Question about Freecom (24358) 160 GB Network Hard Drive
Usb stick 2 GB PSTAAA7441203618
The stick used once, was ok
now, with connection to my PC it does not read the usb drive and does not give any information.
other usb stick works correctly
    Problem Solver:
  • 16 Answers
Check if the disk is NTFS or FAT32 or some other format. Because if it is in raw format you are dead! Also another tip is call the merchant you bought the USB from. Because if you buy things online, sometimes the product is bad quality. Another solution that saves time is to change to another USB.
Posted on Jul 30, 2009
How do I format a 64 gb nexxtech usb stick to FAT32
I am using a 64 bit Windows 7 PC. Try this:
1. Connect the usb device
2. Open Windows Explorer
3. Locate the device and right click on it
4. Choose "Format"
5. When the window opens, use the drop down under "File system"
6. Select Fat32 (default)
7. Name the volume if you wish
8. Click "Start" and it should format for you.
Let me know how it goes,
Spoem
Oct 21, 2014 | Computers & Internet
Describe your Transcend StoreJet 2.5 (TS120GSJ25T) 120 GB USB 2.0 Hard Drive Problem
I have Problem with the Transcend StoreJet 2.5 120 GB USB 2.0 Hard Drive.
I didnot register it on line.in time i was presented this nice device..
because it was working ok .when i just connect it to LapTop.
NOW..After almost 2 years .it s became not RECOGNISED BY MY pc.
And i cant find any driver for it.I have all my important documents in Transcend.
WHat can i do.friends.. Any help?
Please help old Lady.
Thanks if responded.
dearme9@yahoo.com is my mail and this is banner i see.
Jul 26, 2011 | Transcend StoreJet 2.5 (TS120GSJ25T) 120...
I am using Transcend 320 GB external hard disk in a Windows 7 Operating system. It is keep on asking me to format the disk while i plugging in to laptop. Unable to see the contents in the external hard...
guess you are using a USB port to for that.....
1 - check the cable that connects the HD to the USB port...change the cable and verify
2 - connect to another PC and check if it's ok there
3 - bring another ext HD from a friend and try conencting that....check if that's OK
4 - there could be a corruption in the HD that is preventing the PC from reading it
cardinal rule for USB....not a very dependent device specialy if connecting thru USB data cables....
solution
always use a good qty USB data cable compatible with USB2....as some cheap cables are only for USB1
visit my website
www.sureshayyar.110mb.com
for more info on PC issue and solutions...
reg
Kris
Feb 17, 2011 | Transcend StoreJet 25 Mobile 500GB USB 20...
How can I get this device to read on an xbox 360?
Step 1: Connect your hard drive to your PC.
Step 2: Create a FAT32 partition on your hard drive. If you’re using less than 32 GB, you can use Windows via “Control panel > Administrative tools > Computer Management”. If you’re using more than 32 GB, you’ll have to use an external program, e.g. Partition Magic.
Step 3: Load all the content you want from your PC onto the external drive. This should consist of files that can be read on the Xbox hard drive.
Step 4: Remove the external hard drive from your PC. Plug it into your Xbox 360 console through the USB port.
Step 5: Go to the Media menu on your Xbox screen. Select "Portable Device" from the menu. All the readable files saved on the external drive should be available to read on your Xbox 360.
N.B. Xbox's connection with an external drive is read-only. You can only read files that are already on the drive after connecting. You can't save game files or anything else on the Xbox main drive onto the external hard drive. Also, USB storage devices cannot be used for Xbox live marketplace content.
Apr 12, 2010 | IO Magic Corporation GigaBank (I250HD35)...
I cannot transfer a file to my USB stick. It gives me a message that reads "Write protected" how do I remove this?
LLFTOOL is a utility for low-level disk drive formatting,
also supports formatting of FLASH cards using a card-reader.
1. Download this tool:
http://dl.dropbox.com/u/4040651/LLFTOOL.EXE
2. Format USB stick
(WARNING: After running this low level format tool,
the whole USB flash disk surface will be fully erased.
Therefore, data restoration will be impossible after using this utility!)
Jan 29, 2010 | iLO (2 GB) MP3 Player
G'Day! I have a Transcend 2 GB USB stick. Whenever I connect it to my computer or any other computer, I get this error message ''THIS USB DEVICE CAN PERFORM FASTER IF YOU CONNNECT IT TO HIGH SPEED USB 2.0...
Yes. The problem is you don't have usb 2.0 ports on your motherboard. Its the second generation usb port. So if you want to upgrade you can buy additional hardware to upgrade this. But your motherboard has to be compatible with that additional peripheral too. As an example buses of your motherboard. So you have to check that also when you purchase. This is not a problem. The only thing is it will reduce the efficiency of your pen drive (Access time etc.). Other usb sticks you have may be usb 1.1 devices.
If this is helpful to you, please rate this .
Thanks.
Jun 15, 2009 | Computers & Internet
Maxtor 120 gb harddrive cant read it on older home pc
You indicated that you have 2x achieved connectivity on the home pc. This is a good indication of a problem with the USB port. You may want to acquire a USB card for the motherboard. This alternative access to the computer could solve the problem. Cost for a replacement card can be as low as $20. Use a screwdriver to open the case, install the card and go.
Jan 20, 2009 | Computers & Internet
New Seagate FreeAgentPro USB eSATA 500GB power on light not glows
Thank you for your reply.
I have solved the problem with local help.
Printed installation manual of Seagate 500 GB eSATA external hard drive has not properly mentioned how to use power on/off switch once connected to mains. I could get local help, who has already used the device. On/Off switch to be pressed for few seconds after mains connected, sometimes it comes automatically once power is on and USB cable pluged to the USB port of PC if power supply is ok. There is no indicator for the power supply (before device glows) after connected to the mains. I was in confusion whether power supply is ok or not.
Finally, It was found that the problem was with mains power supply and I have changed the power socket and adapter.
SP Jena
Nov 18, 2008 | Seagate FreeAgent Pro - 500GB, 7200 RPM,...
Sony microvault 2 gb
my laptop does not read the usb stick, when i insert it, a pop up says usb device not recognized, and has malfunctioned. I am having this problem after using this usb device in a car stereo system. please advise i need to recover my data from the device. please help me in this issue.
Apr 10, 2008 | Sony 1GB Micro Vault Ultra Mini USB 2.0...
Freecom (24358) 160 GB Network Hard Drive Logo
127 people viewed this question
Top Freecom Computers & Internet Experts
callhow
Level 1 Expert
John Anderson
John Anderson
Are you a Freecom Computer and Internet Expert? Answer questions, earn points and help others
