Question about Bosch WFR 145 Front Load Washer
Washer Probem.. the rubber came off the metal rim.
The rubber that holds the metal rim on a front load washer has come off so now it makes a lot of noise when it spins. Also some water is leaking...
Any suggestions how to get the rubber back on the metal rim so that it starts working without any noise and does not leak.
  • 274 Answers
Re: Washer Probem.. the rubber came off the metal rim.
The rubber is most likely damaged and needs replacing. They make and sell repair kits to fix this. Buy the repair kit from any Bosch dealer and the instructions are included in the package.
Posted on Nov 24, 2007
0 characters
3 Points
Samsung washer WF328AAW/XAA metal pieces in hose?
Could be a number of things. Either something foreign was left in a pocket (Coins are the most common object) and has come out in the wash. The coin rattles around and falls in between the tubs through the gap in the front gasket. When this happens, the coin can hit the bracket which holds the heater element in place and tears it off. This causes a lot of damage. Most Samsung have plastic outer bowls and often, the tub will be split and a leak will start from underneath. Lastly, it could be the drum main shaft and spider assembly. This is what holds the spin tub into the machine. If this fails, bits of metal will come off. Usually seen as bits of corroded aluminium that get stuck in the pump and hoses. When this happens, the tub usually goes loose and the machine makes a horrible grinding and banging noise when spinning. I would say that if this has happened , its time for a new machine.
Sep 10, 2014 | Samsung WF328AAW Front Load Washer
It makes a loud noise when washing - it seems like the inner tub is sagging or something, when you open the door you can see the top rim of the tub. Is this fixable - and cost effective?
When my washer did that, I found that the shocks that hold the tub were bad...
Check out this tip I wrote about the noise and vibration that front load washers can make..
Washer Problems
Washer noise when spinning
Feb 06, 2011 | Frigidaire FTF530FS Front Load Washer
Rubber around the washer has come off - there is a thin mental wire but it does not seem to fit well. I have also lost the manual which may have a picture in it.
The thin metal wire should have a loop on either end. Connecting the two loops is a spring, that wire/spring combination holds the rubber seal around the tub opening. Putting the wire back on is a lesson in patience. The rubber fits in a slot on the back and the wire holds it in in the front. Good luck.
Nov 25, 2010 | Whirlpool Duet GHW9150P Front Load Washer
LG washing machine WM2277H tub off center does not spin electronically, manually its spins but rubs sides
Normal 0 MicrosoftInternetExplorer4 /* Style Definitions */ table.MsoNormalTable {mso-style-name:"Table Normal"; mso-tstyle-rowband-size:0; mso-tstyle-colband-size:0; mso-style-noshow:yes; mso-style-parent:""; mso-padding-alt:0in 5.4pt 0in 5.4pt; mso-para-margin:0in; mso-para-margin-bottom:.0001pt; mso-pagination:widow-orphan; font-size:10.0pt; font-family:"Times New Roman";} Hi,
Washer Problems Washer noise when spinning
Sep 02, 2010 | LG WM2277H Front Load Washer
Mold remain in rubber rim of washer
Hi Qqiustin.There are couple of solution for this,you can try that before attempt to change door gasket.1- Run machine empty on Cotton 95C cycle,while it's intaking water add 300ml of bleach.(It could produce some foam but let it go & finish it's cycle)That progress will clean your machine & mould on the door gasket should get disappeared.Alternatively you can try EXIT MOULD or likely products on the super market sells.Follow the instruction.Goodluck.Thanks.
Aug 02, 2010 | Miele W1926A Front Load Washer
Inserting loose rubber seal on front load washer
you can try holdthe one side and use a screw driver on the other end try to put the rmetal ring in the gasket. is batter if you have to persons...
Apr 10, 2010 | Bosch WFMC2100UC Nexxt Essence Washer
Strong mildew smell in washer is making cloths & towels smell bad, how do you get rid of the problem?
if you look inside washer there is a rubber rim on the inside around the openning. Look inside and you will find where the stink is coming from. Keep door open when not in use and wipe inside of rubber trim to keep the mildew out.
I use tilex sometimes and do a rinse spin.
Nov 16, 2009 | Kenmore Elite 45986 Front Load Washer
Suds get stuck in the rubber rim of the washer
You are not supposed to use suds, use 'washing powder' for 'front-loading washing machines' which is available in any supermarket.
Sep 29, 2007 | Bosch Axxis WFL 2060 Front Load Washer
Distroyed drumb
if it is only the rubber gasket and the spring loaded clamp that holds it in place it is worth repairing. if the tub, inner or outer, is damaged it is probably time to replace it
Sep 19, 2007 | GE WSXH208A Front Load Washer
Bosch WFR 145 Front Load Washer Logo
120 people viewed this question
Top Bosch Washing Machines Experts
Tim Whalen
Richard Roth
Richard Roth
Are you a Bosch Washing Machine Expert? Answer questions, earn points and help others
