Question about Harley Davidson Harley-Davidson Motorcycle Desktop Telephone
Will not engage starter and headlight will not work. battery is fully charged. brake lights, horn, turn signals all work.
Bad ignition switch.
Posted on Jul 31, 2009
Wiring diagram
Sounds like a battery connection,try this ,turn the headlights on,have someone watch or whatever,try to start it,if the lights go out,it's a poor connection(probably at the battery) if they stay on,it's a starter issue.
Jan 16, 2014 | 1992 Chevrolet K1500
Headlights not working, rpm gage not lighting up, neutrel light not coming on
Hi Anonymous, and the usual suspects are:
1.Ignition/Light Key Switch not in IGNITION position.
2.Engine Stop switch in the OFF position.
3.Discharged battery, loose or corroded connections (solenoid chatters).
4. Bank Angle Sensor tripped and Ignition/Light Key Switch not cycled to Off and then back to Ignition
5. Starter control circuit, relay or solenoid faulty.
6. Electric starter shaft pinion gear not engaging or over-running clutch slipping.
For a prime suspect please visit website below and good Luck.
Harley Davidson Sportster error codes and how to access them
Dec 15, 2013 | 2000 Harley Davidson XLH Sportster 883...
Have not had any problems with vehicle. Went out to start it tonight and it would not start. Sounds like engine is trying to turn over, but it won't. Light comes on indicating "service emission
Does the engine turn over fast or is it sluggish? Headlights bright or dim? If engine turns over sluggish and headlights are dim, I'd suspect a defective/discharged battery or possibly a charging problem causing the battery problem. Start by making sure the battery cable terminals at the battery posts are clean and tight.
Put a voltmeter across the battery posts with the engine off, you should measure 12.8 volts if the battery is fully charged. Less voltage and the battery is not fully charged. When you try to start the engine, the battery voltage will drop momentarily when the starter is engaged. I would not be surprised to see the voltage to drop to 8-9 volts when the starter is engaged and the engine turning over. If it drops to a lower voltage, I would suspect a battery problem. The "service emmisions" light I would expect to be a secondary indication and resolve itself once the engine starting problem is resolved.
Nov 04, 2012 | 2007 Ford Escape
My 2000 lincoln ls doesn't crank or click when trying to start it, it does nothing? all the lights work, radio, signals and horn, I checked the fuel relay and the starter relay and the ignition fu
Sounds like an Ignition Module or similar device. Does it have an alarm? Turn the key to ON - not start - and put into Drive and then back into Park. It may be the shifter isn't fully engaged. Also, w/your FOOT ON THE BRAKE shift to Neutral and try to start it.
GL,
Td
Oct 01, 2012 | 2000 Lincoln LS
2007 grand prix won't start but lights and horn work
Your battery is to low on power it needs a good charge, or replace it is the best option for a brand new one!
Feb 27, 2012 | 2007 Pontiac Grand Prix
I disconnected my battery and cleaned the cables and re-connected. Now my car will not start. The lights work the horn etc. What do i need to do to start the engine?
the battery may be faulty,just because the lights & horn work doesn't mean that the battery is enough power to start the engine the battery may have a weak sell that breaks down when you engage the starter try turning the headlights on & then try to start the engine & see how dull the headlights become,if they almost go out the battery is very low or faulty......hope this helps......cheers.
Aug 16, 2011 | Jaguar XJ6 Cars & Trucks
I have a k100rs when i go to push the turn signals the hazard lights will come on when i beep horn the hazerds come on also the headlights dont work and starter wil not engage
is ur batt charged at 12.6volts--chec wiring for flaws n corrosion--alternator cud be bad also--du u hav a clymer shop manual?
Nov 02, 2010 | 1988 BMW K 100 RT
My 93 Chevy Cheyenne has no headlights, tail lights, horn.
ck the wire that comes from starter,,see if it didnt rotted off,,
Jan 28, 2010 | Chevrolet 1500 Cars & Trucks
2001 vstar 1100 classic, issue is when start button is pressed all I hear is a click (one only). battery appears good and even with a boost it still just clicks. Can be push started OK. is this te...
If you turn the key on, you should get a strong headlight, horn and brake light when the battery is strong. If these are weak, then the battery is dying. If the battery is strong, hitting the start button should turn the headlight OFF momentarily. If there is no change or the headlight is not coming on then the starter button could be damaged. The battery voltage should stay above 11 volts when you are cranking the engine or loading the electrical system with brake light, horn or high beam activation.
The starter solenoid is down by the battery and if you jump across the big two terminals with a screwdriver (bike in neutral, please!) that will jumper the battery power directly to the starter motor. If the battery is good, the starter should start to spin the motor over. If the battery is good and there is no sound, then the starter motor is bad. If the starter motor spins over, either the starter solenoid is bad or the wiring to it is defective.
You need a a 12v test light to check the starter solenoid wiring circuits. A good Volt meter will tell you about the state of the battery (should be over 12v resting), as well as whether the charging system is working, once you have determined that the battery is okay. You need to monitor the charging system once the bike is running to see if that is part of the problem or not. It should crank out upwards of 13.5 volts when you rev it up to about 2,500 rpms.
Check the web for V-star forums and groups who may know about any problems unique to this model.
Jan 19, 2010 | 2001 Yamaha V Star 1100 Classic
Electrical problem,possibly relay?
Check for busted fuse in the fusebox.
Sep 27, 2009 | 1988 BMW K 100 RT
Lands Phones Logo
207 people viewed this question
Top Harley Davidson Lands Phones Experts
ted dux
WTF Chuck.....
WTF Chuck.....
Are you a Harley Davidson Lands Phone Expert? Answer questions, earn points and help others
