Question about iLO (2 GB) MP3 Player
Flush disk write protection
I have a flus disk that contains a write protected files and folders i need to delete it in order to put new files on there but it wont let me delete it.can someone please help me and tell me how to remove it step by step..thank you!
  • Anonymous Nov 24, 2007
    i have a flus disk that contains a write protected files and folders i
    by step..thank you!
  • 8,596 Answers
Make sure the hold/lock is not engaged
Posted on Jul 05, 2008
Are you sure the files are going in there? Many times the manufacturers only allocate the size that they need partitioned on that drive. I have seen many cases where that drive is full from factory and people always get that message.
  1. Click Start c01508537.gif and right-click Computer .
  2. Select Properties .
  3. Click System Protection from the left side of the Window.
  4. In the section "Automatic restore points", remove the selection next to the D: drive, and then click OK . If the D: drive was not selected, close this window. Figure 3: System Protection tab with D: drive unselected
  5. Right-click Start Explore All Users .
  6. Before you can remove the backup files and folders, you need to be able to view hidden system files as follows:
    1. From the explorer window press the Alt key on the keyboard to make the menu bar appear in the window.
    2. From the file menu, click Tools , and then select Folder Options .
    3. Select the View tab.
    4. Select Show hidden files and folders , remove the selection from Hide protected operating system files and then click OK .
  7. From the Folder Options window in explorer, double-click Recovery (D:) .
  8. If a Window opens stating "You don't currently have permission to access this folder" opens. Click Continue .
  9. If you previously copied or created any files into Recovery (D:) and you want to keep them, copy them to another drive - such as the C: drive.
  10. Find and delete any files that you previously copied onto the Recovery (D:) drive.
    CAUTION:Do not delete any files that are associated to recovery! Do not delete the items RECOVERY, $RECYCLE.BIN, boot, hp, PC-Doctor, pcdr, or PRELOAD! Doing so can prevent a future system recovery from the hard drive. If you are not sure, do not delete the file.
    Press Shift + Delete to permanently remove the files.
    To delete files created from MS Backup (MS Backup files are not recovery files), find and delete the folder with the same name as the computer name in the Recovery (D:) partition. For example if the computer name is BOB-PC, the folder containing the backup files would be named BOB-PC and would be deleted.
  11. Several confirmation windows open. Click Continue , and Yes until the folder is deleted.
  12. To set Windows Folder Options back to their original setting as follows:
    1. From the explorer window press Alt to view the file menu.
    2. Click Tools , and then select Folder Options .
    3. Select do not show hidden files and folders and select Hide protected operating system files .
    4. Click OK .
  13. Close explorer. The Out of Disk Space errors should no longer appear. If you would like to use the Microsoft Backup Tool again, open it and select a different external backup device to store the backup files on.
Aug 17, 2012 | HEWLETT-PACKARD Computers & Internet
How to Delete Protected Folders from a Memory Sticks
<p>Folder on the removable media used both FAT32 and NTFS file systems in Windows operating system. Some of these attributes in the rule of the people (name, size, creation date, and time) can be seen, others have explicit measures to ensure Windows. Among the latter are "read only" (if set, the folder cannot be erased) and "hidden" (if set, the folder does not appear in the parent directory.) A folder is set with one of these protected attributes clear. With a few extra steps, but you can secure a folder from a memory stick.<br /> <p> <br /> <p>1. Connect the memory stick for your computer. Windows will recognize it automatically and make your content accessible.<br /> <p><br /> <p>2. Click the "Start" and "run" (without quotation marks) into the search box. Click the "Run" link, type "cmd" and press Enter. A command window opens.<br /> <p><br /> <p>3. Type the following commands in the command window:<br /> <p> <br /> <p>E:<br /> <p>cd "\ myfiles \ projects"<br /> <p>Replace "E:"with the drive letter for the Memory Stick and replace "\ myfiles \ projects" with the full path to the folder containing the folder you want to delete protected. Press Enter after typing each line.<br /> <p>4. Type the following command to remove the attributes currently prevents you from deleting the folder:<br /> <p>attrib -r -h folderName /e<br /> <p>"Folder Name" Substitute the name of the folder you want to delete. Press "Enter ".<br /> <p><br /> <p>5. Delete the folder by clicking "Start", then "Computer". Navigate to the folder you want to delete, click once and press Shift-Delete. "Windows will erase a protected folder from memory stick.<br />
on Jun 21, 2011 | Computers & Internet
Hi im anthony and i had bought a laptop from a guy and it has k9 web protection on it and im tryn to get it took off can u pleasde help me
there are two methods you can try.
