qualified technician.
Apr 18, 2008 | Jl Audio 500/5 Car Audio Amplifier
Jl 500/1 no sound, green light
This is an indication that the MOSFETs are ok but the driver stages may have a problem. Get a schematic find the pre-amp stages and test the voltages levels there as compared to the schematic. I do believe that you will find the problem in the pre-driver pre-amp atages.
Sep 03, 2007 | Jl Audio 500/1 Car Audio Amplifier
is there any sound?
Aug 21, 2007 | Jl Audio 500/5 Car Audio Amplifier
Jl Audio 500/1 Car Audio Amplifier Logo
906 people viewed this question
Top Jl Audio Car Audio & Video Experts
Mark Skinner
Tygh Duval
Tygh Duval
Matthew Spark
Matthew Spark
Are you a Jl Audio Car Audio and Video Expert? Answer questions, earn points and help others
