Question about HP Photosmart 3310 Printer
My HP 3310 All-in-One is relatively new and is displaying "ink system failure" even after replacing all of the cartridges and rechecking them. I've tried unplugging the machine and have scrolled to "tools" to clean the printer heads.....no luck. Please advise. Kathryn Long
    President:
  • 2,185 Answers
Reset the system by holding down the OK, Cancel, Black, and Color buttons down at the same time and turn the 3310 off. Keep holding the buttons down until the printer shuts off and then turn it back on. You will have to turn the printer off twice and then it will recalibrate.
Didn't quite worked for the first time, but it did on the second try.
http://www.fixyourownprinter.com/forums/printer/39471
Posted on Jul 30, 2009
HP Photosmart error code Oxc19a0002 what does it mean?
This error code indicate a failure in the ink system. If you've tried with different/working cartridges, please follow the instructions given HERE.
Good Luck.
Thanks for using FixYa.
Jul 17, 2011 | HP Photosmart 3310 Printer
INK SYSTEM FAILURE Ink system has failed. Unable to copy, receive faxes or print. Refer to printer documentation. error: 0xc19a0013 Press OK This is the error in which I am receiving and I need to...
The Ink waste tank filters are usually change by a technician or the counter can be turned back. The ink waste tank is found at the base of the printer
Aug 08, 2008 | HP Photosmart 3210 Printer
0xc18a0106 error from hp 3310 printer.... ink system has failed
That error code indicates a Ink system failure error message. Ink system failed mainly caused by your cartridge spitting extra inks into the copper contacts inside the printer. All you need is to remove all cartridge, clean the copper contacts at the back of it, clean also the contacts inside the printer (cartridge slots). Insert it back in after cleaning, unplug the power cord without turning off the printer, wait for 1 min before plugging it back in. Let me know the result.
Nov 23, 2010 | HP Photosmart 3310 Printer
HP 1050c....Hi, i am getting error on display for
Are you using HP factory new cartridges or some third party cartridges or even wores a refilled cartridge?
80% of the time, that's the cause of the failure.
Don
Feb 24, 2010 | HP DesignJet 1050c plus InkJet Printer
Have a hp 3310 it says ink system failure error 0xc18a0106 it wont print,scan,copy and it does have enough ink. thank 4 ur help
Turn off the machine using the power button, unplug the power cord from the back of the machine, remove the ink cartridges, wait 2 min, plug the power cord back in, press the on button, wait until the printer prompts that the ink cartridges are missing, then replace the ink cartridges. If this doesn't clear the error then you may need to re-prime ink through the system to clear the error. There are good instructions for doing this at http://www.ccl-la.com/blog/index.php/hp-photosmart-ink-system-failure-1/.
Feb 20, 2010 | HP Photosmart 3310 All-In-One InkJet...
Error message oxc18a0001 ink system failure
Go to HP website, I recall some info there on this
Apr 25, 2009 | HP Photosmart 3310 Printer
HP Photosmart 3310 printer shows all ink cartridges need replaced
If you ran the ink cartridge refill routine, from your desktop using the utility supplied by HP, this should not occur, so try running the head cleaning and alignment routines and see if this clears up the problems.
I am assuming that all your cartridges are relatively full and trouble free and that the printer has been successfully and recently used, prior to your replacement of the one new cartridge.
Sometimes, if the printer has been idle for some time without use, the ink will dry on the heads of perfectly good cartridges, causing the problem you cite.
Use alchohol based cleaner with the kind pads supplied with a new cartridge to regularly clean the heads of your ink cartridges, according to instructions in your manual and CAREFULLY, so as to not damage the heads.
Apr 07, 2009 | HP Photosmart 3310 Printer
Ink failure
  1. Press the On button to turn the printer off.
  2. Unplug the power cord from the back of the printer.
  3. Remove all the ink cartridges.
  4. Wait two minutes.
  5. Plug the power cord into the back of the printer.
  6. Press the On button to turn the printer on.
  7. Re-Install the ink cartridges when prompted.
If this doesnt work then apparently the controller for the inkjets is bad. you would be best served to take it back under warranty or replace the printer
Jun 13, 2008 | HP Photosmart 3310 Printer
HP 3310 All In One Error
Try to reset the system by holding down the OK, Cancel, Black, and Color buttons at the same time and turn the 3310 off. Keep holding the buttons down until the printer shuts off and then turns itself back on. You will have to turn the printer off twice and then it will recalibrate. Make sure you have new cartridges in the printer so that it can reset.
Oct 31, 2007 | HP Photosmart 3310 Printer
HP Photosmart 3310 Printer Logo
42 people viewed this question
Seeker5211
Seeker5211
