Question about Sharp R-930AK Convection/Microwave Oven
Have a Sharp R930AK microwave. Used it for 15 minutes on 350-deg convection. At end of cycle the turntable continues to turn anytime the door is open, and microwave does not work at all, that is no heat, no turntable motion. Have tried all combinations of controls, pressing on door to be sure it is firmly closed and finally cycling the AC power. Any suggestions?
  • lmpolsky Aug 09, 2009
    This solution was right on target and got my microwave working in 10 minutes with the only cost being a bit of hot melt glue. Note that the fix can be done by removing the outer cover only...do NOT have to remove the control panel.
    Thanks!
  • Anonymous Mar 26, 2014
    pressed the door lever but does not open door. It also does not heat food and the turntable set to on does not turn.
  • Sharp Master
  • 9,047 Answers
You probably have a problem with the bottom door switch, or its mount may be loose or damaged.
We have the service / repair manual for this model and have uploaded it to our site here for free download to help you.
It will give you safety info, step by step help in disassembly, troubleshooting tips, and part numbers.
You can order parts from Encompass here or you can call them toll-free at 866-779-5835.
If a switch is all you need, we offer a universal type for only $5 postpaid which you can order here.
Even though a door switch clicks, it may still be bad inside.
Door switch or mount trouble is usually caused by slamming the door or by opening the door while it's cooking without hitting the Stop pad first.
There are plastic mounts inside the microwave which hold the door switches and onto which the door latches lock when you close the door.
The screws on these mounts may be loose. If they get too loose, the switches will not be activated properly.
Sometimes it's a broken tab on the switch holder, allowing the switch to rotate just out of position. This tab can be hard to see, since it is under the bottom edge of the switch.
If the switch mount is broken, it's usually more economical and safer to add a dab or two of hot glue to the mount to secure the switch. Let it cool for about 30 minutes before using.
If you still have questions, please reply back, otherwise...
Posted on Jul 30, 2009
Microwave turns on but doesn't heat. Turntable does not rotate
The magnetron (the part that heats the food) is probably done, they tend to go out if the fuse didn't blow and it usually isn't worth fixing as the cost of the magnetron is almost what it would cost to buy a new microwave.
Sorry for the bad news.
Benjamin
Mar 25, 2010 | Sharp R-930AK Convection/Microwave Oven
When the door is opened the turntable begins turning. light and fan and all seems to work but does not heat. Any ideas?
See solution posted on Jul 30, 2009 by MicrowaveSvc This solution was right on target and got my microwave fixed in 10 minutes!
Aug 05, 2009 | Sharp R-930AK Convection/Microwave Oven
Our microwave/convecton turns itself off after about a minute
This is a problem in one of the damper-related components, most likely the switch, but it may also be the motor or the damper door.
The damper is a door inside that opens or closes depending on cooking mode. If the controller senses that the door is not in the right position, it will shut down the cook cycle.
Sharp models stop after 59 seconds.
See the attached sample photo for a typical damper assembly.
We have the applicable service manuals for these models and have uploaded it to our site here and here to help you. You will need the free Adobe Reader to view or print it.
Feb 05, 2009 | Sharp R-1870 Convection/Microwave Oven
Turntable stop working along with microwave and convection oven
would be a door micro-swtch sharp part # Sharp Part Number: QSW-MA085WRE0
Jan 07, 2009 | Sharp R-1405 / R-140 Microwave Oven
Faulty microwave function on the SHARP R-957 model (900watt)
Info on ordering Sharp UK parts / spares is here.
William E. Miller
prototech@usa.net
http://www.microwavedisplay.com
Dec 10, 2008 | Sharp R-930AK Convection/Microwave Oven
Turntable won't stop
Sounds like a door switch problem or stuck relay contacts on the control PCB. Do the light and fan run too or just the T/T??
Nov 07, 2008 | Jenn-Air JMC9158AA Convection Microwave...
Microwave, convection R930AK turntable will not turn and microwave will not cook. inside light works
That would be a defective secondary (lower) door switch or possibly the door switch mount is loose or misaligned.
We have the service manual for this model and have uploaded it to our site here to help you.
The best place to order Sharp parts is Tritronics.
Aug 29, 2008 | Sharp Microwave Ovens
Sharp R-930AK Convection/Microwave Oven Logo
325 people viewed this question
Top Sharp Microwave Ovens Experts
William Miller
William Miller
Devabhakthuni...
Devabhakthuni...
Ed Mac
Are you a Sharp Microwave Oven Expert? Answer questions, earn points and help others
