Question about Microwave Ovens
How do I replace the temp sensor to correct the f2 error message from going off all the time?
  • William Miller
    William Miller May 11, 2010
    Please reply back with your brand and model number so we can help you.
I have an Amana range/oven which kept beeping "f2" error. I looked up the code and found it was the temp sensor. Your tech sent me the schematic for the unit and I was able to locate and replace the sensor. Thanks for the assist as it was exactly what I needed.
JG
Posted on Aug 05, 2009
My whirlpool microwave oven will not power up and shows a code f2. how can i fix it
its an error need to call technical assisstance ..thAT error ranges for faulty temp sensor/probe up to control board ....
Aug 05, 2014 | Whirlpool MH1150XMQ Microwave Oven
Tip
Troubleshooting KitchenAid oven, range and microwave error codes
Here list of Kitchen Aid range and oven codes.
4 Digit Failure Codes
F1 - E0 EEPROM communication error
F1 - E1 EEPROM checksum error
F1 - E2 UL A/D error
F1 - E4 Model ID error
F1 - E5 Calibration shifted
F1 - E6 Latch signal mismatch error
F1 - E9 Stack overflow
F1 - E3 Wiring harness cavity size does not match stored value
F2 - E0 Shorted touch pad
F2 - E1 Keypad cable connection error
F2 - E5 Cancel key drive line open
F2 - E6 Cancel key drive line open
F3 - E0 Oven temperature sensor (RTD) opened (upper oven on double oven models)
F3 - E1 Oven temperature sensor (RTD) shorted (upper oven on double oven models)
F3 - E2 Oven temperature is too high (Cook mode)
F3 - E3 Oven temperature is too high (Clean mode)
F3 - E4 Oven temperature sensor (RTD) opened (lower oven on double oven models)
F3 - E5 Oven temperature sensor (RTD) shorted (lower oven on double oven models)
F3 - E6 Drawer sensor open
F3 - E7 Warming drawer sensor shorted
F4 - E1 Meat probe malfunction - shorted
F5 - E0 Door Switch
F5 - E1 Self clean latch will not lock
F5 - E2 Latch during CLEAN error
F5 - E5 Self clean temperature not reached within 45 minutes.
F5 - E6 Door is open, but latch is locked
F5 - E7 Self clean latch will not unlock
F6 - E0 Return line not connected
F7 - E1 Common switch wire defective
Two digit codes:
F0 ERC Board failure
F1 ERC Board failure
F2 Oven temperature is too high
F3 Oven temperature sensor open
F4 Oven temperature sensor shorted
F5 ERC Board failure
F7 Function key stuck on ERC
F8 ERC Board failure
F9 Oven door lock failure
Microwave and Microwave combo error codes:
F1 - E3 or F1 - E4 Electronic control malfunction
F2 - E0 or F2 - E1 Keypad connection error
F2 - E3 Keypad held down too long, or keypad is shorted.
If you get an error code, try first resetting the code:
1. Disconnect power for about two minutes.
2. Connect back power.
3. If code re-appears, test and eventually replace faulty part.
Regards.
on Mar 27, 2010 | KitchenAid KHMS155LSS 1000 Watts Microwave...
Code F2 upper thermal sensor
please follow the steps use the VOM and test it. God bless you
F2: 3123f39f-6d87-4596-8303-294a18c6bec2.gifCheck oven thermistor for continuity. Replace if zero or infinite ohms.
May 27, 2013 | GE Microwave Ovens
My kitchenaide convection oven is displaying the E1 F4 error.
KitchenAid ovens are popular for their classic design and simple user interface. When a problem occurs in the function of a KitchenAid oven, an error code will display on the clock as soon as the malfunction registers in the oven's memory. Each code corresponds to a particular type of malfunction. Most can be corrected by disconnecting the power supply for one minute and then restarting. If the code persists, either replace the indicated part or contact a service center. F0/F1
  • The F0 and F1 codes refer to electrical issues. If the code appears as only two digits, the problem is a transistor failure, so you must replace the electronic range control (ERC). If the code displays four digits, it will read F0-E0, which indicates a failure switching from analog to digital, or F1-E1, which refers to a safety flip-flop. Both problems require the replacement of the ERC.
