I seek a replacement flat cable (connecting the CD drive to the board) for an Audio Alchemy Digital Drive System (DDS) III. The ID info on the cable read: Pinflex mxII; Y0040; 1-537-472-11; it's a 23-pin cable. this information is part of the metalic middle layer. Also silkscreened onto the reverse side is: 17G10. THANKS!! Ken W. k.r.westphal@kent.ac.uk
  • 162 Answers
Try this link
http://www.audioweb.com/Directory/DirectoryInfo.asp?companyid=34
Posted on Jul 30, 2009
Why does cd rom not conned to my macbook?
I'm not sure about this, because I have an internal CD/DVD in my macbook. But this can be a driver issue. Do you have an Apple CD drive, or an universal USB CD drive? The last one could be very tricky, because the computer needs special drivers, so it can recognise the external drive.
Jun 06, 2014 | Apple MacBook Pro Laptop Computer with...
Tip
How to enable CD digital audio extraction (Digital CD Audio Playback) 1. Click...
1. Click START / SETTINGS / CONTROL PANEL / SYSTEM.
2. Click the HARDWARE tab.
3. Click DEVICE MANAGER.
4. Click the plus (+) to the left of DVD / CD-ROM DEVICES and double-click your CD-ROM drive. Note you can also right click and select Properties.
5. Click the PROPERTIES tab and toggle ENABLE CD DIGITAL AUDIO EXTRACTION FOR THIS DRIVE.
6. Click OK
Repeat steps 4-6 for any other ROM drives listed in Device Manager.
Note you may need to reboot your computer for the change to take effect.
At this point CD digital audio extraction should be enable and you do not need to have the CD audio cable connected between your ROM drive and sound card. Note if you have an older computer (CPU under 1G) then you may need to have CD digital audio extraction turned off because your computer may not be able to handle the data from the CD on the system bus.
on Jun 01, 2010 | Computers & Internet
Does my TOSHIBA SATELLITE 2805-S301 have a way to go wireless?
No wireless on this laptop you would need to use a usb wireless adapter
roduct Details and Features Product MPN MPN
PS280U-ELCLOH Key Features Laptop Type
Mid-Size Laptop Use
Home Use Processor
Pentium III 650 MHz Hard Drive
10 GB Display
14.1 in. TFT Active Matrix Operating System
Microsoft Windows ME Weight
7.3 lb. Processor Processor Manufacturer
Intel Processor Type
Pentium III Processor Speed
650 MHz Motherboard Bus Speed
100 MHz Memory Installed RAM
128 MB Max Supported RAM
384 MB Installed Cache Memory
256 KB Hard Drive Hard Drive Capacity
10 GB CD / DVD CD / DVD Type
DVD-ROM Optical Drive Read Speed
8x (DVD) Other Drives Floppy Drive
3.5" 1.44 MB floppy Display Display Tech
TFT Active Matrix Screen Size
14.1 in. Video Installed Video Memory
8 MB Audio Audio Output Type
Sound card Operating System Operating System
Microsoft Windows ME Platform
PC Technical Features Input Method
Keyboard Networking Networking Type
Integrated Network Card Data Link Protocol
Ethernet • Fast Ethernet Modem Modem Type
Modem Analog Modulation Protocol
ITU V.90 Battery Battery Run Time
2 Hours Battery Technology
Lithium ion Dimensions Width
12.9 in. Depth
10.7 in. Height
1.5 in. Weight
7.3 lb. Warranty Warranty
1 Year Miscellaneous Product ID
20789390 Family Line
Toshiba Satellite
Jun 19, 2011 | Toshiba Computers & Internet
Where is the wireless on TOSHIBA SATELLITE 2805-S301
Hi just go this link below:
http://www.user-guides.co.uk/cddownload/Toshiba-Satellite-2805-S301-Windows-7-Driver-CD-Recovery-Restore-Disk-326243.html
Jun 19, 2011 | Toshiba Satellite 2805-S301 Notebook
How do I hook up the 2 audio outputs from CD-ROM on Intel D101GGC
You shouldn't need to connect audio connections from drives to the motherboard unless you are using A Win 9x operating system. Digital Audio Extraction is used for WinXP and later and the analog cables are no longer needed
Sorry no info on the pinouts
Mar 29, 2010 | Intel D101GGC Motherboard
No sound when i put in cd or dvd was working ok untill my computer crashed
check the following
Microsoft Volume Control or your mixer program mute options and volume sliders.
Connect headphones to the stereo phone jack on your CD-ROM drive’s front panel; adjust the volume control settings on the drive. If there is sound from your headphones, check the CD audio cable connection from the CD-ROM drive to the audio card.
Ensure the speakers are properly connected to the audio card’s output connector.
hope this can help
goodluck
JABEMS
Nov 13, 2009 | Hannspree 19" Widescreen LCD Flat Panel...
Disk boot failure insert system disk
Is it recognises Hard disk or not?
reply
i will try to solve u r problem
Jun 25, 2009 | ASUS K8V-MX Motherboard
DDS-5 not compatible with windows 2008
I am pretty sure that the driver should be compatible with win08.
If you are using backup exec then try switching to use symantec drivers for your tape drive (setting withing BUEX)
If it is just the tape that cant be read or identified and was backed up using windows backup then try restoring the backup on a 2003 server and then copying the data across the network.
May 10, 2009 | HP 364446-001 Storageworks DAT 72x6 DDS-5...
My computer says that my cd drive doesnt exsist any more. I opened it with the pin in the small hole, but it was never jammed. The problem seems internal and I dont know what to do.
If you have Windows XP, there's a flaw in the Registry that sometimes blocks your system from loading the CD drive - please try the following (but only if you're running windows XP!)
[Start] [Run] [Regedit]
Registry Key: HKEY_LOCAL_MACHINE\SYSTEM\CurrentControlSet\Control\Class
Key Name: {4D36E965-E325-11CE-BFC1-08002BE10318}
Value Data: [Delete All Value Data from UpperFilters and LowerFilters]
Note: Do not delete the Key or the Multi-String Values. Delete only the data values.
Exit Registry and Reboot
This worked for me when my drive went missing, so I hope it works for you too!
--- Kudos to http://www.theeldergeek.com/restore_missing_cd_or_dvd_drive.htm
Dec 31, 2008 | Computers & Internet
Samsung TS-H492 CD-RW Combo
are you using a single IDE cable with your H/Disk? if yes! check, the jumper connections of your CD-ROM,maybe the are both in the master position ,change the jumper of your CD_ROM to slave position.or use another cable for your CD-ROM.if doe'snt work go to BIOS SETUP,set the settings to default SETUP.then restart your PC.
Mar 10, 2008 | Samsung TS-H492 (TSH492AWRBH)...
62 people viewed this question
 Grubhead
Grubhead
