Motherboards
Problem for Motherboards
Generic problem for all Motherboards
Incorrect value on ram
By marcial on Nov 24, 2007
i istalled 256mb ram but if i check in the computer properties it shows only 128mb. my mother board is va6 and a processor of p3.
Same Problem
Dec 20, 2007
-   I also have an ECS 755-A2. I installed what should be 1 GB of DDR 400 RAM and it detects something like 534233 K.
I have tried putting it in either of the 2 RAM slots, to no avail. Not sure what else to try. :( I even tried two different brands: Rendition & Crucial.-   Antelope
Best Solution
posted on Jan 06, 2008
Helpful)
DARKLORD1
Rank: Guru
Rating: 86%, 724 votes
Its simple, you got 256mb installed right, but when you click properties on my computer you only see 128mb, right ?
thats cause u have 128mb set as shared video memory size in your bios. to reduce this enter your bios by entering setup as soon as you power on your system ..
Comments:
Jan 07, 2008
- Does your board supporg a gb stick @ antelope ???
check your manual for details
Was this helpful?
Yes
No
Solution #2
posted on Jan 07, 2008
Somewhat Helpful)
sweet_rascal
Rank: Wiz
Rating: 81%, 774 votes
it also happens in some case that half portion of RAM dosent work. its due to technical faults.
you may have to replace the RAM soon.
and dont rate me inappropriate for this too. if you dont find it helpful leave it with out rating anything..
Was this helpful?
Yes
No
Solution #3
posted on Nov 24, 2007
Not Rated)
Benimur
Rank: Guru
Rating: 88%, 3821 votes
Even if the new memory is 256mb, the motherboard will not read it as such but a max of only 128mb. Alternately, what you need is to get is another 128mb SRAM rated at 100/133 MHz. Sorry to say but yours is a common problem when newer memory are fitted to a relatively not so recent machine.
Good luck and kind regards.
Comments:
Nov 24, 2007
- Opps, sorry "128mb SRAM" should read as 128mb SDRAM
Nov 26, 2007
- Hi again,
I am surprised that you rated my solution as "Inappropriate" Perhaps I misunderstood your concern; you are trying to fit a new 256mb SDRAM memory to an ABIT VA6 Apollo 133 Motherboard (roughly same age as a PIII500E). If the 256 works as a 256 in other motherboards or tested good from your supplier and it still reads as a 128 in your motherboard, isn't it obvious that it is not compatible?
The highest bus speed of a VA6 is 150MHz (overclocked) with a standard of 100 for early PIIIs, if your 256 memory is rated at 266 or higher, your MB will not be fully compatible to a newer speed since its highest regular speed is only 133. Pls try an older PC133MHz DIMM Sync DRAM 256MB, 7.5NS, 168-pin memory which would still possibly be available at HMR, SOS or OpenPinoy.
Hope that this shed light on the misunderstanding if any.
Cheers.
Was this helpful?
Yes
No
Popular Solutions for Motherboards
Questions and Unsolved Problems for Motherboards
Answer
Ive just looked at the specs for two motherboards 1,Asus P6T Deluxe V2 2,Asus M4A785TD-V EVO. WHATS... (More)
Answer
compaq presario mother board, what should I replace it with
Answer
you have to wipe bios to make it boot set bios upturn off.you have to wipe bios again to start up... (More)
Answer
My Matsonic MS 8157E motherboard has a built in Soundcard, but it does not work anymore, I tried to... (More)
Answer
network adapter missing. I've checked the bios and it is enabled, but nothing shows in Device... (More)
Describe your problem:
Select a Category:
Ask our Experts
Solve Your Problem Now!
Chat Live with an Expert
Chat Now
Top Motherboard Experts
Top Computer & Laptop Repairmen
(513) 874-3306
We fix and repair laptop motherboard no video, no...
LaptopOnCall Inc.
(877) 934-6198
Send your laptop to us and we will diagnose the...
A+ Rated Oceanside Computer Sales & Service, LLC
Chat Now
Insert Link
Insert Image
Insert You-Tube clip
Insert List
Insert List
Spell Check
What is this?
Select
