Question about Dell Computers & Internet
I have a red vertical line on my dell inspiron laptop.How do I remove it?,please
    President:
  • 2,185 Answers
Try connecting an external monitor to the Dell Inspiron 9300and see if the vertical line is also present on the monitor. If themonitor display is fine, then your laptop’s LCD display panel isdefective. If the monitor also displays the vertical line, then yourproblem is with either the video card or motherboard located insideyour laptop.
Another answer:
run the PSA diagnostics. to do so, press and holdany non-keyboard button( like the internet hotkey or access directbutton or even the speaker mute button) and then press the power buttonand power up your system. if your inspiron doesn't have a non-kbbutton, then press the <fn> key.
release both the buttons and the diagnostics begin to run.after thediags finish. if the monitor is working fine, it'll simply say"passed". however, if it fails it would emit a few beep codes.carefully check those beep codes:
1.) if you get a 3-3-3 or a 3-3-4 error beeps, then we use the LCDbuilt in self-test (BIST). boot to PSA diagnostics again. Watch thescreen and listen for the color bar test prompt tones emitted by thePSA Diagnostics. Press <N> or wait approximately 30 seconds tofail the color bar test. The system will emit a 3-3-3 or 3-3-4 PSAerror after failing the color bar test. Wait for two iterations of thefailure code then press <Y>.
Watch for the BIST color generation and listen for the single beeps that indicate LCD BIST is running.
NOTE: Patterns of flashing color should appear on the screen. Withevery color change, an audible beep will be heard. If the patterns ofcolor do not appear, and the beeps are audible, an LCD failure may bethe issue. If the patterns of color appear, a video card or motherboardfailure may be the issue.
2.)if you get an error code apart from 3-3-3 or 3-3-4 :Ensure thesystem is powered off. Press and hold the <Fn> key and press thepower button to power the system on. Release both buttons.
The PSA diagnostics sequence begins. Make note of any alert tones or error messages.
error codes:
123- memory fails
141,142,143,144,145,146 hard drive error
147- IDE optical drive fails
148 optical drive built in test fails
122-memory test initialization test failure
111- fatal diagnostics exception.
i really hope you dont get any of these. these will help you determine,if you need to change the LCD. when you call dell, they will run youthrough these steps anyways. so if you finish them beforehand, you wontpay much to talk to them. cheerio then.
http://answers.yahoo.com/question/index?qid=20060722190406AAHejuS
Posted on Jul 30, 2009
Dell Inspiron 9300 Vertical lines
Try re-seating and cleaning, the connection between the display and the Motherboard, (Electronics cotton swab and rubbing alcohol, be sure not to leave any of the cotton fuzz on the connectors.) It will be below the keyboard. If that doesn't result in any improvement, the display will probably need replacing. You can find the complete tear-down guide here: http://support.dell.com/support/edocs/systems/ins9300/sm/index.htm
Jan 04, 2012 | Dell Inspiron 9300 Notebook
Try re-seating and cleaning, the connection between the display and the Motherboard, (Electronics cotton swab and rubbing alcohol, be sure not to leave any of the cotton fuzz on the connectors.) It will be below the keyboard. If that doesn't result in any improvement, the display will probably need replacing. You can find the complete tear-down guide here:http://support.dell.com/support/edocs/systems/ins9300/sm/index.htm
THE SCREEN ON MY dell iNSPIRON LAPTOP-2" FROM THE
It might be failure within the main board, possible hardware issues and so will need attention from Dell support.
Jul 31, 2011 | Dell Inspiron 1525 Laptop
Dell Inspiron 1501 Laptop-6'' Red Vertical Line
The color red and especially red colored lines or a pinkish hue are indicative of an impending screen failure. The only other possibility is that the data cable on the left backside of the lcd panel may be loose at the socket or on the motherboard. 9 times out of 10 though, it is the lcd panel that it failing.
Jan 17, 2010 | Computers & Internet
Dell 1720 screen
If you can see the vertical lines during POST, try to check the vertical lines in BIOS. If the vertical lines are there in BIOS, the only thing you can do is to replace your LCD screen.
Oct 31, 2009 | Dell Inspiron 1720 Notebook
Hi. I have a Dell Inspiron laptop. And I have
You need to replace the LCD screen. Or use an external monitor 24/7.
sorry
Sep 25, 2009 | Compaq Presario M2000 Notebook
Red vertical line going down the screen'
That shows a bad LCD screen that needs to be replaced. Unfortunately it's a hardware problem.
If you laptop is under warranty, you need to take it to a Dell Warranty/Service centre and have the LCD replaced.
Feb 22, 2009 | Dell Inspiron E1505 Notebook
Inspiron 1150 lines on screeN problem.
Connect an external monitor to the laptop and see if it also has the vertical lines. If the external monitor looks fine, then your laptop’s LCD display panel is bad. If the monitor has the vertical lines displayed on it, then your graphics card or motherboard is bad.
Your responses are intended to improve the level of service provided. Please show your appreciation by rating your experience.
Thank You.
Nov 10, 2008 | Dell Inspiron 1150 Latitude D600 14.1 LCD...
Vertical lines in my laptop screen
Try connecting an external monitor to the Dell Inspiron 9300 and see if the vertical line is also present on the monitor. If the monitor display is fine, then your laptop’s LCD display panel is defective. If the monitor also displays the vertical line, then your problem is with either the video card or motherboard located inside your laptop.
Not sure if the Compaq Presario has an external monitor plug, but if it does the above procedure can be applied to that one as well.
Your responses are intended to improve the level of service provided. Please rate your experience.
Thank You.
Oct 19, 2008 | Dell Inspiron 9300 Notebook
Computers & Internet Logo
401 people viewed this question
Alun Cox
