SOURCE: Isuzu Trooper anti-theft alarm
Join up the wires in the tailgate catch and the drivers door for the anti theft circuit the nthe unit thinks its allways unlocked so wont sound off .
SOURCE: anti-theft alarm
take it to a shop were they can hook up ur car to a computer and delete the problems and turn off ur alarm
SOURCE: isuzu rodeo 2000, LS, anti-theft alarm needs to be reset
This has to do with the Auto's Computer system and should ONLY be done by a Factory Rep who knows what he/she are doing. not a home mechanic chore!!
SOURCE: anti theft will not turn off, motor will not start
Disconnect the battery to the vehicle for 15 minutes and while disconncted change the battery in your key fob. Good Luck.
SOURCE: 1999 Nissan Maxima will not start up
there is a chip inside your car key
some times gets damage or the car computer gets damage and no longer recognize your key chip
this causes the anti theft system to prevent the fuel injectors to open and the engine will not start because has no gas.
the security light stain on is your hint of what is going on.
I had the same problem on a 99 Nissan Maxima but i got the car running again what you need to do is replace the engine computer and then call a locksmith to reprogram your key to be recognize by the new computer i when to a lot of pain and suffer to get this solve.
before changing any thing make sure the plastic part of the key is not broken, if it is call your locksmith to make you a new one before changing any thing.
NOTE do not use a computer from a salvage yard unless you get to see the actual car it came from
if it came from a car than has the body in one piece do not buy it
its real hard to diagnose this problem and
chances are it came there because of the same problem you have.
if the car looks like it was in a crash the computer is more likely to be good.
but its always best to get it rebuild or brand new if you can.
after you change the computer call the locksmith to get you car key reprogram.
Do not use a computer from a 98 or 2000 because they will not work no mater what the salvage yard tells you they are to make money not to help you so it has to be 99 only.
