Blown headgasket, how to remove cylinderhead
Remove all connections, vacuum hoses etc from manifold, remove all bolts from Engine head, remove gasket and replace, installation is reverse of removal...
PURCHASE a repair manual for $20.00????? One that has pictures for you..
Testimonial: "If one had manuals for each different vehicle in the world, we wont need fixya, righ? Only in Soviet you have 13.000 MAKES - 5000 CONCEPT CARS - SOVIET CARS. Worldwide 1000,s of manufactures each with 100,s if not 1000,s of there own makes. No one in his right mind will have workshop manuals for each makes and model of vehicles and will cost millions of dollars. You definitely no nothing thats why you have no decent answer and can only say "buy a manual with pictures" Fixya is to share experienced knowledge from people that have know hows, not go a buy a manual! Every engine have manifolds,vacuum hoses and BOLTS AND the reverse order to assemble once stripped - thats COMMON SENSE. Obviously you dont know the answer and cannot do such work,looks like you only answer is this manner to score so called "expert" points on fixya. How many auto repair manual [if any] have you got? Are you even a mechanic as you advice is extremely poor? - Right?"
Unbolt it and remove stuff replace gasket and reverse the order! EASY NO!!!!
Testimonial: "MOST IMPROPER ANSWER EVER!"
Questions: Do you have the proper tools?
Do you have the proper knowledge?
Do you have the ability?
Best to have a repair shop fix!
If you have to ask! If it was that easy! We would have web sites and no repair shops!!!!
My answer was exact! If you need a step by step answer and telling each single step! You would be in OVER your head! Why in the H*ll do think it is so hard to find a GOOD TECHNICIAN? Do your self a favor! Spend you time finding a good Technician!
you got no answer and never done a Chev Spark, job is done WITHOUT YOUR COMMENTS!!
YOU ONLY ANSWER TO SCORE POINTS!!
GET A GRIP IN LIFE!!
ANSWER: GOT MORE TOOLS THAN YOU MOST LIKELY EVER CAN DREAM OFF.
MORE ENGINE KNOWLEDGE THAN YOU CAN EVER DREAM OFF
YOU LACK ABILITY TO ANSWER QUESTIONS LIKE THAT!
WEBSIDES DONT REPAIR VEHICLES-PEOPLE DO
WEBSIDES IS FOR DECENT INFO, NOT LIKE YOURS!
MY QUESTION IS SIMPLE AND DIRECT, YOUR ANSWER IS A JOKE!
I NOTED YOU ARE AN SO CALLED "EXPERT"(hehehehehehe) ON Fixya ANSWERING ANY QUESTION ASK ON ANY SUBJECT,MEDICAL,CARS,DIESELS,OTHER STUFF. YOU MUST BE BORED AND STUCK IN FRONT OF YOUR CHEAP PC - JUST TO SCORE POINTS. 99.9% OF YOUR ANSWERS ARE JOKES!
If you had more KNOWLEDGE why are you asking!
ALSO you hide behind ANONYMOUS! GET A LIFE!
NOW it makes sense L.D.ahlers IS ANONYMOUS! VERY Childish! You have been reported!
As for ALL your comments are tied to L.D.ahlers
Good luck to Ya!
You been reported as well for poor and improper technical answers to people on fixya.
SOURCE: Head gasket blown. What is approximate cost to
Considerations
Testimonial: "Thank you."
SOURCE: blown head gasket
I would change both, as well as use new head bolts. Make sure your heads are not warped or cracked, especially the one that is leaking. There may not be any need to change the head if it is not cracked. These are prone to blowing a gasket especially after 150K miles or so. It will not cost a huge additional amount to change both head gaskets since the engine will have to be disassembled down to the heads anyway. Hope this helps you, Rick
SOURCE: how to replace blown head gasket
u have to start by removeing ur headers dont forget to take ur blown gasket to ur local part store to make shure u get the rigth one
And torque to specs..easy yes!!
Mate, if I knew how to repair every vehicle on the planet from memory, I'd be a nutter by now. Google is your best friend for general knowledge repairs and manuals for most vehicles from parts distributors..even if I told you bolt by bolt, you wouldn't understand...just trying to help...p.s. I'm expert in many fields not just vehicles..so no need to be test.. cheers and good luck.
I said with pictures because I too sometimes needs pictures or diagrams or videos?? Don't have a bad attitude because you misunderstood me mate...good luck with the repair...not an easy job, but doable..cheers
