Just change brushers on beko wma641w and now water wont go in washer
  • 24 Answers
Make sure you have a circut through the brushes
Posted on Aug 05, 2009
Beko dishwasher doesn always fill with water but makes sounds as if it does. Other times it works great any ideas?
depending on chosen wash cycle washers are not always supposed to 'fill' just use enough for that cycle .
If you mean sometimes no water at all and sometimes water with same settings check hoses and valves .
make sure valves are fully open hoses securely attached and hoses from valves to washer are not pinched twisted or damaged.
Hopefully the water not getting in the washer isn't leaking all over your floor below the washer.
Jul 18, 2016 | Beko Dishwashers
I have a beko 4311w dish washer that wont empty. i emptyed the water manually and have checked all filters and hoses and all seemed to be clean.then switched back on and machine completed one complete...
The motor runs in one direction to wash and the opposite direction to pump out the water. Look at the motor direction controls to see what is starting to fail.
Jan 03, 2015 | Beko Dishwashers
Why wont it spin fast
Hi if your Beko washing machine has a spin problem then you have to check the carbon brushes first.
Also check all waste pipes are clear and inspect the pump I have included this video below. At our website I am doing self diagnostic videos on these beko's as we speak so all tutorials will be in this link below
How to replace Beko Washing Machine Motor Carbon Brushes
Aug 08, 2014 | Beko WME7247W Washing Machine
Water control valve washer
Hi carl if your Beko WM5140W washing machine wont drain or has a spin problem then you have to check the carbon brushes first.
you might find this test video helpful but only do it if you have checked the motor
Mar 11, 2014 | Beko WM5140W
Beko wma641w wont spin?
Hi if your beko wma641w washing machine wont drain or has a spin problem then you have to check the carbon brushes first.
Jan 24, 2013 | Washing Machines
Model 417.29042992 pumps out water but wont spin
it could be your motor brushers the only way to check is remove the motor and you will see two plasic holders on each side of the motor armature undue the 2 screws and the brushers will come out they should be 1.5 inches long and shinny on the ends also sometimes they can get stuck in they might pull out a bit to get you going if not replace them you can get them on line from euro spares just type in your make model and motor brushers if i can help more let me know
Nov 10, 2011 | Kenmore Front Load Washer
I have a beko DWD 5410 dish washer and it wont fill with water. I can hear what sounds like the pump but no water?
It probably has a bad watyer control valve, that needs replace., Or voltage is not getting to it.
Jul 08, 2011 | Televison & Video
BEKO WMA641W washing machine not draining but pump working.
Are you sure the pump is working, or it the motor thats running? If the pump is truly working, there is a clog in pump or line. If the motor is working, but the pump is not, you will need to replace. You can usually buy a replacement pump for the washing machine for around $50. They are usually easy to install for a beginner DYI. Make sure you know the easiest way to remove washing machine housing to get at pump and motor. Unplug entire unit. Remove 2 hoses for pump and either screws or brackets to remove housing. BTW if the washing machine won't drain, you are going to have a bunch of water that gravity wants to dump out of machine. Bring pump to parts dealer for exact match.
Aug 21, 2009 | Washing Machines
Beko wma641w reset
hi
to reset these al you do is press and hold the start button for about 5 seconds then it should reset if not then you have a faulty pcb
regards
Mar 22, 2009 | Washing Machines
Washing Machines Logo
162 people viewed this question
Top Washing Machines Experts
