Question about Honeywell Heating & Cooling
Honeywell thermostat 3100 won't shut off - Honeywell Heating & Cooling
    Habit-Forming:
  • 102 Answers
So you lower the set temp and the furnace wont shut off? If you take the thermostat off of the wired sub base does it shut off? If it shuts off, bad thermostat
Posted on Jan 17, 2018
SOURCE:
I have a Honeywell Rth 111 series unit was running all the time so took the cover off and replaced the batteries but unit will not turn off help
So your saying the furnace will not shut off? If you take the thermostat off the sub-base will the furnace shut off? If the furnace does shut off with the thermostat disconnected from the sub-base then you have a bad thermostat
Jan 17, 2018 | Honeywell Heating & Cooling
Heating won't go off
Honeywell manuals are online for all its thermostats.
Google search your model number.
Model number is on back of thermostat.
Copy following link for Honeywell resources:
http://yourhome.honeywell.com/home/Applications/FindYourModelNumber.aspx
Honeywell manuals are detailed, but each pdf file can be word-searched.
More resources:
http://www.ehow.com/how_6596826_troubleshoot-honeywell-thermostats.html
If you need further help, I’m available over the phone at https://www.6ya.com/expert/gene_9f0ef4df2f9897e7
Jun 25, 2012 | Hardware & Accessories
Coleman 7995-856 a/c blower won't shut off
Is the fan in the auto position?
If you need further help, reach me via phone at https://www.6ya.com/expert/thomas_092728000e6acb79
Feb 05, 2018 | Coleman Heating & Cooling
What should ther honeywell relay read in ohms on a r8222u 1006
did you check power to the gas valve? Pilot lit? Or electronic pilot on? Need more info on boiler.
Nov 05, 2011 | Honeywell Programmable Thermostat Heater
Fan blows but no heat/fan won,t shut on and off in the auto mode
Certain gas furnaces will default to high speed fan ON any time a high temp limit opens or the 24 volt transformer fails. Please respond to describe your make of furnace and if the fan runs only when your thermostat calls for heat or if that makes a difference.
Dec 29, 2009 | Honeywell Programmable Thermostat Heater
The heater runs and doesn't want to shut itsself off
check the wire to the thermometor then if the wire is ok replace the thermostat
Mar 03, 2009 | Honeywell Programmable Thermostat Heater
HONEYWELL T-STAT
it is always advisable to shut down the main swith to avoid further issues in replacing thermostat, if you follow the right color coding this should be no prob, unless otherwise it cannot detect the right temp then it will not stop until it reaches and senses the right temp.
Dec 21, 2008 | Honeywell Programmable Thermostat Heater
Honeywell 5+2 day programmable thermostat will keep heating to 29 degrees!
Is sounds like you wired it correctly, The black is a little unusual perhaps its blue, anyway, try disconnecting the wires from the thermostat and see if it shuts off. If so, then it may need to re calibrated. I will need some more info to help you anymore.
Dec 03, 2007 | Honeywell CT3200 5-2 Day Electronic...
Heating & Cooling Logo
375 people viewed this question
Top Honeywell Heating & Cooling Experts
Bill Long
Paul Carew
Are you a Honeywell Heating and Cooling Expert? Answer questions, earn points and help others
