Question about Canon Pixma iP2600 Photo InkJet Printer
Canon Pixma ip 2600 has a flashing orange light,3 flashes.Cartridges are installed correctly.Why isn't it printing.??? please help.
SOURCE: CANON IP 1880
Hello, My printer showing 5202 service error before that "printer is busy" mssege shows and stop the printer. if top is open and close then printer started printing after two line printing repeat the error.
Posted on Sep 30, 2008
devdeep545
  • 137 Answers
SOURCE: why flash by 5 times the orange led?
Probably your waste ink counter should be cleaned or replaced before resetting but usually you can get away with resetting once.
1. Start with printer OFF
2. Hold down RESUME and then hold down POWER
3. Release RESUME
4. press RESUME twice, then release POWER
5. let green light blink until printhead has finished moving.
6. Select functions below with RESUME, execute with POWER
0 presses - green light - Test Print (exit service for i960)
1 press - orange light - EEPROM info print
2 presses - green light - EEPROM initialise
3 presses - orange light - reset waste ink counter.
This also applies to the i550, i560, i950, i960
Good Luck, I hope this helps?!
Posted on Aug 12, 2009
cene765
  • 787 Answers
SOURCE: My canon ip1880 printer orange light flashing 7 times.
1. Press power button while plug in the power cord – green lamp.
2. While hold the power button press resume button twice – orange blink and return to green.
3. Release the power button, Then the PC will recognize new printer install.
4. You need the software for permanent reset.
5. Run the software and select printer port.
6. Then select Set Destination
7. Click MAIN and PLATEN button to reset waste ink counter to zero.
8. Finally test print by click TEST PATTERN button.
Posted on Oct 19, 2009
SOURCE: canon ip 2600 printer. Paper does not feed
Hey I had the same problem. Called the company; we couldn't fix it. Well I turned it upside down and a 2" flower stem fell out from when I cut some flowers next to my desk. It still didn't work. I was examining the feed area while it was running and I found another little piece of stem that was lodged way in there. I had to get it out with tweasers and it turned out to be 1" long. Couldn't really see it at all. Works fine now.
Posted on Nov 10, 2009
SOURCE: Canon Pixma IP4000 - Printer
5 times orange means you need to replace the print head.....if the led are Blinking in Orange and Green Alternately you need to replace the sheet feed unit.
Posted on Mar 28, 2011
Testimonial: "THANKYOU SO MUCH - IT SAVES ME A LOT OF WASTED TIME."
What causes orange light to flash 4 times?
It is related to a badly installed or empty print cartridge: http://www.canon.co.uk/support/consumer_products/product_ranges/printers/pixma/error_codes/#1600
1600 - Orange light blinking 4 times Description:
The ink cartridge has run out.
Resolution:
  1. Lift the printer cover up.
  2. Identify the ink cartridge that has run out (the ink cartridge flashes quickly at around 1-second intervals).
  3. Replace the applicable ink cartridge and close the cover.
  4. Press the [Resume/Cancel] button on the device to continue printing.
If the above solution has not resolved your error, please contact your nearest Canon authorised service facility using the link at the top of the page.
1660 - Orange light blinking 4 times Description:
The ink cartridge has not been installed correctly.
Resolution:
  2. Check that the red lights on the ink cartridges are all turned on.
  3. If no red light is activated on a particular cartridge, check that the cartridge is securely positioned and adjust if necessary.
  4. Also make sure that the orange protective cap has been removed from the bottom of the ink cartridge.
  5. Press the [Resume/Cancel] button on the device to continue printing.
Feb 11, 2016 | Canon PIXMA iP3500 Printer
Flashing orange light
Cannon pixma 3500 Flashing orange light count the blinks for the error,
Mar 17, 2014 | Canon PIXMA iP3500 Printer
Alarm / Power light flashes orange 5 times consecutively (Print Head / Cartridge Error) What can I do?
Refer to Canon documentation
Five flashes: Print Head is not installed./ Print Head is defective
please check correct placement with your cartridge, maybe it's not installed properly
May 09, 2011 | Canon Pixma iP4500 InkJet Printer
My canon ip90 printer cartridges is stuck to the right of the printer. And the light keep flashing orange 5 times. Can someone please help me fix it.
LED blinking in Orange color 5 times = Print head is not installed properly or the print head has reached to the end of life.
May 29, 2010 | Canon PIXMA iP90 Mobile Printer
Both lights are blinking and will not print
they call that flash codes or error codes. please count
count how many times the lights flash, here is what they mean
Alarm / Power light flashes orange 7 times consecutively (ink cartridge installed incorrectly)
Alarm / Power light flashes orange 5 times consecutively (Print Head Error)
Alarm / Power light flashes orange 4 times consecutively (Out of Ink Error)
Alarm / Power light flashes orange 3 times consecutively (Paper Jam Error / Cover Error)
Alarm / Power light flashes orange 2 times consecutively (Load Paper / Paper Feed Error)
Alarm / Power light flashes orange 16 times consecutively (This FINE Cartridge has previously been used)
Alarm / Power light flashes orange 15 times consecutively (FINE cartridge not recognized)
Sep 20, 2009 | Canon Pixma iP2600 Photo InkJet Printer
Canon ip 3300 flash 5 times orange
pixma ip3300 flash orange 5 times, i remove all catridge / remove print head and orange flash 5 times. help!!!
Sep 18, 2009 | Canon PIXMA iP3300 InkJet Photo Printer
Why flash by 5 times the orange led?
3. Release RESUME
Aug 12, 2009 | Canon PIXMA iP5300 InkJet Photo Printer
Canon iP1800 printer,flashing orange light under the green 'on'
First off, How many times does it flash organge before it goes to green?
two: out of paper
three: paper jam
four: Ink has run out
Five: FINE cartridge cannot be found
Seven: FINE Cart. not installed in correct position
Eight: Ink absorber almost full
Count how many times it flashes. Then get back to me
Feb 05, 2009 | Canon PIXMA iP1800 InkJet Photo Printer
Canon pixmaip3000 states printer offline & does not print, flishing power lights green & orange
I have canon PIXMA ip3000. After power cut at night printer doen not print. I re installed the drivers but no result. When try to print message appears printer is offline. POwer button is flashing shorthly green after orange lights. Error code 5100.
Please advice what can I do urgently.
Mar 10, 2008 | Canon PIXMA iP3000 InkJet Photo Printer
Canon ip4000 flashing 12 times
For 11 orange flashes (Canon doesn't list 12) Canon says its an automatic print head alignment error: -make sure ink tanks are snapped in correctly http://www.usa.canon.com/consumer/controller?act=SuprtKnowledgeBaseAct&fcategoryid=184&modelid=10438 -place 8.5 x 11 paper in the automatic sheet feeder, anything smaller will cause this error. -Remove the printer from strong light; apparently a sensor in the paper output slot can be affected. -Also you said you replaced all the cartridges with new ones, were the new from HP? If not I would definitely try replacing them all.
Jul 21, 2007 | Canon PIXMA iP4000R InkJet Printer
Canon Pixma iP2600 Photo InkJet Printer Logo
463 people viewed this question
old marine
old marine
