Question about Hawking Computers & Internet
Installed hawking wireless range extender- as soon as I connect it to linksys router, the router and desktop pc (connected with an ethernet to the linksys) can no longer connect to the internet, but the laptop can access the extender ssid I set up. HELP
  • karenvelez Jul 30, 2009
    Yes, I was able to have both connected simultaniously before adding the extender. The DNS settings are definatey correct- will try the fix of changing the modem to a lan port. Thanks
  • Pavan Ponangi
    Pavan Ponangi May 11, 2010
    were you able to connect both the Laptop and PC simultaniously before the Hawking extender in any case try connecting the cable from the modem to the ports number 1 instead of the port INTERNET and this should work also check to see that the DNS server Settins and other settings are set right too
SOURCE: configure WRT300N wireless Router to connect internet using PPPoE
Often the nets and subnets are NOT the same.. ie The Fixed connection often uses 192.168.0.1, 192.168.1.1, however sometimes the wifi is setup 10.1.1.1, or 10.0.0.1 etc, have you checked this? Esentially tho ya router is an "Acess Point" and ya Lappy etc is ya "Client" the links below has a lot of tutorials to help have a look. http://portforward.com/routers.htm http://portforward.com/guides.htm
Posted on Aug 05, 2007
SOURCE: D link airplus G Wireless range extender
You have to change your computer IP address to the same domain as the range extender i.e. if your range extendr's IP is 192.168.0.31, try setting your computer's IP to 192.16.0.xx where xx is between 0 and 255.
Cheers,
Posted on Oct 25, 2007
  • 556 Answers
SOURCE: DSL modem and Linksys Wireless Router not working together anymore
if i were to guess you are probably a PPPoE user with a dynamic IP address.
possible config
Posted on Dec 18, 2007
  • 11 Answers
SOURCE: netgear wireless router DG834PN wireless access local only
With Vista on the Laptop it should be just a matter of double clicking the router in the network settings, vista should automatically configure the connection.
This has happened to me before and this is what I did just to see if it worked, and it did flawlessly.
Posted on Mar 07, 2008
One Piece
  • 53 Answers
SOURCE: connecting 2wire router with desktop pc and laptop
hi! try to check the settings on your 2wire modem, you can do this by going to gateway.2wire.net, run the system setup wizard, when you get to the ppp authentication page, check the username & password on it, it should be the one that you setup for your ISP account. as for the wireless on the desktop, it depends on the brand of the wireless adapter, be sure you have installed the drivers for this adapter. you may need to go to the client utility manager or the wireless adapter shortcut/icon on your computer screen then configure it to "see" the 2wire network. make sure wireless encryption is turned on in the 2wire modem's MDC, you can do this by going to homeportal/management, or go to gateway.2wire.net/mdc.
Posted on Apr 14, 2008
Hwern1 hi gain wireless 300n range extender
what issue are you facing? its not connecting to your existing wifi network ? let me know if you want me to call you if u r in US
Dec 06, 2013 | Hawking HWREN1 Hi-Gain Wireless-300N Range...
What is the difference between USB Ethernet Extender and a USB Ethernet Adapter?
Extender boost your wireless connection range.
Adapter is use to connect to a wirelles connection (router)
So let say you have a router far from your PC the extender boost your adapter range to get the router best signal
Jun 07, 2013 | Computers & Internet
Hi, I just got Linksys WRE54G V.3 and was trying to install the CD. But I keep getting "Site Survey fail" message. My house is using a router made by Apple, and does not have extra space to...
The range expander helps to extend the range of wireless network...
Anyhow the range expander has to be placed withing the range of your Apple "wireless" router (Make sure your apple router is wireless router, if it is a wired router, then there is no use of range expander...! U need to buy an Access Point instead)...
your range expander must be connected to the computer(using an ethernet cable) from which you are trying to configure...
Site survey searches for the available wireless networks in range...
It should show your existing wireless network...
You need to select your appropriate network and you need to configure the Range expander wireless settings according to the Apple router's wireless settings...
exactly the same SSID(Network name), Security type and encryption technique, password PSK (security key) has to be selected on your range expander as in the APPLE wireless router...
Thats it...
You are done...
Your wireless network range would have extended now....
Dec 09, 2010 | Linksys Wireless-G Range Expander (WRE54G)
Connectivity issues with my srx200 wireless router
First take the ethernet cable one end should fixed with ur PC/laptop and other end connected to ur modem.finally configure the access page .
Apr 30, 2010 | Linksys WRT54GX2 Wireless-G Broadband...
Hawking Extender- Connected to WiFi but cannot access Internet
First think I always do is Reset Linksys Router and disconnect extender. Then turn off all security on router. Do soft reset on ipod. leave extender off and see if you can connect to the linksys. If you can then plug in extender (still with security off) then see if ipod connects to extender.
you might have to soft reset ipod again once you connect the extender.
if that works. reset security. Let me know how that goes.
Jan 01, 2010 | Hawking 802.11g Wireless-G Range Extender
WAP connecting to another WAP
On the D-Link WAN page, change IP Address to static and give it an address about 30 away from both the Hawking and the Linksys. On the DHCP page, disable DHCP.
In a multiple router network such as yours, you can only have ONE real router. The others have to be disabled as routers. Disable thier DHCP and give them static addresses that are all at leat 10? or more from each other. Wireless should all be the same setup. The on;y exception is the SSID which can be slightly different to know which wireless you are on.
May 31, 2009 | Hawking 802.11g Wireless-G Range Extender
Hooking up a Linksys dual range router to a 2 Wire cable modem
ok once your internet is resolved you shouldnt need to have any computer hard wired to the router but it should go like this cable from your wall to the modem, then cable from modem to the router, after that you can go wireless all the way just make sure that its all secure and encrypted dont want the next door neighbor stealin your internet
Feb 25, 2009 | Linksys Ultra RangePlus Wireless Routr...
Hawking extender hangs
They just issued new firmware: http://www.hawkingtech.com/support/details.php?CatID=32&FamID=105&ProdID=394#Firmware
You might try that...
-Tom-
Dec 26, 2008 | Hawking 802.11g Wireless-G Range Extender
Use Belkin f5d7230-4 as a wireless access point
Hi Druid,
Based upon what I've read regarding and experience with the F5D7230-4 is it will only work with another F5D7230-4 or F5D7231-4, F5D7130, F5D7132 and this are all Belkin products as well I thiink it has something to do with the WDS compliance for this specific model that's why they have clearly specified on the User Guide which devices are guaranteed to work with an F5D7230-4 that is set to AP Mode(Bridge/Repeater).
If you really want to exend the wireless coverage of your Linksys router I suggest you try the Wireless G Range expander(WRE54G v2.0/3.0 version 1.0 I do not recommend since it's somewhat challenging to configure since it has no ethernet port all the setup will be done wirelessly)
click this link for the User Guide of your Belkin router.
Aug 17, 2008 | Belkin (F5D7230-4) Router (587009)
Wireless G ranges expander
when using the range extender you have to make sure you set the SSID, channel & wireless key in the range extender the exact same as the router also it has to be in the same IP range so if the router IP address is 192.168.0.1 the range extender IP address has to change from 192.168.1.240 to 192.168.0.240. once that is done restart the range extender and disconnect the ethernet cable & it the 2 lights should light up blue.
Jan 20, 2008 | Linksys Wireless-G Range Expander (WRE54G)
Open Questions:
Computers & Internet Logo
278 people viewed this question
Top Hawking Computers & Internet Experts
Steve
Mike
Are you a Hawking Computer and Internet Expert? Answer questions, earn points and help others