Method 1
If you have the administrator account password for the local computer and the best way to uninstall K9 web filter from the local computer is to re-install it! Re-install k9 web protection will simply get you a new license code and a new password you can enter without the need of old password.
1.Open K9 web protection website 2.Click "get K9 NOW" tab on the top-left 3.Fill out the information and your email. 4.Download the K9 Web protection software from the link included in the email and keep a copy of the license. 5.Grab a version of the K9 web protection installed on your computer, a Google search should do the job. 6.Open "Task Manager" by press (Ctrl+Alt+Delete) and end the process K9filter found in the "Process" tab. 7.Now, you can safely delete the K9 web protection program files. Open computer explorer and go to the folder where K9 is originally installed. It can be found mostly at C:\Program Files/Blue Coat k9 Web Protection. 8.Remove the contents of the folder but not the folder. 9.Run the K9 web protection setup/installer file which has the same version as the one you just delete 10.Provide the license and create your new password 11.Point the installation folder to the same folder you just empty the contents earlier on 12.Now you can have a re-installed K9 web protection with a password you know. How do you uninstall K9 web protection now? Use the new password you just created If something goes wrong, install the K9 web protection program downloaded from Step 4.
Method 2
Reboot Windows into safe mode: restart your computer and hold "F8? key until you see the menu to choose "Safe Mode" Login to windows and go to "Program Files" directory and delete the K9 folder manually (delete only the contents but leave the folder) Click "Start"->"Run" and type "msconfig" Check the tab "Services" and tab "Startup" Un-check anything that is related to k9 If somehow this method is messed up, try to download K9 again to at least restore your previous installation. If this still does not work, try to install Revo Uninstaller.
Here is a video tutorial
Aug 24, 2011 | Dell Inspiron 1501 Notebook
In My Computer Disk drive E - one of folder using earlier, now iam not find the same folder file. If i create in the same name folder showing the error message contains.... the existing file already...
you just accidentally hide your newly created folder. go to tools it in your upper view. click the folder options. > view > click the show hidden files and folders > and also unchecked the hide protected operating system file (Recommended). after that you will see the folder that you create. im sure virus and trojans are responsible for that.
Jul 12, 2011 | Computers & Internet
I cant delete some video clips from my pc, every time i tried to delete it, a message appeared.. saying " Make sure the disk is not full or write-protected and the file is not currenty in use" ...
Seems like files and/or folder is write protected ( in Read Only Format ).
Right click on the folder and click on properties. Check if there is a check mark on Read Only or any such other check mark. If so, remove those check marks and then open the folder and try to delete.
If this does not work, Check with the file you wanna delete in same way.
If it still does not work, you most likely do not have permission to delete files on your PC profile that you login with. You either need to be administrator of the PC with admin rights or the person who has the admin profile should give you full rights on your profile.
* Please rate this solution with Thumbs up and Testimony to help us improve providing support
May 14, 2011 | Computers & Internet
Write Protected USB
hi Not only your pendirve your computer system is also affected by virus . please check your pendrive with any other computer .before you connected open your pendrive format your pendrive with any other computer. if it will not work you have go for any new pendirve. bye
Jun 16, 2009 | Disney High School Musical Mix Stick 2.0...
Use following link to download recover jetflash from transcend site.
note that the data on the pen drive will be erased. so back it up before you run it.
  • 1 week ago
Sep 16, 2008 | Electronics - Others
How to remove write protect on my usb flash drive
There is a software on internet, it is FREE of charge, it is called unlocker, it's a simple installation that lets you delete, rename, move any file/folder, just right-click the desired file/folder, go to"Unlocker" the image is a wand, and select the option you want.. works for me. good luck. hope this helps
Jun 02, 2008 | Creative Labs Zen Digital Media Player
iLO (2 GB) MP3 Player Logo
65 people viewed this question
Top iLO Audio Players & Recorders Experts
Mohamed Ismail
Mohamed Ismail
Michael Vincent Cruz
Are you an iLO Audio Player and Recorder Expert? Answer questions, earn points and help others
