Question about JVC Televison & Video
I bought a jvc tv crt model AV29RT28 last may 14, 2008. my problem was a week after i bought it discoloration on the screen was noted. i report this problem to jvc service center. they said that the picture tube was the problem. i would like to ask if they will replace same model of picture tube. as i notice the picture tube they replace was not of the same model. can you help me with my problem. thanks.
    Novelist:
  • 123 Answers
I presume that the set is second hand?? They`ve got to fit the correct tube for safety reasons and the set is designed to work with that tube only for that size of set, HOWEVER, they may fit a regunned/refurbished or even a second hand tube in the set. Ian
Posted on Jul 30, 2009
JVC CRT tv (no handset)- first time installattion screen is frozen
Assuming by "handset" you are referring to the remote control which is essential for initial set up. You need to get the appropriate JVC remote or possibly a universal remote that may or may not provide the needed functions.
Dec 17, 2013 | Televison & Video
I just bought a 50" plasma Tv - Insignia last week. We've used it for about 2-3 hrs. per night for 4 night and then... we noticed that the majority of color on the screen has discolored lines in it. What...
Go into the tv menu.Go to PICTURE,go down to reset,to reset the tv Tuner signal board.The picture now it resetiing back to the factory setting.The tv colors should be fine now,not than take the tv back where u bought it,get a replacement.
Oct 18, 2010 | Insignia Televison & Video
I am starting to get a discoloration in the bottom left side of my screen. It is slowly making it's way up to the middle of the screen.
If it is a tube type TV, probably needs degaussing. The screen within the crt becomes magnetized or external magnets from speakers are causing a problem. Sometimes changing the direction or position the tv faces causes degauss problems. If moving nearby speakers changes the discoloration, then speakers are too close or TV needs degaussing. Some high-end Asian tvs have E-W adjustment in users menu to correct this problem.
If it is RPTV 3 tube crt TV, maybe a convergence problem.
If it is DLP or LCD rear projection, probably optical engine failure.
What model is TV. Is picture normal in BW with color turned off?
easyab
Apr 22, 2010 | Televison & Video
Tube tv has a discolored spot on outer edge?
Sounds like it may be a deguasing issue. What type of set?
May 16, 2009 | JVC Televison & Video
My jvc tv model av-56wp30 has a big way line across the top
You have a CRT TV
CRT's get dim with AGE. This is normal.
Your TV is getting old.
NO fix. Get a new TV
Mar 24, 2009 | JVC AV-56WP30 56" Rear Projection...
TV: bright line across black screen for several hours.
vertical output ic needs to be resoldered. careful leaving that bright line displayed on the screen as this will cause a permanent phosphor burn into the tube. this can not be corrected once burned unless you replace the tube. mch
Mar 08, 2009 | JVC Televison & Video
Sony FD Trinitron Wega model KV-34BR800
Sony Wega Triniton KV-32FS100 TV
For the last week my TV has been going to a black screen for 10 seconds or so then the picture returns. It has been continual. Last night it stopped going to black screen, but now the standby light flashes 5 consecutive times and the color went haywire. A lot of red and everything that is suppose to be black is green.
I did a soft and hard reset with no success. What's wrong and is it worth fixing? Bought new in November 2002.
Aug 01, 2008 | Sony FD Trinitron WEGA KV-32FS100 32" TV
JVC AV-32f704
the problem is your high voltage section in the main board of you tv,try to resolder the the circuit and components near the flyback
Sep 01, 2007 | JVC AV27F476 27" TV
Tv problem
I assume you get a picture in there somewhere? The discolorization is caused by the degauser circuit malfunctioning or un-shielded speakers sitting too close to the TV causing magnatism in the CRT (picture tube).
Apr 08, 2007 | JVC AV-32F802 32" TV
Top of the screen Picture Problem
sound like you have 1 or a couple of leaky/bad capacitors in the tv's vertical circuit, typically, there sould be 5 to 10 caps. in all, but you just need 1 bad one to cause your problem. good luck.
Mar 13, 2007 | JVC AV-27230 27" TV
Televison & Video Logo
103 people viewed this question
Top JVC Televison & Video Experts
Jaime Hernandez
Henry  Thomas
Henry Thomas
Are you a JVC Televison and Video Expert? Answer questions, earn points and help others
