SOURCE: Staples penetrate, but do not bend
If you unscrew 4 bottom screws to lift the top cover, you may find out that there are 2 orange rubbers above its hammer that broke and needs to be replaced.
SOURCE: Stapler (Swingline 211xx) has jammed. It is electr...
Turn the stapler over, remove the batteries, then remove the black pads and the four screwa under them. Take off the bottom cover and you will see the clear tabs of the cover sticking through the bottom plate. Pust them with a screwdriver toward the center of the stapler while squeezing the cover from the other side. Chances are that you will find the plunger that drives the staples is misaligned. Bend it gently forward or back until it moves without binding. Good Luck!
SOURCE: staple shredder
it has to be photo sensor you may need to remove them to clean them. i had to do this before because they were really dirty with oil and paper shavings
SOURCE: 900XDN-C SWINGLINE HIGH CAPACITY HEAVY DUTY STAPLER OPERATIONS MANUAL
auto parts store sells a pick with straight on one end and 90 degree on other end.
This should be slender enough to pull staples out.
Swingline heavy duty staplers provide the power to staple up to 120 pages of 20-lb. paper easily and consistently. The all-metal construction of these staplers makes them an indispensible office tool. However, the way to load staples into a Swingline heavy duty stapler differs from the method for loading most other manual staplers and can cause a little confusion.
Difficulty:Easy
Instructions