  • F2/F3/F4
  • The F2, F3 and F4 codes refer to problems with the oven temperature sensor or the keypad. If you see the two-digit F2 code, it means your keypad has shorted and the ERC must be replaced. The four-digit F2-E0 code means that the oven temperature is too high. Test the door lock and the relay operation, and correct as necessary. A two-digit F3 code means an open temperature sensor or thermal fuse, so those parts must be replaced. A four-digit F3-E0, F3-E1, F3-E2 or F3-E3 code or a two-digit F4 code means that either the oven is registering as too hot or the temperature sensor has shorted. Either way, the oven temperature sensor must be replaced.
  • Nov 22, 2010 | Microwave Ovens
    Kenmore Gas Range model # 362.75491990 F3 error Oven will not hold temp - error message displays and beeps I Replaced the oven temp sensor same issue Is the control panel bad?
    Many models of the GE microwave have sensors that can detect humidity from the foods you are cooking. This allows the microwave to make adjustments to the power levels used to cook your food. If "Sensor Error" appears, you should either press "Clear" to cancel the mode or leave the food in the appliance longer to give the microwave more time to detect the food.
    Press "Time Cook" to manually enter the time if you receive an error message when trying to use the "Sensor Reheat" mode of your GE microwave. The error message may be caused by the food item being too large or too small to detect.
    these are some other code error that will help you in case of next time.
    1. Step 1 Press "Off/Cancel" (or "Cancel/Off" depending on your model) to clear the error code. Note the code if it reappears.
    2. Step 2 Replace the touchpad if the code displayed is "F0," "F7" or "F10." A function key is stuck or shorted.
    3. Step 3 Replace the touchpad or the clock (ERC) if the code "F1" is displayed. Disconnect the ribbon connector to the touchpad. If no code is displayed after an hour, replace the touchpad. If the code displays again, replace the clock.
    4. Step 4 Replace the oven temperature sensor if "F2," "F3" or "F4" is displayed. "F2" indicates the oven temperature is too hot and the oven temperature sensor is suspect. "F3" or "F4" indicates the oven temperature sensor or shorted or open.
    5. Step 5 Replace the ERC if "F5," F6" or "F8" is displayed. The ERC is the main control unit. "F5," F6" and "F8 are codes that indicate problems in the ERC functions.
    6. Step 6 Inspect the door-lock assembly and circuit if "F9" is displayed. The door must lock when the oven is in use. If the lock mechanism is not functioning or if the detection circuit is malfunctioning, the stove will display "F9."
    jQuery('.article ol .image').each(function(i,e){ var $this = jQuery(this); $this.find('img').error(function(){ jQuery(this).remove(); $this.remove(); }); }); NOTE:
    "F3" codes mean your oven temperature sensor has failed or shorted out. The only thing you can do is to replace the sensor.
    Take care.
    May 11, 2010 | Microwave Ovens
    Controlpanel flashes f 3
    You have a faulty keypad. You could probably special order this part from a local appliance parts supply store for 50-60$ or purchase a new microwave.
    Oct 22, 2009 | GE Spacemaker JVM1640SJ Microwave Oven
    Kenmore Elite speedcook oven Model 63799. F2
    f2 error means : -------
    1. The oven temp has risen above 665F and the door is not locked or
    2. The temp has risen above 965F with the door locked
    ------------- if this happens you should check: -----------
    1. Check oven temp in mode that failure occurred. Replace EOC (Electronic Oven Control) if above limits
    2. Check and replace oven temperature sensor if necessary
    keep updated,please do accept and rate the solution.thanks.
    Sep 30, 2009 | Kenmore 63792 Microwave Oven
    Kenmore microwave model 63792 displays F2 error message
    The F2 error code on your microwave oven is a membrane failure.
    It is recommended that you replace the membrane first & if you still have problems to replace the control board.
    Thanks for using FixYa - a 4 THUMBS rating is appreciated for answering your FREE question
    Aug 21, 2009 | Kenmore 63792 Microwave Oven
    Microwave Ovens Logo
    106 people viewed this question
    Top Microwave Ovens Experts
    William Miller
    William Miller
    Are you a Microwave Oven Expert? Answer questions, earn points and help others
