Question about HP Media Center m7060n PC Desktop
HP media Center m7060 will not turn on
Usually would be in sleep mode in the morning and I could just press button once and it would start up. Yesterday though, This did not work and I had to hold the button in to start up, which it did but the time and date were set back to Jan 2001. I reset the date and everything seemed fine. Came back later in the afternoon and power was off and it will not turn back on....Help!
  • 83 Answers
Yur sys has a primary prob... the start button wiring or solderin myt ve gone chec it,..
Posted on Jul 30, 2009
Turn on my monitor from sleep mode
It should turn on when you move the mouse around a bit. Otherwise, it is in hibernate and you need to push the start button for 1 second or so to wake up the computer.
Mar 01, 2015 | HP Media Center m7657c home PC - RC640AAR...
How do you turn off sleep mode on hp p3015?
Disable or enable sleep mode
  1. Press the Menu button c01779150.gif.
  2. Open each of the following menus. Press the down arrow c01779151.gif to highlight it and then press the OK button to select it.
    1. CONFIGURE DEVICE
    2. RESETS
    3. SLEEP MODE
  3. Press the up arrow or down arrow c01779152.gif/c01779151.gif to select the ON or OFF setting, and then press the OK button.
  4. Press the Menu button c01779150.gif.
Jan 09, 2013 | HP Pick Up Roller Rm1-0885 for Laserjet...
Start up from sleep mode
i'd turn off sleep mode then. have you tried to press the power button once?
Jul 18, 2012 | Acer Aspire AM5100-EF9500A PC Desktop
Vista computer HP in sleep mode. How to get it
Typically you can just press the power button once, and the computer should come out of sleep mode.
Be sure to power off your comptuer regularly to reduce risk of freezing when computer enters sleep mode
To chance Sleep Mode Settings follow instructions below:
First click on the start icon at the bottom left hand corner of your screen and type into the start search box :power options , now click on "power options" it will be at the top under programs, next, under perfered plans section you need to click on " change plan settings" that is under the plan that has already been selected, this plan has a blue dot on it , come down to and click on " change advanced power settings" , now you need to scroll down to "multimedia settings " in the window that has just been displayed, click on it's box to open it up , then do the same to " when sharing media "' now click on the text to the right of "setting" it is light blue ,this will high light it and you now click on the little arrow . select " allow the computer to sleep ", lastly click on ok!
Jan 06, 2010 | HP Pavilion dv9000z Notebook
HP w2207 monitor keeps "going to sleep" then it will not come back on and says no input signal.
most times this is indicator of a video card problem, most times you try booting in to vga mode and see does it go to sleep. if it does not go to sleap you video driver is bad and needs to be reinstalled. if it does go to sleep it is usually video card issue. to boot in to vga mode turn ur pc off and once u press on to put it back on start pressing button F8 and advanced menu will come up and you have to choose boot in to vga mode. if this does not work same way go to safe mode with networking and reinstall video driver by going in to device manager.
Nov 27, 2009 | HP w2207 Monitor
My computer isn't working...it's in sleep mode and won't come out of sleep mode. I can't access anything - not even the start menu. Help!
Hold down the power button until it turns off. Turn oit back on and tap F8. Choose last know good configuration from the menu.
Jun 08, 2009 | HP Pavilion Media Center a1330n - AMD...
How do you turn off the sleep mode in a HP 3600 printer?
My printer will not print after sitting for about 30 minutes. As soon as I turn it off and then back on the job I previously sent, prints out. I tried changing the amount of time before it goes to sleep but this does not correct it and does not seem to be related. You can hit the check mark to wake it up but it still will not print until turned off and then on.
Mar 25, 2009 | HP LaserJet 3600n Printer
Sleep Mode Lockup on Dell Inspirion 530 w/ Vista
Try hitting the "Windows" key on your keyboard to bring it out of sleep mode. The "Windows" key is generally found on the bottom row of the keyboard, near the Alt and Ctrl keys, and it has no letters on it, just the Windows logo. That key brings my Windows Vista machines out of sleep mode when other keys won't.
As for the power button, anytime you need to force a computer to turn off, you can press and hold the power button to do so. Usually, you need to hold the power button for 5-10 seconds and it will shut down. Use this option with caution, as it turns the computer off without running through the shutdown process and can cause you to lose data.
Hope this helps.
Mar 08, 2009 | HP Media Center m7060n PC Desktop
Monitor goes into Sleep Mode immediatly upon turning on computer
I have a LCD panel it is connect to to the LCD. I need to change a setting on the computer to make it stop going into sleep mode, however, now that it's in sleep mode, how do I get out of that so I can make the change?
Jan 09, 2009 | HP Pavilion F1503 15" LCD Flat Panel...
Monitor going to sleep
Within the control panel select performance and maintenance within that select power options.
Once in there check that the power is set for desktop computer and that never sleep on monitor or Hard disks.
If this doesn't work then press the OSD button on the monitor and scroll through the setting and make sure that there isn't one that is auto sleep mode after and amount of time.
Thanks J
Jan 02, 2008 | HP Pavilion Media Center TV m7360n...
HP Media Center m7060n PC Desktop Logo
213 people viewed this question
Top HP Computers & Internet Experts
Tony
Are you a HP Computer and Internet Expert? Answer questions, earn points and help others
