Question about Amana Easy Reach AFD2535DE Bottom Freezer Refrigerator
Not cold - Amana Easy Reach AFD2535DE Bottom Freezer Refrigerator
  • Mike Smith
    Mike Smith May 11, 2010
    Brand and model number and more symptoms needed .
    Champion:
  • 363 Answers
If you are talking about the refrigerator not cooling, but the freezer is then it appears that the circulating fan is wearing out. This problem is very hard to diagnose as the fan still spins but it does not spin fast enough to circulate the chilled air thru the freezer and refrigerator. The minimum cost to repair/replace the fan assembly is around$300.00.
Posted on Jul 30, 2009
Toyota rav4 diesel starting problems from cold it take a long time to start up when i leve it over night..
Its cold start issues:----
Go through the list of help links mentioned below:----
Click the link :----
Cold start problem and vehicle shudder around 2500 to 3500 rpms
http://repairhelpcenter.blogspot.com/2012/10/cold-start-problem-and-vehicle-shudder.html
Low idle when cold out side?
http://repairhelpcenter.blogspot.com/2011/12/low-idle-when-cold-out-side.html
Ford explorer 4.0 will not idle when cold?
http://technoanswers.blogspot.in/2012/02/ford-explorer-40-will-not-idle-when.html
Automatic transmission shift lever hard to move on cold mornings?
http://technoanswers.blogspot.com/2012/01/automatic-transmission-shift-lever-hard.html
Car won't start when cold?
http://schematicsdiagram.blogspot.com/2011/12/car-wont-start-when-cold.html
These will help.
Thanks.
Dec 06, 2012 | Cars & Trucks
99 contour starts easy idles smooth, cold but dies when you start to pull out runs well when warm
These will help.
Thanks.
Dec 06, 2012 | 1999 Ford Contour
2006 nissan navara wont start in cold weather
These will help.
Thanks.
Idle fluctuates when cold 93 bonneville
These will help.
Thanks.
Nov 28, 2012 | Cars & Trucks
Hi, my washing machine isn't working in cold/cold mode but will work in hot/cold and warm/cold. Meaning that water will not come out at all. I even started it in warm/cold and tried to switch it over to...
My bet is that your cold water screen is plugged...
If your washing machine will not fill, only hot or cold will fill or is slow to fill then read these tips. I have covered many of the things that can happen in these tips…
Washing Machine Problems No Water
Washing Machine Fix Washing Machine No Water
heatman101
Aug 31, 2010 | Frigidaire Washing Machines
Maytag ensignia washer...cold water settings
You need to remove the cover and check the voltage to the cold water inlet valve. Do this with a volt meter while it is set to fill with cold water. It is most likely an AC voltage that is around 24 volts. If you have voltage then the valve is most likely bad.
Feb 16, 2018 | Maytag Ensignia 3.3 cu. ft. Top Load...
Kenmore front load washer: no cold water problem
that's odd.
if you choose cold/cold then check your hose orientation. you could have put the hot water to the cold solenoid.
or the wires have been interchange, the hot water wire was plug to the cold solenoid and the cold water wire was plug to the hot water solenoid.
or hot water is still flowing to your cold water line.
if the cold water solenoid is the problem, then there should be no water at all going to the tub.
try to experiment, try to switch to hot/hot and see what would come out...
tnx 4 using fixya,
drcool
Oct 02, 2008 | Kenmore Energy Star 44092 Front Load...
Maytag washer
It sounds like you have the hot and cold water lines to the washer reversed.  Try turning off the tap for the hot water then setting the washer to just cold wash and then  hot washif you get nothing on the cold and cold water when set to hot they are probably reversed.  Typically if the auto-temp control is broken you will only get hot or cold coming out on any setting.
Oct 01, 2008 | Maytag Neptune FAV6800AW Top Load Washer
Amana Easy Reach AFD2535DE Bottom Freezer Refrigerator Logo
117 people viewed this question
Top Amana Refrigerators Experts
Charles T Nevin
Charles T Nevin
John Tripp
John Tripp
Dan Webster
Dan Webster
Are you an Amana Refrigerator Expert? Answer questions, earn points and help others
