Question about Intel Pentium 4, 3.0 GHz 530 (bx80547pg3000ej) Boxed Processor
Swaping hdd 845 motherboard to 915 motherboard
I have 2 pc P4 1.8Ghz/256 Ram/40GB Hard Disk with Intel 845 GVSR motherboard with Windows 2000 Proffessional O.S
Other config is P4 3.0Ghz/1 GB Ram with 915G Intel Motherboard.
I want to swap the harddisk from one cpu to other whether I have reinstall os or change, it will corrupt my working files.
Thanks & Regards
Prakash
  • 390 Answers
Its always safe to have data backed up
u can swap the HDD
but bootup with the Win2K CD in the Drive and after the files are loaded at the first screen select install then after it detects the OS select R (Repair) and this will reinstall the operating system files and then you can use the system as before though u may have to install the device drivers and motherboard drivers
for any other clarifications u can place a comment in the same question or u can mail me at mail2pvs@gmail.com
Posted on Jul 30, 2009
I have an Intel 845 Gvsr Motherboard,with 512 mb 266 Mhz RAM I want to upgrade the system to 320GB, with 2 Gb RAM, and also I want to make it HD Compatible is it possible, and is it worth taking a risk. ...
Upgrading HDD is no risk for your PC. The RAM memory instead should cause a problem if it's not compatible. The problem that can appear is simple: your computer won't start until you take out the ram memory. Your type of motherboard supports:Max 2Gb of RAM (DDR SDRAM)
Cheers.
Jan 17, 2011 | Intel D845GVSR Motherboard
Drivers for intel 845 gvsr with p4 2.4 gHz for windows 7
please visit the website below and search for your board 845 then select your operating system in the right hand box and the drivers that are available will be show below hope this has helped http://downloadcenter.intel.com/Default.aspx
May 22, 2010 | Intel D845GVSR Motherboard
Finding Intel 845GVSR & 915GLVG Compatible Motherboard & Proc
you can use intel dg41 mbd , dualcore processor,1 gb ram,160 gb hdd or use intel atom for support contact 91-9645071021
Aug 11, 2009 | Intel D845GVSR Motherboard
RAM SUPPORT FOR D 845 GVSR MOTHER BOARD OF 2004
Greetings
Memory support for your d845gvsr board is as follows:
Memory speed - 333MHZ, 266MHZ and 200MHz.
Memory type - DDR SDRAM
Max Memory - Capacity of up to 2 GB
Memory Slots - 2
Memory module size is 1GB (1024MB) for slot.
Thank you,
Let me know if you need anything else.
Ekse
Mar 02, 2009 | Intel Motherboard
Display driver for 845 gvsr
http://downloadcenter.intel.com/Product_Filter.aspx?ProductID=1065
There you go!
Just select your OS and you will be able to download al avalible drivers for that MoBo, including the graphicdrivers you need!
Good luck to you
Please take a moment and rate my solution
Nic
Feb 11, 2009 | Intel D845GVSR Motherboard
Slow speed+hard disk
problem not clear enough
Please Don't Forget To Rate "FIXYA" Me For The Help
Dec 21, 2008 | Intel D102GGC2 Motherboard
Ram Support
You can add that to the motherboard. 80% chance your motherboard will support that memory. It will run at a lower speed if your motherboard can only run at a lower speed than 400Mhz
Sep 18, 2008 | Intel D845HV (735858149143) Motherboard
Intel 845 GVSR drivers for windows vista
i don't know weathere you are awared of this or not...
to get the 32 bit graphic on 82845gv motherboard go to BIOS setting and change your video frame buffer size to 8 mb and agp aeperture to 256 mb and let the system boot... you will get 32 bit graphic with 1024 x 748 screen resolution... i have changed and believe me it is working
but only problem is that you will hardly play any game or use bubble screen saver..
Feb 24, 2008 | Intel D845GVSR Motherboard
Open Questions:
See all Intel Pentium 4, 3.0 GHz 530 (bx80547pg3000ej) Questions
Intel Pentium 4, 3.0 GHz 530 (bx80547pg3000ej) Boxed Processor Logo
195 people viewed this question
Top Intel Computers & Internet Experts
Tony
David
David
vsri9
Are you an Intel Computer and Internet Expert? Answer questions, earn points and help others
