Question about Karcher K2.26 Electric Power Washer
B302 pressure washer wont use the additional cleaning solution
I have a B302 that wont **** up the additional cleaning solution. Even after 20mins of cleaning the drive the solution level has remained the same.
    Problem Solver:
  • 18 Answers
Use the nozzle with the least pressure black one i believe
Posted on Jul 30, 2009
Need to know steps to trouble shot hydrostar 98444 Pressure Washer.
The problem most people encounter with lawn mowers, weed eaters, and pressure washers is that today's gasoline has so many additives, that if it sits in the carb all winter, it coats and gums up the carb. Try watching this video that shows how to clean the carb of a pressure washer: https://www.youtube.com/watch?v=QCSrTIamUIY
May 13, 2015 | Garden
Karcher b302
see if you can spin the cooling fan of motor if so you may have a bad capacitor on motor
Jul 29, 2013 | Garden
1994 jeep cherokee (5spd) wont start
Yah sure check the fuel pressure on the manifold, ur belt tension and altenator. But a very common problem with jeeps is the crankshaft positioning sensor. Check and make sure ur gettin fire. If ur not could also b the ignition control module in the distribitor.
Dec 03, 2012 | 1994 Jeep Cherokee
My washer has some water in the bottom from the last use and wont drain all the way. Now it wont even refill for a new load.
aplastic tube leading from bottom of tub goes to a pressure switch and is probably plugged w lint. the machine tthinks its full & Wont prceed. clean tube & Switch
Jun 22, 2010 | GE WBSR3140DW Top Load Washer
When i try to use a cleaning additive, my pressure washer will not "****" the additive into the system
most pressure washers have a special nozzle when using the cleaning part to reduce the pressure and **** the solution from the tank. Check your owners manual and if not give me the brand and model number and I will check into it.
Jul 09, 2009 | Coleman Pressure Washer PW0881800
Dispenser problems
Open dispenser drawer and push down on center plastic tab at back of dispenser to allow you to take dispenser out of machine. Take the plastic pieces off and clean them. (they need to be clean in order to siphon the bleach, softener, etc out. If there is water left in them, the water fill valve is OK. Cleaning should fix your problem. If you are using concentrated additives, try diluting them a bit with warm water when you add them to the dispenser. Remember, only one tablespoon (max) detergent, one teaspoon (max) fabric softener per load.
Oct 18, 2008 | LG WM-2277HW Front Load Washer
Pressure washer wont idle and run
check the pressure replace valve or a bypass valve
Jun 05, 2008 | Karcher 2500 PSI Pressure Washer
B302 - unable to start detergent flowing - How should it work?
It will only pick up detergent if you use a low pressure detergent nozzle - or no nozzle at all. It also takes a while for the detergent to get to the nozzle.
Oct 18, 2007 | Karcher 2500 PSI Pressure Washer
Karcher K2.26 Electric Power Washer Logo
308 people viewed this question
Top Karcher Garden Experts
John Trevino
andy just round the...
Level 1 Expert
Are you a Karcher Garden Expert? Answer questions, earn points and help others
