Question about Ricoh Aficio 1035 Copier
Display is showing code SC 542.
Machine has been working fine. Yesterday the code showed up . Can somebody tell me how to correct this? thanks in advance for your help
  • arbame Jul 30, 2009
    IT WORKED!!!! Thank you very much. God Bless you.
  • arbame Jul 31, 2009
    I followed your instructions , and It worked!!!. Thank you very much
  • 313 Answers
The error is for a heating eror in the fuser either toner build up on the thermistor or the thermofuse has blown if you have the machine turned on press the yellow clear button and then input 107 and then hold dowwn the stop button.. turn machine off and wait a few seconds then turn back on.. this should clear it if it was just a fluctuaction in temps.. if that doesnt work take fuser out and check the condition of the temp sensors and do reset again.. if the code stays on you will have to go into the service mode.. acccessed the same way as reset but you need to enter the copier sp and then go to 5.Mode and look for 810 this is the sc reset execute turn off and then on >>>>Hope this helps A
Posted on Jul 30, 2009
  • Andy Bell
    Andy Bell Jul 31, 2009
    glad I could help the method of clearing the error code can be used on most sc codes you get as long as the fault isnt serious or a fault in the parts try the code again if youhave other error codes.. A
Sharp photocopy machine showing error code Sc 542
SC 542 Basically the machine is telling you that the fuser did not reach its target temperature in a specified amount of time. In normal circumstances this code will appear if the thermistor is not maintained or replace periodically or in abnormal circumstance the heat lamp blew. This is a Service Tech reset code. Once the error is detected, the printer is toast until you manually clear the error from the keypad. Even though the printer is physically fine, it won't come ready until the prior error condition is cleared. basically you will have to care a service tech to clear it
Aug 03, 2015 | Sharp Office Equipment & Supplies
Error sc 542
this is a fusing error
change the set of thermisters in the fusing unit
Jan 20, 2014 | Ricoh Aficio CL3500N Laser Printer
When I turn the printer on all of the alert lights go on.
check the lcd screen of the machine if there is an error code like SC 542. with this machine it will always show what is the problem through CODEs.
Apr 23, 2013 | Ricoh Aficio 2022 All-In-One Laser Printer
I have a ricoh aficio sp c420dn, when and turn on the screen showing error sc542
You may try first to reset the SC 542 before calling a technician!
That you can do by following method:
1.Turn the machine off and then after 5 second turn it on while pressing the “On Line” key and “Escape” key together until “SYSTEMver x.xx/1. Service” shows on the display.
2.Use the “Up/Down arrow” keys to scroll through the menu listing.
3. Press the (OK) key while
on the display writes " 2. Engine " .
4.go to "[5810 001] - Fusing SC Reset" by scrolling the “Up/Down arrow” keys and press the [OK] key (on the display should write execute or done) press [OK] again if is needed to press it.
5. After this turn off and than after 5 second turn it on the machine.
Please do not change nothing else in this menu only reset the fusing unit SC code, because if you change some other values and settings you might to regret that and pay high price for that.
So only reset the Fuser SC code SC542 by the upper mentioned method and do nothing else, if the SC code appear again then do not try this again because you might burn some parts.
If this do not help than call the technician.
Please answer do this is helpful for i to know do the problem was solved.
Regards
Jan 10, 2010 | Ricoh Office Equipment & Supplies
Functioning problem with aficio 1033 or 2033,not sure, church cop
You must check the display for a code like SC-542 or something loke that.
Sep 17, 2009 | Ricoh Aficio 2022 Black and White Copier
Service Code SC 542
That is fuser code and needs to be reset in the service mode, it will not go away by turning the off and back on.
May 29, 2009 | Ricoh Aficio 1027 All-In-One Laser Printer
RISO RZ200
if show ERROR CODE D22-542 means the board in the drum have some problemif show D04-534 means you are using not original ink, but just press restart key is ok.
Apr 13, 2009 | Riso RZ220 Duplicator
Ricoh Aficio MP 2510 SC 541, SC 542 Errors
To clear level A SC codes such as this SC541, you need to
Enter SP mode, and then turn the main power switch off and on, only.
Please check if the thermistors are the proper ones and are installed correctly in their position properly.
This is also useful for SC542.
Please check the thermostats and fusing lamps for open circuit.
Good luck and please rate me, thanks.
Jan 17, 2009 | Ricoh Office Equipment & Supplies
Ricoh aficio 2022 error code sc542
1. Mode(Yellow Button)
2. 107
3. Press STOP Button for 3 second (RED Button)
4. Copy Sp
5. 5810#
6. Excute
7. Power Off
8. Power On
Oct 23, 2007 | Ricoh Aficio 2022 All-In-One Laser Printer
Sc 542 error code
Error SC 542 indicates a fuser temperature problem. Once the error is detected, the printer is toast until you manually clear the error from the keypad. Even though the printer is physically fine, it won?t come ready until the prior error condition is cleared. The magic keystrokes, clear the error code: The Fix In order to clear error SC542, you must perform procedure 5810. Press and hold online + escape, then power on. Use up and down arrow keys to select SP2 Press Enter Use up and down arror to locate SP5 Press Enter Use up and down arrow keys to select 810 Press Enter Confirm the selection Power off and on. The error code is now cleared.
Aug 13, 2007 | Ricoh Aficio 2015 Copier
Ricoh Aficio 1035 Copier Logo
193 people viewed this question
Top Ricoh Office Equipment & Supplies Experts
Adorjani Laszlo
quennie732
fares
Level 1 Expert
Are you a Ricoh Office Equipment and Supply Expert? Answer questions, earn points and help others
